• Happy Peace Officers Memorial Day! 👮🏽‍♂️👮‍♀️
Alan's Bloodvein II
As to what to call the feature you are working on: I don't think it has a stabilized name yet. It's still new, compared to the weight of boat-building tradition. We're still working that out.
The feature we're talking about is not new. It's been a standard, stabilized feature designed and incorporated into U.S. solo and even tandem canoes for at least 45 years. I've started a thread about the history of this "shoulder" feature HERE.
LOL OK, we've got the terminology discussion separated and I'll endeavor to (at least try to) be more accurate.
No pictures today but I stopped by the shop tonight & got 2 more strips on. As both ends need tapered to fit and then spliced in (strips still aren't long enough to go full-length), it's taking about an hour per strip. I'm done with the Poplar now except for that tiny piece in the center so it's almost all Sassafras from here in.
I did pick through the remaining Poplar strips for a couple with vivid purple and I'm gluing them together for the float tank panels.
Despite my efforts to keep my center line centered, there were a couple of places where it was slightly off (although not nearly as far off as when I built the Freedom Solo [my first]).
Whether the drill or the saw was angled doesn't matter but having the center line slightly off center causes a mismatch if you're using accent strips on the floor (Bilge?). I wasn't far off in the bow but I decided to get it as close as possible so I fitted a small tapered piece of Poplar to help the Sassafras strips align.
This worked out pretty well and I feel that the additional piece will be less visible than a color mismatch. If I'm wrong on that: oops. Too late now, I glued it in, used some discarded ends of strips to hold it for a hour or so until the glue set up and then started in with the Sassafras.
In some cases I marked the start & end points from above and, in others, I held the strip into place with one hand, reached under with a pencil and marked the taper. I, honestly, don't know which is easier.
In either scenario, I then used the pull saw and an OSB discard to cut a little wide of the line and rasped & sanded until I felt that I had a good fit. The fitted strip was then glued into place, forced tightly against the previous strip by whatever means necessary and pulled down tightly with a ratchet strap over the hull
As the hull closes, it becomes impossible to use the jimmy clamps in their usual manner but the narrow areas can be wedged with strip discards and the wider areas can be held with the handles of the clamps. (I find it easiest to put the clamp in sideways, reach under the hull, squeeze to open the clamp and then turn the clamp so the handles push the strip tight)
There were also places where the strips needed to be held or pushed up from the bottom. I find that bar clamps work well for this and I put the tail(?) of the clamp against the hull
and then use the tensioner to force the tail away from the strongback
There's plenty of waiting time at this stage of the build so I finished gluing up the panel that will eventually become the float tanks
trimmed off the overlapping ends of the strips on both the bow and stern and then shaped the "stem" areas with the horse-shoeing rasp
I was thinking that I was ready for the whiskey strip tonight but found more mismatches where I returned to Poplar for the very center. If I had not switched woods, I would not have had to do anything and I feel reasonably certain that nobody would have noticed. However, because the Sassafras should darken a LOT more than the Poplar over time, and I like the results of the first mismatch repair, I decided to do it again toward the stern but switch the method slightly to see if I could hide it even better.
As you can see here, I'm way off...
I put 2 strips together and lined up the cove edge of the innermost strip to the Poplar center strip, then reached under to mark the taper.
Because of the length (and my general lack of patience), I cut this out using the bandsaw (then did it again because I was going too fast and broke off the last 8 inches or so as I cut out the feathered edge).
I rasped and sanded the patch until it fit well, sanding a rounded edge to simulate the bead and then checked my width
(You may be able to tell that the last picture was taken prior to the previous one. I continued to test fit the width as I sanded the edges of the patch but forgot to take a picture during the final fitting)
Once satisfied, I glued the patch into place and used scraps to wedge it. I found that I could vary pressure by getting a reasonably snug fit and then jamming another strip in between two of the longer strips (hopefully this makes sense with a couple of pictures)
And that's where I am tonight. I still have a minor mismatch toward the bow
but I'm thinking that it's minor enough to just fit the Poplar, let it flex left to fill the gap and hope that I can scratch the glass quickly and sufficiently enough that nobody will notice.
Not much going on tomorrow & rain in the forecast so I'd like to get the hull closed up & get sanding this weekend (oh, boy, almost to the fun part) 🤢
Note: This morning, it occurs to me that the center line was off because I hadn't accounted for the kerf of the pull saw (it's not very wide but it's not paper-thin either), and it's kind of surprising how little error is required to cause the strips to be that far out of alignment.
