Make a Lamoille lighter
Finland
Hi, I am new in this forum, but I like to ask some advices to my next project. But first something about me (as I think that this site administarator like to know who we are), I am around 50 years old man from southern Finland and I begin canoeing in 1989. Today I have three canoes in my shed, Mad River Lamoille GF, Northstar Northwind 17 in Blacklite with E6 trim and Wenonah Minnesota II kevlar ultralight. I paddle with my wife and we dont like that Northwind at all, Minnesota II is very good until average wind is more than 8metres/second (15m/s in gusts). Mad River is our favourite, but its heavy. I think it weights around 85 pounds. But the glide of Lamoille is so good and its so stable that its best canoe what we have paddled. Some years ago I have Jensen 18, which is my alltime favourite, but my wife didnt like at all.
My plan is make lighter copy of our Lamoille. I will make only one copy, so using male mold is way to go. I like to make it full carbon, usually canoe manufacturers don't use carbon fiber only, but I am going to make it using carbon only. Is there some problems to use only carbon fibers??
My plan is put 2x245 (9oz) gram twill over existing hull, and use epoxy resin. I don't remove trim, I like to get two corner to the edge to get copy little bit stiffer, from that first phase. Later I will make L-shape gunwales, which increase height around half inch, so copy wont be lower than original Lamoille. After first phase my plan is put 10mm (4/10 inch) insert of foam to diamond and ribs and put third layer on 9 ounce carbon twill as a inner layer. Should I put reinforcements to keel line or near gunwales? I can get 11 inch wide 200g/m2 carbon fabric in good price, so I am thinking that is it good idea to put one layer to keel line and in both sides?? At least in the edges, it makes first phase copy much stiffer and it might be easier to get copy straight, before I add corematerial to it. These reinforcements with epoxy increase weight around 5-6 pounds.
In Finland we may have different foams avalaible than you have in USA, put my plan is use this as a core : https://kevytrakentajanverkkokauppa...80-10-mm-flat-10x1005x610-mm-4969?category=59 Is this stiff enouht to make canoe strong??
I have already a made 0,5 square meter partial test copy of first phase, and I put 2x245g fabric and around 280 grams of resing. I use peel ply, so I can squeeze some resin out of laminate.
I have some backround to make carbon infusion skisleds, but I dont dare to make canoe by infusion, and I dont want make a split mold of Lamoille. Its really too much work for one canoe. Of course, using infusion, canoe would be very light, maybe around 30 pounds, but my guess is that third copy would be the first without problems. And it every copy cost around 1200 euros for me.
Sorry for my quite bad english, this forum seems to be best place to get advices, so I make this post, even its possible that my english is too terrible :) ...
Your English is very good. It's easy to understand what you're saying.
This sounds like a fun project. It's good you already have experience working with composites.
I've made a couple composite canoes, one of them with a foam core, and while they've all turned out OK I've been a little disappointed in the weight of all of them. My personal experience is that without infusion or vacuum bagging that carbon and Kevlar suck up a lot of resin and that tends to offset the supposed weight savings.
That doesn't mean you shouldn't go forward with your project but if I was doing another one with a foam core I'd be inclined to use more fiberglass and less carbon and Kevlar.
Good luck and welcome to the forum.
Thanks Alan, for me you message means that I should make a female mold :) . Actually I have 10 kg vinylester tooling gelcoat and 20 kg vinylester tooling resin in my man cave. My first plan to make Lamoille copy was make a female mold, but as I know these infusion problems with skisleds (170cm long, 38 cm wide), I thought that with much bigger infusion, there will be much bigger problems. It was not an easy task to get skisled infusion to be perfect, and canoe will be much harder.
But maybe I must bite the bullet and make a female mold for Lamoille. If all will goes like I like to, it saves much work (after mold is ready), but if there is a problem, result will be crap. If I compare canoes and skisleds shapes, canoe would be easier to get fibers to their places, but canoes size is so big that there can be problem to get enoght epoxy go thru feeding pipes.
The voice insíde me says get it light as possible, but both of my Northstar and Wenonah are wet bagged, weights are 40 and 43 pounds, and these are light enough for our short portages. Single portages are impossible for us, because we make stories for outdoor journals, and we have too much camera gear etc, and its the same if canoe weight 30 or 40 pounds, if we cant carry all stuff in same time.
I have had the same dilemma. A female mold would be ideal but there is a huge amount of cost and time involved with that and then what do you do with it when you have built the canoe you want? I still think a male mold is the best alternative for those of us making a single canoe but there are definitely compromises.
I've built strip canoes since 1978, more recently I've built a few carbon copies of existing hulls.
For a home builder, not interested in production, it will be hard to beat a male plug, your Mad River,
Be sure to liberally coat the plug with multiple layers of mold release, a bunch of us here have used Partal, a PVA compound.
A single layer of carbon will provide plenty of strength, you'll need a layer of glass on the outside. Carbon alone will wear away as fast as a pencil. Another layer of carbon fiber over the foam inside is overkill, and 9 oz cloth will soak much resin. Glass would be a better choice.
Be sure to leave the stems open, or you may never get the copy off of your plug. Seal the stems up after releasing from the plug.
