- Joined
- Mar 20, 2013
- Messages
- 3,356
- Reaction score
- 978
Nice work!!
The biggest issue lately is either putting too much or too little epoxy on, then either sanding too little or too much afterwards. I seem to be going back and forth.
I was disappointed to learn that I should wait at least 6 or 7 days before varnishing. I plan to get this thing in the water by June 15th, come hell or high water!
Scuppers add more weight, but come in handy. Now I'm torn between scuppers or not on Nokomis.
OK then. I've put the canoe on top of my car and am heading up the valley to Daley Lake to put it in the water. I stayed up late last night and put a coat of Watco on the gunwales, so they should be a little protected. Wish me well!
Mark
I love the looks ! Especially without scuppers. Your ends turned out great !
Here's a current issue I have that I thought I should ask everyone about while the epoxy is still green and before I bring this thread up to date. I have finished what I think is my final fill coat and I end up with these little holes or divots in the expoxy all over the hull. They are as if somebody went around and poked a pushpin in everywhere. Some areas of the hull have fewer or none of these and other areas have more. I noticed them on the prior fill coat and thought they would fill, and some may have, but they seem to persist anyway. Have you seen this before? Do you have an idea what's going on? I think I'm ready to sand but I'm not sure if I need to put another coat on prior to that. It seems I've got plenty of expoxy on the hull at this point, maybe too much already with the exception of a few small patches. The temperature in the shop was in the low 70's yesterday and didn't really fluctuate during the application. Will the varnish coat ultimately fill these in after sanding? Any words of wisdom? Thanks, Mark
Wow, I could have written that! My Kite surprised me with the initial stability, secondary is pretty darn good too! Maneuverable for sure, hull speed is easily reached but not easily exceeded. You sure have a nice background in the photos!
And I'm sure the grocery store crowd didn't even notice any finish variances, they were eyeballing the hull shape and wood color and grain...
Back to the bubble issue. I can't remember if this was mentioned or not but the last thing I do after rolling on epoxy is to tip it out with a foam brush. There are always lots of bubbles in the finish until that final step. I think a bristle brush would do a nicer job but I don't trust myself to clean it out every time so I use the disposable foam ones instead.
Looks like you have plenty of freeboard, and the seat location, looks right.
OK. Now get some varnish on it !
I would love for others to take a photo of some epoxy in a cup just prior to using, after mixing. Even with my final patching I am still getting quite a few bubbles in the mix. I'm trying to keep the agitation down as much as possible, so I don't know what's going on.
