• Happy Birthday, Gene Kelly (1912-1996)! 📽️⭐🕺🏻☔
First Aid Kit Container - Soft vs. Hard
Nantucket, USA
How to you pack your first aid kit? I need a better version for a large group sized first aid kit. I want a small, cylindrical, hard container, with a wide opening, that isn't too heavy and contains 8-10 liters.
So I'm packing for a camping trip with my boys. I grabbed my ready-to-go first aid kit that I use for group canoe trips. It's pretty extensive and even contains a wilderness first aid manual, which also served as a guide for its contents. I keep the kit in a dry bag, specifically a sea-to-summit 13L Well, I just crammed it into a remaining void in my trunk, pushing it past a few hard edged containers, and BOOM, next thing I knew the entire car smelled like nail polish. Turns out I had crushed a vial of liquid bandage inside the kit and a major clean-up process ensued.
This is probably the third time I've had some liquid or cream inside the first aid kit explode or leak and foul other contents. Even today, I discovered that within another Ziplock bag therein, an oral painkiller leaked out of its container and stripped the printed label right off an adjacent tube of Lotrimin.
I don't like bulky, square pelican cases, because they don't pack easily into a canoe, or portage pack, but I can't keep using soft dry bags.
Maybe something like a CostCo-size canister/ container of pretzels? 8-10L seems like a lot of space, though. I’ve got one of those bigger adventure medical kits & have hardly ever needed even a kit that big. But better to have & not need…
I use a Nalgene Silo bottle (48 ounce) for my personal kit. Too small for what you're looking for but maybe they, or someone else, makes something similar but larger.
US Plastics is a fun place to look around:
This is the first thing I came across:
That would work but these days most of those food container stuff are much thinner than they were years ago. Along the same line I have a couple of containers that were originally used for supplements, the ones I have only have the weight of the contents but I would guess they are 3 - 4 liters, heavy duty plastic with better screw lids as they are intended to to keep the contents dry for an extended period.
Of course in my mind they are good because they can be free if you know anyone that uses that type of stuff.
They would not be of the quality of the US plastics or Nalgene containers but they don't cost $40 either and would do the job especially as you would be transporting in a dry bag anyway.
Not many dutch canoeist have none of these in their kit.
Pelicases (or copies) or ammoniniotn cases are also used. Personally I use a drybag of palm. I am mostly paddling with small adult groups in a very civilized surroundings on flatwater.
the first aid kit lives in a bigger drybag with a boothie bag, spare clothes and a number of other usefull items.
what I use is a waterproof (both inside and outside layers) padded cordura case where all the closed cell foam inserts can be removed and used as splint padding or soft splints, giving me a 3x24x1/2" stiff foam pad, 2 8x8 pads or splints , and an thinner folded 6x8 by 1/4" pad, as well as 4- 1/2 x 1-1/2x 8" finger or wrist splints.
all crushables are in those cheap soap containers while bandages etc. are in those foldable pocket packs some assorted bandages come in.
The lid has a vinyl pouch velcroed to it that can be removed and used as a self- sealing cover for penetrating chest wounds. It also has both a carry handle and d-rings to carry it or attach it to your pack, and has survived over a quarter century of abuse by both adults and teens on an almost weekly basis.
Unfortunately it's looking a little ragged and is more pink than red after all that time, and the manufacturer's tag is long gone...
Edit- this kit looks like it may be the one, but it doesn't mention if the padding is removeable or if the kit is waterproof- https://sja.ca/en/product/home-play-kit?v=2686
