Questions and requests for advice as I'm starting out
Well, the last strip is in. And it felt good to get it there. Took a lot of finessing to get those last few strips in, and having to start over on a strip because it ended up just a tad to short. But was worth it. I had intended to glue up those last few up as one and then put it in, but it worked out better to just do them one at a time. Including that last really small one. I did wait to glue the last 3 in until I had them all fit. I used some brad nails not pounded all the way in to hold the last two boards in until I could get that last little strip test fit. And than used the same holes to hold the boards in place for glue up as well. Along with a couple of bungee cords. And of course as tradition dictates, I had to have a glass of whiskey once that whiskey strip was in. I figured I deserved it. The whiskey is aged and bottled at a local brewery I love, but is distilled in KY (they won't say by whom). But I also thought the name seemed appropriate.
Now it is on to fairing things out, sanding, patching the holes, and getting ready for fiberglass and epoxy. I just ordered that stuff yesterday, and should be here by the end of the week. I was originally thinking of going system 3 for epoxy and filler, but ended up going with total boat to save a decent amount of money. I hope it works out in the end. I ordered 42' of 50" 6oz e glass. Should be enough for the full 15' boat plus some. I know I have a lot of work left to do, but hitting this milestone felt like a big one for me. Unless I hit some major road blocks, I'd like to have this on the water in about a month or so. But I'm also not putting any pressure on myself to do it in a set amount of time, it takes what it takes.
Been a while. I've made progress, but not as quickly as I had hoped. Oh well. The chance of it seeing water this season, here in WI is getting slimmer, but still a possibility. More likely if I put it in before 100% completion.
Things I've done since getting it fully stripped. I've sanded and scraped it down, and made it as fair as I could. I than went in and patched some holes with thickened epoxy. While doing that, I realized it was darkening just those areas, and I might as well do a sealer/ fairing thin coat of epoxy as well, so did that. Sanded and scraped it down. Added the fillet of thickened epoxy to the tight bend near the top of canoe, sanded (actually mostly scraped) it to profile. And this whole time stayed fairly nervous about actually fiber glassing, so took my time, and just sat on it for a while. Also had some other non canoe things that took up a few weeks worth of time.
So on Monday I finally bit the bullet, and laid the fiberglass. And while it didn't go perfect, it went well enough, and I'm happy with that. I was working by myself, and from when I started mixing the first batch, to when I finished scraping off the excess of that first coat, took me almost 2 hours. I now know why people say to get help with this part. I could say it cutting that in about 1/2 with someone mixing full time. Waited about 2 hours (this was with Total boat and a medium hardener). It was warm, almost 80F, but higher humidity than I would have liked close to 70%. Than applied the first fill coat. This only took about 1/2 an hour, and two batches of epoxy. The first took about 8 batches. Waited another 2 hours, and did a final fill coat that also took about 1/2 an hour, and about 1 1/2 batches of epoxy. My batch size was about 10 pumps of each. It hardened over night, and I've been letting it cure for the last few days.
Things I've noticed. The stem's need some work. I left each about an inch to 1.5" stick out past the stem, cut the fiberglass to the canoe at the tip, and folded one end under the fiberglass on the other, and than left the other 1/2 run long. But it left a little air gap between the layers near the tip that I did not notice. I also after things hardened realized that there are still a few places I can still feel the texture of the glass, through the epoxy, most of the canoe is glass smooth. These locations are mostly near the lip where it was harder to get the epoxy to not drip off as much. I'm not sure If I need to put another fill coat on these areas before sanding, or If I can sand first and than see?
Also have another process question. I know sanding is next, and than eventually varnishing. Do folks usually varnish the bottom while it is still on the forms and before glassing the inside? or wait until the very end and do it at that point? I'm also looking at Epifines for varnish and thinner, if that matters. And now the pics.
Thanks again for all the help and inspiration.
Looking great! Some people varnish the exterior before removing it from the forms but I never have patience for that. I flip it the day after full coats and let the resin fully cure while I work on the inside
Ha, I hadn't even considered flipping before fully curing, or sanding. But it does make sense, especially if making for others. Since it has been 3 days. I may get out today and see how it sands. But might wait a day as well. It has been humid, and I know that can effect cure time. TB medium says 3-5 days for full cure.
Lookin' good.
...on Monday I finally bit the bullet, and laid the fiberglass. And while it didn't go perfect, it went well enough, and I'm happy with that...
IME, that's the best way- "just do it"
As for varnish, that varies for me. I'm under the impression that the epoxy should harden a few (like 5ish) days before varnishing so, if I'm into other things, I'll let it sit & then sand and (sometimes) varnish before flipping. If I'm reasonably free and pushing ahead, I'll flip right away & start sanding the inside.
I"ve even paddled all summer (this summer in fact) before varnishing.
I'm curious about your stems... did you wrap the glass around from either side or pull both sides in & epoxy them together with intention to cut off while green? (If the latter, you probably want to add an extra layer on there for strength & waterproofing)
I did a poor job describing that area. What I intended to do (and mostly did) was leave a few inches off the front and back of the stems, put a slit in the fiberglass up to the boat at the peak, creating two flaps. Than overlap those so that there was a double layer of glass across each stem. What happened was after I got the one layer folded under the other, the one on top wouldn't hold down to the other surface tight enough and would float away from the boat. So I let it just hang out and trimmed it. So the stem still has one layer overlapping it, and one side of the stem has two layers on it.