If you have the means to apply vacuum to the foam stiffeners that will ensure a solid contact to the carbon. And an inner layer of glass would be plenty, assuming you have good adhesion between all layers.
I'm assuming all epoxy resin...I've had disappointing results with polyester and vinylester resins. Oops, just reread your post, OK, all epoxy resin.
A 4 layer copy of my 17'9" Sawyer Cruiser weighed 40 lbs complete with all trim and seats, it could have been much lighter.
BTW, I used 1/8" thick Divinycell foam (closed cell PVC) and it provides plenty enough stiffness. Not sure how your linked PET compares...I have trouble to think in Pascals. 10mm thick foam will create a laminate as stiff as granite!!
For ultimate weight savings, I would avoid using carbon for the trim. The compound shape of the gunwales will force you to use a bias woven cloth, and there are too few choices of carbon bias woven tapes, you will lose all you weight advantage of the carbon to the massive amount of resin needed for a full wet out. Composite (foam) gunwales and thwarts can be wrapped with glass and provide all the strength you'll need.
Please understand all of the above suggestions are my personal jaded opinions.
And your English is fine, way better than my non existent Finnish.
Oh, and thanks for dropping by, hope we can help.
Hey ErAh - I've got a kevlar-airex Lamoille, it weights a little under 60lbs. What strikes me about your comments is describing it as "stable". The Lamoille is barely 34" across. I love it, but It just doesn't fell like a stable boat to me, especially compared to something wider like the Northwind.
I think you might actually like the weight and stiffness of your fiberglass Lamoille.
The weight gives it inertia. To rock a 85lb hull takes more force than a 40lb hull. Plus the weight is distributed all around. So just by being heavy, it's feels more stable. Especially when empty.
The shallow v hull should help stability, but on my Lamoille the v is so shallow it is almost flat. I doubt it's doing much.
A fiberglass Lamoille would also be really stiff. My fiberglass Explorer feels stiffer than my kevlar-foam Lamoille. I think unless you get a good carbon kevlar layup you're copy will not be as stiff.
I suspect this is the same reason old wood-canvas canoes feel so special. They have enough mass to stabilize them. Like a built-in balance pole. They are also very stiff, so the don't waste your energy on wiggling the hull.
I have a carbon-kevlar solo that weighs about 30 lbs. It paddles great because it's so stiff, but the lightweight makes it twitchy. I switched to a heavy paddle for a few days and could actually feel the boat rotating as I swung my body and paddle around on the return forward. You'll never feel that in an 85lb canoe.
I understand the desired to get a lighter Lamoille, its a great hull. Good luck!
I use Miracle Gloss MG681 mold release compound. I have already one gallon can. If I use Lamoille as a male mold, I would use window film in diamond area, because its so flat in Lamoille, its possible that it would be hard to remove copy from mold.
My plan is laminate with closed stem, but I will cut ends open after one day of curing, Epoxy wont be totally cured and can be cutted with carpet knife. I think that it would be easier to get stem closed, if there is only that closing job.
In my Minnesota II there is 10mm foam in diamond area and ribs. If I use 10mm foam in this, canoe would be very stiff, but if we hit canoe to rock in bigger wawes, hull wont flex at all and there may be a risk for structural problem in hard hits. In real life, we use our canoes like babys, there wont be problems with hard hits.
I am thinking to get 5mm foam, it could be stiff enough. It gives little weight saving and its little cheaper too.
I made 4 rib to my Northwind 17, I use 3mm soric as a core material, and these ribs works well. Soric is actually really heavy, because it sucks epoxy very much.
Gunwales are something, which are difficult to make. Actually I dont know, how I will make them. First I plan make only inwales, but in this case canoe would be 1/2 inch lower than original (I wont remove wooden trim).
Welcome to the forum, @ErAh
Please share your stories! Especially canoe stories!
In finnish forums, I can't wrote stories, but here it may be possible. Magazines wants stories first, and even my wife wrotes these stories (I am photographer), its not right to wrote trip report to forum before they have published it in magazine. Making story will take hours with my english, but I will try when I have enough time.
Today I look forums canoe destination and routes and find this: https://www.canoetripping.net/threads/the-happiest-country-on-earth-has-188-000-lakes.129942/ I have done around 50 trips in Finnish lakeland, mainly in Saimaa area, which is Finnish heaven for canoeing. But there is much more than Saimaa for canoeing, not as big areas, but good places for 5 to 7 days trip which is what we usually do.
Welcome. You seem to be doing just fine in English & it's always good to watch another project / adventure take place.
...its not right to wrote trip report to forum before they have published it in magazine.
Best of luck getting published. If you succeed, you can always post links to the article(s). We have many here that post external links (not my preference but I'm not making money at it).
Wife wrotes around 40 articles per year for magazines, so almost all of our trips will be published. In Finland biggest player of wilderness magazines is "Erä-lehti". In july, I get my first magazine cover image in Erä-lehti and this was big deal for me... (I make my first subscribe for "Erä-lehti" in 1989, when I was 16 years old).
