• Happy National Dessert Day! 🍰🍦🍪
Questions and requests for advice as I'm starting out
Central Wisconsin
Hello all. I'm new around here, but have been trying to catch up on reading some of the wonderful builds folks have and are doing. This will be my first build. But the idea of building a cedar strip canoe is something I've been thinking about off and on since I first read Canoecraft about 30 years ago. Over the last 5-10 years I've watched a lot of Nick Schade's Youtube videos, as well as others, and read several build articles and forum posts online. So I have some background, but there is only so much you can learn without getting your hands dirty. While I'm excited to get going on building this canoe, I'm also hoping it will not be my last, but we will see how this first one goes first.
I'm looking at building a 15-16' solo. I've bought both the plans for a Northwest Passage Solo, and a Kite. The digital Solo plans were very inexpensive, but did not have much detail, so I thought I'd get the Kite ones as well, to get some of the extra details from that, even if I don't build it. I know the Kite may not be an ideal first canoe, but it is just so sexy, I thought it was at least worth looking into. The physical plans for that are supposed to arrive tomorrow. I plan to use this on both inland lakes and non whitewater rivers. I actually live on a smaller river, that I would love to take it down at some point. Both these designs seem to be decent all around'rs for these tasks, but would take feedback if others know differently.
As of now I'm thinking about trying to go stapleless, with 3/16" white cedar beed and cove strips I'll mill up my self. I do have a decent source of that locally, but he typically only has 8' lengths, and as we all know finding CVG will be difficult as well. Picking out the wood is something I plan to do tomorrow. Looks like a lot of scarfing will be in my future. And of course I will be staggering those joints as well. When using that much shorter wood, does it make sense to try and pastern the scarf joints, or try and make them look more random? I also am planing on using at least an outer stem (still debating on inner), I'm not looking for super light weight, and I figure in the river I could use the extra ding protection. Also looks like it might be easier to hide some of the sins on a first build.
So far I have my strongback itself a good way along, and will start working on forms when I decide on a design. I used some leftover 3/4" ply I had to build a two part 16" one. Since I'm going stapleless, I guess the form material shouldn't matter as much, so will probably go with 1/2 construction plywood from menards, unless others think I should upgrade a bit. I also had just done an amazon order of a bunch of parts to build Jimmy clamps, but I think I may have screwed up the size of one thing or the other. The inner tubes I got seem way wider (about 1 5/8" wide) than the spring clamps (about 1 1/8" wide), So not sure how that is going to work out. I also ordered a bunch of small C clamps to possibly use the strip hold down method I've seen Nick S. use in his videos with a chunk of a hook shaped piece of wood clamped to the form. And for good measure I even bought some bungee materiel to possibly try that method as well. PXL_20260227_212313936.jpgPXL_20260227_212401708.jpgPXL_20260227_213616272.jpg
The one section of outer strong back box is not screwed down to the other yet, so not fully level, but will be. I'm also probably going to increase the height of the saw horses, but they were at this height, so I put it on there. Actually that is another good question, what is a good height for the top of the strongback?
Thanks in advance for any suggestions and help. I'm really looking forward to getting going on this, but also a bit nervous as well.
Strongback looks like it'll be solid. You may need to temporarily brace it level when screwing it together.
The most time-urgent, since it might affect your wood shopping tomorrow:
  • It might be un-intuitive, but you usually don't want vertical grain planks for your strip stock. (Assuming 1x nominal stock, which is what most of us start with.) Instead, you want the flattest flatsawn available. Then, when you rip your strips out of the plank, the strips will have vertical grain. Draw out the annular rings on the end of a plank if you need to visualize it.
  • Are you thinking of scarfing in the plank before ripping your strips? If so, you'll lose about 9" of length to the scarf. What does your supplier mean by 8'? Is it "Exactly 96 inches" or is it "8-ish, probably a little bit over"? If the first, scarfing them will leave you with 15'3", which might be just enough to run full-length for a 15' canoe. No extra space here. If you intend to scarf/joint per-strip: you won't loose near as much, since the scarf will run the other way.
  • If you can't get 100% clear stock, you will end up breaking the strips at semi-random lengths. Not necessarily an issue, it just affects whether trying for matching/patterning joints is at all practical.
Other stuff:
  • Staple-less construction: If you haven't found it already, you might want to look at how @gfraizer13 handled the forms over on this build thread. I think it was brilliant.