Since I'm planning on going stemless, I agree that I should consider putting on a second layer. In fact I wasn't 100% thrilled with how my wood work came out at the stems, and had considered covering them with something opaque anyway. But I currently don't have anything.
Below is a picture of how it stands now. You can sort of see the little bit of a bubble at the top, and how i trimmed off the excess from one side of the fiberglass. You can also see why I wasn't thrilled with my trimming ability of all the ceder strips, and had to use filler to make it smooth, hence why I was considering covering it.
You do you but bear in mind that someone will have to have their nose within a foot of your bow to get the view that you show in your last picture.
If they're THAT close, they'd better be inspecting for purchase while holding a fat roll of cash or asking questions about your process in anticipation of their own build. (at least, IMO)
It looks pretty good for a first try & you can still clean it up. Remember that the glass will conform to the curves better on a bias, that you can layer smaller pieces on the tight areas and that you can stretch the cloth a little (deforming the weave) when needed.
For the future: You'll get a cleaner cut by leaving alternating strips run past the stem & then trimming flush when done (even then it doesn't turn out perfectly)
when you glass the stems, I find it's always best to cut the glass on the bias (45° to the weave). yes it wastes more cloth but it'll lay better because the fabric bends tighter by effectively cutting the radius in half, plus the individual strands are about 1-1/3 the length of doing a strip cut perpendicular to the edge, giving you more length to bond on either side.
Cutting it on the bias also lets it conform to the curves better because you can stretch the fabric to shape, opening or closing the weave to follow the contours. The excess glass goes in my patch kit to be used in future repairs
As for the filler on the stems- a fairly simple fix is to add some carbon black or graphite to your epoxy and darken or completely blacken the stem strips, or just ignore it as the extra glass and epoxy will tend to blur the transparency a fair bit, enough that you won't notice unless you're one of those who run waters that make you habitually kiss the caps in thanks...
Update. A few weeks ago I did both put in a strip of bias cut fiberglass on both stems, and gave the whole outside another 2 fill coats. The first went on supper slow, and used a lot of epoxy, the second went on light like I expected. Let it harden, and started resanding. I now have the canoe very well faired at 60 grit with the long block sander, and 120 grit ROS. And I've got one side done at 240 with the ROS. It is feeling and looking great. Except I have some of the same problem I had before. The fiberglass was high (or more likely the wood underneath was a bit high) in some locations. And to get everything fair, and get rid of the low spots, I've gotten down to the fiberglass. I really don't want to do any more full fill coats for weight and waste of epoxy, and honestly I think I would end up with the same issue even if I did, since these areas are always going to be a bit high. First off, how big an issue is this, or am I overreacting? Is this going to cause failure, or leakage? I had put a coat of epoxy on the wood below the fiberglass. Is there a way to spot deal with this before varnishing? Will the Varnish help protect that exposed fiberglass? I have a few example photos. They are from before final sanding.
I think most of us get a few of those and we just varnish over them as long as you didn't go through the cloth.
just go ahead and varnish, it isn't a big deal, you aren't actually in the fiberglass yet from the photos, just near the surface. Visually the varnish will make that all disappear IMO.
If you do another boat, realize that FG is the very last step ... getting the boat faired is done before you glass, after glassing it is just making it shiny and dull, you cannot easily do any level adjustments or corrections at this stage. It is pretty much the same for any finishing work, if you don't get the flattening and sanding done before finishing, you can't do it at the finishing stage.
Thanks for easing my worry guys. And yes, I realize now that what I thought was faired before glassing, was not as well as I thought. I did think of this very much as a learning experience. One I very well may repeat in the future. And if I do so, there are things I now know I don't have to worry about as much, and things I need to concentrate on more.
It is, indeed, a learning process, but you're doing great and asking questions when you're unsure is the best move (IMO).
I'll echo the above; you can just varnish & it'll be fine. Just be careful when re-varnishing in a few years (if you want to remove deeper scratches) and try to remember to go gently in those areas.
PS: I don't sand anything finer than 120 grit but that's me.
WOW ! I can't believe I missed this build thread ! I must have been in deep Left field.
Haven't read through the posts
Your last pic shows an area that needs a patch a small one at that.
Water will enter there and rot the wood in short order.
Second, the weave patterns you see, will disappear with the aid of varnish.
You have learned a lot about the build process ! Your next will benefit greatly from it !
On the side ? You have learned much about yourself ! You now know you Can do it !
I'll try and follow along !
Jim, if you are looking at the open spot on that last pic, it seems to be under the cloth. Maybe an area that didn't get filled prior to glassing.
John, you may want to check that area to be sure it is cover with glass and not open to the strips.
I did check the areas mentioned, and any others I saw, and I think I'm good. I've since finished sanding everything to 220. Washed with dish soap and water, rinsed that with clean water. Wiped with a tack cloth. And applied my first coat of Varnish. I'm using Epifanes Clear varnish and thinner. In a 1:1 mix for the first coat. It took way less than I was thinking, so I capped the remainder, and will add a bit more varnish to it before applying the 2nd coat tomorrow, after a light sanding of course. I brushed it on, and tipped it with the brush as well, but it looked fairly clean, even after the first. Not many runs that I saw. Hopefully I don't notice more as it drys. It's not perfect, but I'm very happy with how it is turning out so far. The pics are just after applying that first coat. 1791398524495.png
