• Happy National Shrimp Day! 🦐🍤
Alan's Bloodvein II
I've only done a shouldered tumblehome once, but mine had a concave curve. Glass adhered to the outside just fine. It was the inside that got finicky.
Keep in mind: The exterior glass fibers are a major part of your structural strength. If you break them, you have a much weaker hull - or will need to add a significant amount of weight in overlaping the seam to compensate.
...I’m guessing the strong back is the heaviest so it will always want to rotate with the canoe upright.
Not on the Merlin build. The OSB forms & stripped hull were heavier than the plywood legs of the strongback (but not by much). The set-up rotated easily and I could rest the hull on a 5 gallon bucket to color the sides. Only issue was that I needed a helper to get it on the stands (we lifted one end at a time and one person stabilized it while the other positioned the other end on the stand. I'm in the process of reworking the stands to see if I can make that a one-man operation)
I think I'm going to try and wrap the glass upside down to do the whole exterior as one piece but have some 6 inch wide e-glass tape on hand. If the cloth starts to bunch up (there's an extra 1 1/2 strips on the tumblehome area compared to the bow & stern), I'll glass what I can cleanly, allow that epoxy to set overnight and then flip the hull, trim off the loose cloth and glass the knuckle with the tape the following day.
The flat top of the knuckle + the sheer is about 4 inches at the widest point so a 6 inch wide tape should give me 2 inches of overlap and Raka says that I have (I think) 72 hours to still get a chemical bond. I'll be using the tape to reinforce that area on the inside anyway but the sharper edge contour should provide extra strength as well. I think 2 inches of overlap will be sufficient but I've been wrong before.
I glassed my red kite with 6 oz glass and it was a breeze, easily conformed.
I used carbon cloth two layers at once for the carbon copy kite and I had great difficulty to get the carbon to fully conform around and over the crease.
With glass, no issue at all.
And a warning about using glass tape: it’s likely straight woven with finished edges. That tape will not conform to compound curves very well. Bias woven tape will, but it’s quite a bit more expensive and difficult to find.
For better or worse, I did something a little different tonight.
I'm training for a new job and I'd taken the Raven out of the rafters to do a "show & tell" at driving school (relax, I'm not teaching it). As often happens, someone mentioned that you can see daylight through the hull where the strips were not perfectly tight.
Like seeing the staple holes, I've always considered the slivers of light to be part of the process and they don't bother me in the least. However... I got to thinking that maybe I can do something about them.
Now, ideally, I'd tighten up my building process and get the strips fitting in perfect alignment but that seems like a lot of work and it's too late for this boat anyway so I was left with how to eliminate (or, at least minimize) the issue as I finished sanding.
First, I looked between the forms and applied masking tape to any cracks that I could see. I then grabbed the bucket of sawdust that I used to thicken epoxy on the last build (It's White Pine sawdust but, hopefully, the color difference won't be horrible) and sprinkled a little on & around the visible gaps
I then used the heel of my hand to pack the sawdust into the cracks and wiped away the excess.
If I had to patch an area on the sides, I just put a pinch of sawdust in the palm of my hand and packed it in
I then took the handle off of my broom and used the broom head to sweep the hull lightly and swept the floor of the shop since I was already holding the broom (I reinstalled the handle for the shop floor)
Next step was to trace my daughter's Trillium onto the bow and color it in lightly with pencil (I mean, why not, right?)
Finally, I checked my cloth supply and found that I have just enough 4 oz, 50 inch wide e-glass to cover the hull and the 50 inch will just barely cover at the widest part. I also have a ton of 30 inch wide, 4 oz e-glass which I'll use on the inside but I think I'll just do a single layer on the exterior and then 2 layers inside to improve impact resistance.
I rolled the cloth over the hull, smoothed out all the wrinkles with a clean paint brush and that's where we are this evening.
Between now and Wed I've got a driver's test to pass and my taxes to do.
Assuming that I'm successful at both, I'm hoping to celebrate by encasing this in epoxy on Thursday.
Looking great. Can't wait to see it glassed.