I really like the fact that I can cheat after screwing up and the repair may not be visible except upon close inspection (TOO close IMO unless the inspector is planning on paying stupid money to take the boat home) but it's certainly more efficient if I don't have to fit those cheater patches.
I think I'll drill wide of the center line next time (probably at the outside edge of the line on the forms) and sneak up on it more as it would probably be faster to shave the line than to fit the repair strips and I could still shave some to fine-tune it even as I continue to close the football.
Live and learn (FAFO isn't always a bad thing)
I'd run awfully close on the amount of Sassafras and didn't want to set up the shaper for one strip so I had to get somewhat creative with clamping when I had to splice the last Sassafras strip
that done, I finished stripping and the whiskey strip of Poplar looks pretty uniform.
Especially with the color difference drawing your eye away from it, I think the cheat strip (visible between the 2 rows of staples opposite the pencil) is going to be pretty hard to find once sanded.
The bow (where I didn't bother to realign the Poplar & just allowed it to run long) didn't turn out too bad either IMO
I could have gotten a little better fit on the centerline but I'll tape off the inside and allow that crack to fill with sawdust while I'm sanding. The epoxy will saturate it when I glass and I suspect that I won't be able to see light through it when portaging (not that it will bother me if I can)
The next order of business was removing all those staples.
I had bought a staple remover and it worked pretty well (also holds the staple after removal so they don't just fall on the floor)
but it did have a tendency to break a staple every dozen or so, and I wound up going old-school on it and just using the small vice grips instead of the new toy.
I managed to get about 2/3 of them out before the gorgeous day drew me away in favor of washing the scooter and going over it for the Spring. I went to get 2 gallons of fresh gas with the car and then rode the bike to top off the tank.
Interestingly, the trip to the gas station is about 30 miles longer on the bike.
No work tomorrow so I'm hoping for an early(ish) start and lots of sanding.
I used to have one of these pullers that came with an Arrow stapler. It is the best puller I’ve ever used. Apparently someone else like it too and felt they deserved it more than me. I might just have to make one. It’s hard to see in this pic but it has a spring steel leaf to hold the pulled staple.
Well, I got all of the staples out and ran the shoeing rasp over the hull to finish trimming the knuckle or shoulder, remove all of the excess glue and knock down any high spots.
One observation that really hit home today was that there are very few spots that need supported from below before glassing.
In each of the other hulls, there have been a couple of places where bending against the grain has caused the strips to "oil can" a little and I've corrected that using the bar clamps between the bottom of the hull and the strongback, holding the low spots up as described on Thursday (above).
I've always assumed that the "oil can" effect was caused by using rough cut (4/4 or 5/4 inch) boards instead of finished lumber (3/4 inch) and that the extra 25 or 30% was just a bit much when bending against the grain to close the football (from the chine through the bilge?)
For anyone who hasn't (yet) built a stripper (and in case I'm the only one having issues); the problem I'm talking about usually happens between the Sassafras (darker brown) accent strip (the one with the 2 worm holes) and the center of the hull (see picture below).
As you can (hopefully) see, the strips in this area have to be bent outward across the strip's width to follow the hull's shape. This causes the strip to buckle a little and, therefore, produce the "oil can" effect.
The severity of this phenomenon has varied with each hull and, because I've been changing hull shape and wood species every time, it's pretty hard to compare which woods deflect more than others or which hulls are more (or less) prone to the condition (I'm assuming that it is a combination of hull shape, wood species, and material thickness and that varying any or all of these factors may exacerbate or mitigate it)
The reason for this lengthy explanation is that it didn't happen this time (AT ALL).
I had noticed very little of it while stripping but expected a couple of areas to "pop" when the staples were removed and the cumulative effect of bending the strips released the build-up pressures.
Nothing. The hull is sitting flat and didn't move at all.
Now I'm left to wonder if I just got lucky, finally did something right or if it's due to the Poplar being extremely forgiving (it seems to be) and the hull shape just makes this an easier-than-usual build. I guess I could build another using the White Pine (it oil-canned so badly on the Merlin build that I had to taper strips to relieve the pressures) or I could try the Poplar on one of the other forms.
Neither of those will happen this Spring, however and I'll be thankful that whatever is going on seems to be going my way.
It looks like the Poplar is going to level easily and I should have it sanded this coming week.
I've had that happen quite a few times...some strips will "buckle" or oil can out of plane between forms.
I stressed about it, and waited a few days while I tried to think of a solution.
Lo and behold, the problem fixed itself...The strain causing the buckling forced the wood grain to relax, sort of a low cycle fatigue.
Not saying your sassafras will yield the same as my western red cedar did, but maybe some time will help?