  • Form materials: Are you intending multiple builds on the same forms? If not, go for what is most cost-effective for you. Would not recommend any utility plywood less than 3/8". One of the advantages of the MDF that I often see used is that it stays flat. Most utility plywoods tend to warp or bow a bit, and may need some flattening cleats.
  • Work height: I like the section that I'm working on to be just a few inches lower than chest height. That strongback will be able to take some moving about, so there's no reason not to lift or lower the build as you progress. If I had to leave it all at one height, I'd suggest that the bottom of the canoe be around 48" from the ground, give or take. YMMV.
Other stuff:
Thank you for the quick response and good points.
I did misspeak and meant just clear grain, not clear vertical grain. I've been to the fellow I'm buying from's yard once before. He mills, and kiln drys a wide variety of material, and I bought some maple and walnut when I was there last. But just looked at the cedar. I'm assuming like you it is a bit long, but not absolutely sure, will check tomorrow. I remember thinking to get the lumber as knot free as I could get, i would probably need to go with some wider boards, and than not strip all of it. While gluing up and scarfing before stripping sounds like something that would save time, I was worried both about the waste, and the joint holding up at that point. I have a bit more confidence in getting good glue coverage on the individual strips, or am I mistaken on that? I believe both of these designs would take about 50 or so board ft, but I plan to buy extra.
I believe I had seen that build before, but thank you for bringing it up again, it is an interesting technique that I don't know if I fully understood the first time I saw it. I get it more now.
I also appreciate the reality check on the form material. I was already planning on using 1/2" at minimum material. And I wasn't thrilled with how much MDF was going for a sheet. And I could have sworn my local Menards was out of particle board at the time I looked a few months ago. But checking today they have plenty of both 1/2" and 5/8" so I think I might go with that instead. I believe 2 sheets should be enough even if doing the extra edge technique. I don't have plans to make another of the same right now, and I think I may not even be supposed to of the Kite, without buying new plans, but they also don't take up much room to store. The strongback on the other hand, I could see being used on other builds, so I did intentionally build it fairly strong, but also so I could split it in 1/2. And the plan was to brace it while screwing it down, but thank you for the reminder on that as well. And like you said, it should be able to handle some shifting even with the canoe and forms on it. I may have a way of doing that fairly easily, at least at the start. May go down to the saw horses when I get to the bottom.
I think it's important to remember that lots of people build cedar strip canoes and, assuming they actually finish what they started, they always seem to turn out fine. Not making mistakes certainly makes it easier but it's pretty hard to mess it up to the point it can't be fixed.
And there are many ways to skin this cat. I remember being frustrated with my first build because I just wanted a step by step "do this and do that" but it seemed like everyone had a slightly different way of doing each step and it was so hard decided which method to use. Eventually I realized they all work and quit sweating it as much.
If you plan on this being your only cedar strip canoe and you tend to be a perfectionist then knock yourself out and make it as pretty as you want. Just realize it's going to take a lot longer. A lot of people are fine with that. Some people enjoy the process just as much or more than the paddling.
If you think you're going to build more of these, or if you're not that much of a perfectionist, I recommend using staples and knocking out a basic cedar strip without getting bogged down in the details. This will make you familiar with every step of the process and will make it easier on your subsequent builds to shoot for high quality because you'll know what areas to focus on and which aren't that important.
Have fun!
Alan is right about the tradeoff between "perfect" and "good enough". Don't let the former be the enemy of the later, but only you can decide where that line is for your build(s).
I have done the "Scarf each strip as I go" method. Once. I had a little jig to sand the scarfs on a disk sander, and scarfed each one as I was ready to lay it. I found it fussy, messy, time-consuming, and in the end the joints didn't look all that great. (Think about what happens when you round off the outside of the strips when fairing it before glass. Each of those knife-edge joints sands back in an irregular parabolic curve.)
All for a stronger joint that doesn't matter:
The structural strength here isn't actually relevant to any real degree. I've said it before, but I will repeat here: The core of a strip canoe is not really structural. It needs to have some compressive/crush strength to keep the two glass panels properly separated, but beyond that it could be balsa, or even styrofoam for all its strength matters. (indeed, there are some builders here that have built more advanced composite canoes that do use foam to separate the composite layers when they need more stiffness without much weight.) All it really needs to do is look pretty, and hold together until we get the glass applied.
What I, and many other builders, have done is to simply butt-joint the strips. This means make sure that the end has a nice, clean, straight cut, and just butt it up to the previous strip. You can clamp a scrap of strip stock behind the joint until the glue in the bead sets, but otherwise it's properly supported by the strips above and below.