I use thickened epoxy to fill any gaps, usually after the 2nd pass of rough sanding. I used to spot fill the gaps but the last couple times I just started putting a skim coat to the entire hull (doesn't take much time or epoxy). I use a squeegee to spread it and force it into the cracks and then use hard pressure with the squeegee to remove any excess that's on the surface of the hull.
The rest of the sanding proceeds as normal and it all but eliminates any epoxy leaking through to the inside during glassing, which makes sanding the inside that much easier.
The only issue I can see with sawdust packing, is it will shrink when the epoxy soaks in.
I have an alternative method that is pretty easy.
1. put a strip of masking tape to either side of the area to fill, usually done day before I am glassing
2. make up a small batch of epoxy and wetout the marked areas lightly
3. Thicken the epoxy and apply at taped areas (usually small putty knife), pushing into the area to be filled
4. use the putty knife to remove any excess
5. pull up the tape and start the glass process
Doing the filling just before you start, means the filled area and the new epoxy/glass application just sort of blend together and disappear with no sanding or attention. Using the tape and putty knife means that when you scrape the area, there is just the right amount raised above the rest to help it blend into the surrounding area.
I use wood glue, instead of epoxy. no need for epoxy, and the wait time involved.
You are just filling a hole, not a structural situation.
The main reason for using epoxy Jim, is simply to let it blend and bond in a continuous operation, glue would have to be left to dry and possibly be sanded, but using epoxy for cracks skips all of that .... just push the glass on as usual and it all disappears into the process
I like the different methods & maybe I'll try one of them next time (I've been thinking about doing a quick seal coat the night before anyway).
One question, if I'm using thickened glue or epoxy:
Although I've continued to sand with the longboard, I usually have a few low spots where I give up and just feather them in instead of taking the entire hull down those last few 1/1000s. Wouldn't the thickened filler hide the wood grain in those areas and make them more obvious? I mean, I'm getting better with each boat but there WAS a lot of room to improve from the 1st and quite a bit of that remains.
I've never seen that to be the case. Usually, since the filler is being scraped back off aggressively with a flexible squeegee, it doesn't really fill those low spots in anyway. If you were using it as a fairing compound then, yes, it might look a little funny where it filled in those low spots.
My concern with wet epoxy is when you lay out the dry cloth, it might snag the cloth and distort the weave.
I guess it would also depend on how many spots you were filling, and where the spots were.
Like Alan, I fill voids before the final sand, and then I'm ready for cloth.
Fact is, I just filled a knot today with wood glue and saw dust.
No hassle mixing epoxy, to the right ratio, and then having left overs.
Wood glue is soo easy.
Worked great.
You make a good point Jim and I agree that the quantity of holes and likely the size will impact the decision on how to do the fill. I have done both and it is mostly just that, a judgement call when you reach that point.
For a few small spots, it can also be a question of time ... if I am ready to glass and I have a couple of defects to fill, I may not want to put off the glassing, to prep and do glue fill/dry/sand. Mixing a small batch of epoxy and doing the layup with a "wet" patch is going to be less work overall and the results are great, no sanding, no dry time. However, it is best used when there a few, smaller defects .. then it doesn't really impact laying the glass down.
I may fill the next (I doubt that I'll pull the cloth off of this one) and my decision may come down to timing. If I can epoxy it within 72 hours: epoxy, sand and glass. If not: glue, sand & glass.
As mentioned, It's not structural (which is why the visible slivers of light don't bother me at all) so filling IMO is simply so that I don't have to hear "I can see through it" when showing it to others.
Honestly, I'd love to find a way to adhere the glass to plexiglass strips or something similar and make a clear canoe. Then you'd be able to see thru it while it's on the water too.
make a clear canoe
All you need is a giant oven!
There are a few companies thermoforming Lexan polycarbonate into transparent recreational sit-on-top kayaks and sups. Polycarbonate is the material used for aircraft windshields, safety glazing, etc. The process is akin to how Royalex canoes used to be manufactured.
They may float but they look pretty awful to paddle.
I don’t think we’re the intended audience for whatever those things are. But hey Gamma, at least the bar is set pretty low for a clear canoe.