I've never thought about waiting it out (I tend to favor brute force over patience and action over pondering solutions). I've usually continued stripping and supported the low areas from underneath (which, in turn, brings down the high areas). What struck me as odd on this build was that I'd seen very little of it prior to pulling the staples and none upon removal (I was expecting at least some).
Certainly weird. I'm wondering if it's due to the Poplar or the hull shape (and reasonably sure that the answer to that is "yes")
Two things come to my mind. Humidity changes is the first, I tried to build a strip boat from basswood and I never got it glassed it was always moving around. Quarter sawn wood helps minimize the dimensional changes. The other thought is once the staples were removed some of the stresses were equalized. Have you looked under the hull?are the strips still contacting the forms?
That’s all I’ve got.
Well...
The strips contact the forms when I staple them but I don't staple them tightly against the form (I duct taped a piece of strip to the bottom of the stapler so the staple doesn't pull tight). This makes the staples easy to remove and also allows me to gently pull the strip away from the form (ever-so-slightly) when installing the next strip. By sliding the strip up the staple (when needed), it becomes very easy to keep the beads centered in the coves.
The end result of this is that, once the staples are removed, the hull is in very loose contact with the forms. I've slid strip discards between the form & the hull sometimes when glassing or sanding (especially if the hull is trying to oil can).
I've never seen anyone else's builds so I've always assumed this is normal but now you've got me wondering, Jim.
You're (and everyone else is too) forcing a curve into the strips in the off axis...the strip can't yield immediately, so it deflects orthogonally. The outer edge of the strip is in tension, and the inner edge in compression.
With small deflections, the wood fibers can slip by each other to some extent. Larger deflections may yield immediately, or maybe not. With time, more internal slippage can occur. Think about a plank that's been used for a long time as a ramp, it takes a semi permanent deformation.
The amount of that off axis buckling is a function of the wood species, it's condition, and the amount of deflection imposed.
But don't ask me to quantify any of that, I don't know enough about wood. Metals, sure, the basic principals are the same, but I'm not schooled in wood.
I found the Hogging effect, when I pressure fit the strip joints in the football.
I actually had to glue a block to the inside of one hull, to pull the hull into
shape. Once I glassed the outside ? It stayed.
After that I I removed enough of a strip, so I didn't have to force it into place.
I too use the canoe craft method of stripping the football.
That's been my experience as well, Jim. Support wherever & however necessary to keep it true until the outside is glassed and, after that, it doesn't move.
I went over the hull with 120 & the long board tonight. A couple more passes on the bottom & I'll have to haul the jackstands upstairs so I can flip it and sand the shouldery, knuckle (dragging) areas. 😁
Has anyone ever skipped glassing the tumblehome on these hard-shouldered hulls until they're flipped over?
I've got the bottom sanded pretty well, and the jack stands are tied up downstairs doing jack stand things (holding up a race car for the next couple of weeks). I could go buy more but I hate to do that for all the more I'd use them (I'd buy 20 ton or so to get the wider footprint and likely pay $60-70 USD each)
It looks like the tumblehome area could be covered by a 4 inch tape so I'm thinking about glassing the bottom while getting as close to the buckle as I can but leaving the sanding / glassing the actual tumblehome area (probably the center 1/2-2/3 of the hull) untouched until I flip it over and start on the inside.
What do you think Coach(es)... worth a try?
The glass should stick to the hull. Glass it all at the same time.
Trim your cloth, to about 2" of the hull.
Should have no trouble glassing it.
I don't like to flip it until the exterior glass is on, there is a lot of movement with a bare hull.
Are you wanting to flip it for better access? I know I did think the same thing on my first hull, but found it was less work to just get started and sand it. For the tumblehome section power sanding isn't practical (at least for me) so it's an all hand portion of the hull.
I've never had a problem sanding or glassing it when everything is upside down. The knuckle area is flat so that makes it pretty easy to sand. I realize you're using wood that's harder than cedar so it might be more work.
Round over the outside corner and add a small filet to the inside corner and the glass should stick fine.
I'd be a little worried about that area potentially breaking or getting damaged when flipping the canoe if it wasn't glassed.
I was going to put the strongback on the jack stand- rotisserie set-up that I used when applying the Unicorn Spit to the Merlin
so I don't have to sand upside down (the uprights are high enough that the whole set-up can rotate 360 degrees).
If general consensus says the glass won't bunch up around that knuckle, I'll try it but, if I'm going to fight to keep the glass smooth & firmly attached, I'll roll the dice and try to do the tumblehome area separately once it's off the forms and I can work upright.
I’ll have to remember that setup. I’m guessing the strong back I’d the heaviest so it will alway want to rotated with the canoe upright.