Scarfing in the plank, before ripping your strip, is entirely about convenience and aesthetics:
  • You get the convenience of having full-length strips to lay in
  • You get a neat, crisp joint for relatively little effort. (Honestly, since this isn't really structural, you can get away with a shorter scarf here. 4:1 or 5:1 scarf will work fine, and look good.)
  • You have the inconvenience of needing to machine and handle full-length strips. These things are long, thin, and flexible. You know your shop layout, and your ability to arrange for infeed and outfeed support, both for your strip-ripping, whatever that might be, and for your router setup for the bead and cove.
I've never built with full-length strips and I scarf as I go with a simple miter box (45 degree scarfs). I lay both pieces in the box overlapping them, cut them both at the same time and then glue them on as you would laminate flooring: whatever is left over from the last strip becomes the beginning of the next strip. It assures a completely random pattern to the scarfs.
Personally, I wouldn't worry too much about finding clear lumber either since small knots are common to that wood species. As long as the knots are tight you'll be fine and you can always put a few drops of CA glue on the knots just to be sure they don't move when you cut the strips.
For station forms, I use 1/2 inch (or whatever it is now) OSB and haven't had issues. Building the strongback bulletproof is always a good idea.
I've found that Harbor Freight is a great source for cheap, decent spring clamps and any local bike shop will have used inner tubes. They'll probably give you far more than you want just for asking.
I'm not sure how high my strongback is but I can check tomorrow if you're really interested. I'd say the top is about mid-thigh. I have to bend over or kneel to place the sheer strips and I use a small (2 step) step ladder to close the football.
I agree with Alan: don't overthink the first. Relax, have fun with it and know that almost anything can be fixed. Besides, if you buy 50 board feet of Cedar, you'll probably have enough to build the second one anyway.
Looking forward to watching.
WRT scarf joints:
Whenever I have built with less than full length strips, I've simply used a butt joint positioned on a form. I stagger the joints randomly, and position them in a low stress location.
Small knots are fine as long as you can keep them intact until glassed, they add quite a bit of character...
As Alan mentioned upthread, there are few opportunities for failure, most errors can be quickly remedied along the way.
One potential problem area that is difficult to recover from is the laminating, this step often prevents folks from ever starting to build. If you're not familiar with glass and epoxy, best to do a test panel or two to gain experience and comfort.
The Kite is a beautiful hull, and more easily stripped than you might imagine. It's an excellent compromise, it performs well in many waters, but will not win any sprint races. I have both a stripped version, and a carbon copy version. I'm plenty pleased with the design.
The bulk of the strips I am using, on my current build, came from 3 x 8' white cedar boards I had on hand. Not wanting to face the 200 or so joints "on boat" assembly takes, I just skarfed them together to make a single board, long enough for full length strips. I skarf at 10:1, but my feeling is anything 5:1 or better is fine for this, as pointed out, it doesn't have to be structural.
I use the strongback as a base and the skill saw method to cut the strips ... again, cutting a long strip instead of shorter strips is easier (at least it feels that way).
If you preskarf the source wood, you will usually have extra length allowing you to slide the strips aft or forward to keep joints from aligning, another suggestion for that method is to "flip" every other strip, to keep wood variations scattered as well.
If you are going to use stapleless construction, a few things to keep in mind.
- Jimmi Clamps are the best IMO for strip clamping between forms
- whatever clamping solution you use at the forms, needs to respect the material being clamped. It is soft wood, white cedar especially so, spring clamps will dent, C clamps likely dent worse, unless you are very carefull.