I was thinking of something like this:
Only 1mm thick though, so I'll need to epoxy 5 (almost transparent) strips together and then do the bead & cove...
Maybe someday but not this weekend. I didn't get it glassed today but I did manage an hour or so tonight. I trimmed the glass to an inch or so from the edge
And rolled fresh paper on the floor and strongback. I've got some Sassafras, Cherry and Poplar (that's destined to be gunwales) leaning against the legs of the strongback so I rolled another length of paper instead of moving them. Lazy, I know, but it seems like it'll work.
Hopefully, I'll slather it with epoxy tomorrow but I'll be a bit upset if I can't find time to get it done before Monday.
Today was glassing day and I made one addition before wetting out the cloth. I wasn't going to mention it in this thread but I'd swear that I saw Sadie's TR as a featured thread this morning and, as I was epoxying, I decided that I won't just discreetly include a picture and wait to see if Alan notices...
Alan's original included his logo featuring Sadie paddling bow (a sticker made by his mom IIRC. If I'm wrong, I'll blame old(ish) age)
Now, I have neither a sticker nor a Mom who is able to create such a sticker but that's OK. I don't like stickers on my hulls anyway.
I've always credited the designer (if I know who they are) on the stern float tank but by donating the plans, it seemed that Alan may be entitled to more than the usual recognition and pencil may be even more appropriate lately given this:
You can redeem them at the prize counter. You have enough for a pencil. :)
Bottom line: I used a little poetic license (doing verbiage upside down wasn't gonna happen and I liked the logo shaded instead of solid black) and drew on the stern opposite the Trillium
That done, it was time to start mixing epoxy.
I cut the glass at the bow & stern so that they wrap around as a double layer and I also put an additional layer of glass over those so that I have 3 layers of glass where some have stems. Today, I ran those strips a little further down the hull so that I have 2 layers in the high wear areas (both 4 oz e-glass so I like the idea of a little extra protection)
It wet out nicely and I really like the color combo (the pictures make it look a lot like the Aspen that I used on my Freedom Solo but, in reality, it's got far less yellow and, of course, some purple. This close-up shows the color fairly true)
It does occur to me now that I should have flipped the logo so Sadie was facing forward... I guess Alan must have had his on the left (oops- too late now, under the glass is permanent IMO)
2 fill coats later, I think I have the weave buried. I'll head over tomorrow, scrape off the loose threads and I'll be able to start the inside next week.
...Super impressed you can draw that well period, let alone upside down!
I can't take credit where it's not due. While my daughters are both capable of such artistry, I am best suited to following the path of least resistance and cheating wherever I can. 😁
For anyone wanting to try this at home: I downloaded the 1st picture in the last post, zoomed it until the size seemed appropriate to the Trillium that my daughter had drawn for the first boat, laid tracing paper on my laptop screen, traced it in pencil, then laid that tracing on carbon paper to transfer to the hull. I went over the lines in pencil to darken them, shaded in the middle and voila... trademark infringement.
I tried the verbiage (on tablet paper) and couldn't get it to transfer cleanly so I didn't try it on the wood. If I do another, I'll take the carbon paper off, flip the tracing paper over and trace from the other side. That'll get Sadie pointed forward (seems like a more natural orientation for her given her TR and Alan's).
Confession over & I'll do penance as assigned if I must (ok, maybe not lol)
Anyway, I spent the morning under horses & then stopped by the boat shop. I took a scraper to any runs and loose threads (there are always some on the "stem" areas and any place that extra glass is laid over the full layer). They clean up really well if you get to them the next day.
You may notice that I ground the edges of the scraper to round them off... this was to keep it from digging in where it isn't supposed to and really helps when doing the inside glass (but doesn't hurt outside since I don't have to be careful with those sharp corners)
I did find a couple of places where the weave wasn't completely buried, so I mixed a small batch of epoxy and touched up those areas as well as the places I'd scraped.
At this point, I'm really eager to flip this thing and see how much purple will show on the inside. I'm very pleased with the way it looks from this angle... enough to add color without overdoing it...
I'll have to get some purple paracord for the seat.