- the shock cord with dowel to protect the strip cove is likely a better solution for holding to the form
If weight isn't a concern
- 1/4" strips are likely going to be easier to prepare and handle
- easier to get a B&C cutting set
- easier to handle when applying to hull
- more material when fairing and sanding, can keep you out of trouble on a first build
- yields a marginally stronger composite
Just a few thoughts
Cruiser
whatever scarfing method you use, a jig will make a world of difference- For scarfing to make long strips, you can make a simple jig that slides in the groove of your table saw; take a piece of plywood (2x2' handy panels are perfect), glue a piece of 1/4 masonite (HDM is great because it won't wear appropriately, I use thick laminate flooring strips) the size of your groove, and glue it on approximately an inch or so farther away than the distance between the guide and blade, and run it through the saw to square the guide to the blade, next glue some triangular pieces cut to the scarf angle you want on the surface at your trued-up edge and angled and spaced to your thickness and angle, if you leave them overhanging the edge a bit you can run it through the blade again to ensure a tight, consistent fit and stop any deflection in the piece from the pressure of the blade. you should be able to produce virtually identical scarf angles this way, allowing you to simply flip the pieces to opposing angles. This way lets you make long (2-3") scarfs that will be strong and consistent, but it wastes a lot of material (4-6" per scarf joint)
the other way (doing it as you go) is a little more complicated, but equally satisfying- Cut a block about double the height of the strip and a few inches long (enough for clamps), cut a groove in it the height of your strips and tight enough to hold them in place, but not so tight as to scuff the cedar when working on it, now cut a second groove perpendicular to the first at your desired angle (about 60° is the max) deep enough to easily see the whole joint and wide enough to slip one of those 2 sided emery boards used for fingernails between the pieces, you should end up with basically a lopsided X)- you simply slide one piece in (do not clamp to the last station) slide the emory board in place, but the new piece against them and sand away , using a bit of pressure on the new piece and trying to maintain the angle of the jig, it doesn't need to be a perfect fit because you'll be making the pieces match each other, so any variation on one will match the variation on the other. the main drawbacks of this method is all the hand sanding and you won't get that perfect, machined cut that prescarfing gives, getting the jig right can take a couple of attempts, and you end up with more of a mitered joint than a traditional scarf.
As long as your joints are well staggered there should be little difference in strength because the joints will be reinforced by both the strips around them and by the glass laminated over them.
Good luck and have fun! stripping can be tedious, but is well worth the reward if you take the time to line everything up properly
Thanks again all for the encouragement, suggestions, and answers. You have given me plenty to think about, and confirmed that this is the right place to ask these questions. I know I will have plenty more as I go along. And while I've done a tiny bit of fiber glassing before, it's been over 25 years, so I probably should practice a bit when it comes to that time.
I think I'll decide on scarfing the board vs strip once I get the wood, waiting to hear back from the seller to make sure he is around today. In the meantime I've been looking over some of the other posts around here. I've been planning on using TB3 for glue since it is something I have a decent amount on hand, and because my shop is still on the cooler side. I heat it in the winter, but only about to 45-50f. I didn't realize using TB3 was a bit controversial for this, I think I will still use it, but will keep an eye on how it is doing, and may change it up for the next build if I find it hard to work with. It's been working fine on some of the other projects I've been doing out in these temps, mainly building some cabinets. I will make sure the area I use to fiberglass is much warmer, but that is a ways away, so have time for the weather to change.
When both using the skill saw method for cutting strips, and routing the b&c how much PPE do you folks use? I was planning on dust mask, but I have a respirator I could use as well. And any particular filters you strongly recomend? I wasn't planning on needing the gas ones until working with epoxy.
Oh boy, at the risk of reprimand:
I'm probably not a great one to ask about PPE as my risk tolerance is higher than what is likely to be healthy. About the only PPE I wear during a build is latex gloves when handling liquid epoxy and a paper dust mask when sanding the dried epoxy for varnishing.
I understand that Cedar may be more toxic than most of the woods I've tried, so I might mask up if I ever get around to using Cedar or Cypress. (I've noticed that Catalpa makes a very fine, irritating dust when sanding it, so I'll probably mask up when I sand it 2 builds or so from now)
I'm not the best at PPE either but WRC will make my nose start to run and give me a cough almost immediate once I start cutting or sanding it so I always wear a respirator when cutting it. Mask might be fine but I have a respirator and it's more effective and I don't mind wearing it (especially in winter).
I will also use the respirator when working with a lot of resin, such as when wetting out the hull or putting on fill coats.
I just use whatever filters came with the mask. They seem to eliminate the epoxy odor so I just assume they're mostly doing their job.
I connect a shop vac when sanding and, despite WRC being an irritant to me, I can seemingly sand it all day with no mask or respirator as long as the vacuum is hooked up to the ROS. After using a vacuum connected to the sander I simply cannot imagine not having one.
I usually just let ppl do what they like, I comment on what I like to do ... but generally there are many ways to do stuff usually. In this case, I will interfere a bit ... all PVA glues (eg. TB III) have a chalk temperature, that is a point where the glue crystalizes instead of setting up. The joint will look pretty normal, but it has no real strength. The chalk temperature for TB III is ~47F , right in the middle of your operating temperature range, this is just not a good idea, personally I like to be about 5-6F warmer than the minimum specified by the glue.
One of the few products that will behave in your temperature range would be LePage Express Wood Glue, which is useable to 37F ... also if you go looking, go to the manufacturers site to get the chalk or min temperature, AI and store adverts routinely gets this very wrong.
I did a bit of a discussion on glue selection in my last build thread, it is at the end of this post, you may find something of use there
Just be careful with wood glues at lower temps, especially the higher solids ones like TB III
Dust from the NWC will definitely affect you more than most common midwest hardwoods per exposure, and the oils are a sensitizer on top of the dust/silica concerns. Dust-rated mask whenever you are generating sawdust. If you can do your bulk milling out of doors, you can probably reduce exposure, but cutting strips generates a lot of dust. If you're using a typical Tablesaw blade, you can figure around 1/3 of the plank will be sawdust by the time you're done, The proportion will probably be higher when going for thinner strips. You can reduce waste by using a 7 1/4" Skillsaw blade, even if you prefer to use the tablesaw for the actual cut setup. (The smaller blades will fit correctly in the arbor of a standard 10" saw.)
Not so much "controversial" as it's pretty widely understood that the bond strength and waterproofness are massive overkill for a strip build. Doesn't mean you can't use it, but most of its selling points are irrelevant. "I already have it" always has some weight, all other things being functional.
You may well already know this, but @Cruiser is right about the chalking temperatures. You want to keep the space warmer than 47 through the entire curing cycle - 24h for TBIII. If your TBIII has frozen in the bottle, it's done. Ditch it and buy new.
Cruiser's linked thread also mentioned the color of the glue, which I agree with: depending on the color of the cedar you buy, you might find that you use a different glue for better blending.
Due to my previous life as an apprentice trained toolmaker, I have always preferred a bandsaw for cutting strips. Set up is sometimes challenging, but a typical 1/2" 4 of 6 pitch hook tooth blade produces a kerf of roughly 1/32".
Understandably, others prefer the skilsaw method, perhaps due to space constraints, or lack of a bandsaw.
Again, so many ways to skin a cat...
Yep. In trying to cut Sassafras strips for my current build, the rough-cut edge was rough enough that I was getting thin spots. I took the plank to my woodworking buddy so we could true it on his joiner and he insisted that we could get perfect strips with his table saw. He then cut me a dozen or so strips that look like they'll work just fine.
One detriment that I noticed: The plank was too wide to use featherboards so it was a two-man operation. I held light pressure against the fence & kept it from riding up the blade while he fed it into the saw (the plank was about 14 inches wide and 12 feet long).
Not to derail a thread but I'm curious how you'd do it on a bandsaw. The table on mine is so tiny... I assume that you've built long infeed & outfeed tables?
Just like during the build: So many options and all of them work.
SG, the idea that a bandsaw saves wood needs to be quantified, with respect to your equipment IMO, if you are comparing to a standard 10" saw blade, it translates to quite a difference, but once you start going with something like a 7.5" thin kerf blade, those savings start shrinking.
I have a Rikon band saw and your point about the setup for strips is somewhat understated for most folks IMO. Setting the saw up for this type of cutting requires full infeed and outfeed tables and a lot of experience with the setup operation. Additionally, I suspect the cut quality will be rough enough that fixing that will eat up any width savings. Plus if the setup and operation isn't "spot on" you are not going to have the strips as uniform as you might want.
Another shortfall in using, is the speed ... the bandsaw is a very slow way to make strips,
While using a band saw is perfectly doable for making strips, it really is a poor choice in terms of ease and finished product quality. It will make a few extra strips from the wood you have, but that is the only advantage and there are quite a few disadvantages for this operation IMO.
Agree to disagree
Once set up with infeed and out feed rollers, a 6 pitch blade will cut strips as fast as I can push the plank through. Strips are uniform in thickness and have a nice enough finish to send directly to the shaper for bead and cove. It’s all in the set up of blade guides and rip fence.
I have pics somewhere but no videos. In the past I’ve used a table saw, radial arm saw and yes, a portable saw as well as a bandsaw. For me, well, you know my preference.
there are plenty of thin-kerf 10" blades on the market that are actually about 1/2 the thickness of a skilsaw blade, and give a much cleaner cut because they're generally used in fine woodworking, I even have a couple that are 3/64" and about 180TPI. the larger blades mean far les tearout, an important consideration with fibrous woods like WRC or EWC