I put link to some of my wifes article (these are finnish articles, maybe google can help??):
https://wp.eralehti.fi/nakoislehti/...3NDM2OTgkbzEkZzEkdDE3ODk3NDQxNzQkajEzJGwwJGgw (Sarek story)
Google translate seems to work well. Your pictures don't transfer but her text does. (I guess we may have to settle for switching back & forth if she does a canoeing article). I've often wondered how well such things work.
Google Kääntäjä näyttää toimivan hyvin. Kuvat eivät siirry, mutta teksti kyllä. (Taidamme joutua tyytymään kielten välillä vaihteluun, jos hän tekee artikkelin melonnasta.)
Maybe I should put some pictures, which I take in that trip. My wife interviewed the best finnish nature photographer for this article Jorma Luhta (my opinion). It was quite difficult to make it with my photos : , my photos are cheap, Jormas are not and publisher dont want pay the bill) , because Jorma Luhta is so awesome, that there will never be the same, actually he was one of my idol of nature photography (the other was Hannu Hautala).
In the last "retki-lehti" was her article about paddling in Kukkia, which is quite small lake in soutkern Finland.
But, if you plan to make canoe trip to southern Finland, I can help with it. Maybe we want come together to Saimaa.
ErAh, I'm not one of the builders but do want to welcome you to site membership!
Feel free to ask any questions and to post messages, photos and videos, and to start threads, in our many forums. Please read Welcome to CanoeTripping and Site Rules! Many of the site's technical features are explained in Features: Help and How-To Running Thread. We look forward to your participation in our canoe community.
Reports about trips in countries other than the USA or Canada are mainly found in the forum named Canoe Destinations and Routes. Here are two threads about canoeing in Finland from that forum:
I believe you are our second member from Finland after @hautamak, but he hasn't posted in about four years.
I would like to ask how popular are open canoes in Finland? In some European countries they are called Canadian canoes. Is it difficult to buy open canoes from American sources in Finland?
If you have some single photographs of canoe subjects you can always post them in our popular Photo of the Day thread or in our Show us pictures of your canoe vehicle with boat(s) thread.
In FInland open canoes are not as popular than kayaks. I have used both, but in the last 2-3 years I have paddled mainly with canoes. In our paddling club our members use almost only kayaks. But the other side is that outfitters in Finnish lakeland rents canoes at least as much as kayaks. But usually outfitters has cheap and heavy polyethene canoes with too long heavy paddles, so first canoe trip can be the last canoe trip.
Before Covid you can find Esquif, Wenonah, Swift, Northstar, Clipper and Nova Craft in Helsinki area. Today you can buy only Esquif, Northstar and Nova Craft. I try to order Wenonah Itasca 2 years ago, but nearest dealer was in Denmark. Northstar has very good dealer in Finland, and they have even sell some Northstars to Germany.
Two weeks ago I visit former Clipper dealer, they have still some boats, but they dont order more, because Clippers are quite expensive and canoes stays too long in the dealers canoe rack.
Welcome! I love the pictures of all the snow-laden trees. I’ve been looking at some canoeing locations in Finland. A country with more water than land is marvelous.
I made a second trial lamination, I use infusion epoxy in this trial, and it seems to be better in my workshops temperature. Its only 15 celcius and usually resins need around 20 celcius. Normal epoxy resin for hand lamination will be too thick in this case and with infusion resin its much easier to get flawless laminate in this temperature, and it won't drain out as it would do in warmer workshop. And good thing is that I already have 10 kilos of infusion resin, with 300 min pot time. When I use this, I have enough time to squeeze excess resin out of laminate.
Of course I must put two MSR Dragonfly stoves under the canoe after one day of curing (I want wait that epoxy cures enough, before it will get warmth, I dont want risk that epoxy runs out of laminate), without these laminate would take week to be totally hard. My workshop is really too large to keep in 20 celcius in this time of year.
Now I must order enough carbon fibers, 20 metres long roll will be enough for one canoe. And enough carbonfiber sock for thwarts and yoke.
My goal weight is 40 pounds, and I think that canoe will be quite strong in this weight.
Do you plan on an all carbon lay up?
Carbon fiber, while amazingly strong, is also very susceptible to abrasion. Unless you plan to take extreme care to avoid ANY abrasion, you're gonna need some protection on the outside. Glass, nylon, polypropylene, Dynel, Kevlar...
You're lucky to have so many resources at your disposal.
I have Nelo Inuk kayak in E layup, its honeycomb structure, carbon in outside. And with it I have made some hard landings as you are forced to do in the sea sometimes, there comes hits but they are quite easy to repair. Actually, I really dont want kevlar in the outside, if you get hits for it, its really hard to make looking good, you cant grind it, there is always some "fuss" and its really difficult to repair. Glass is much easier, but as good is carbon. I will rather get stiff boat, than boat which have glass barrier, but it is not as stiff. We use our boat like babies as we paddle in the lakes only with our canoes, little scratch comes, but those are only marks of a good life of the canoe. Our Minnesota II is kevlar light and even it has little of use, it looks terrible (OK, it looks almost like new, but little fuss is in the stern and bow), if I compare it to our Northwind 17, which is Nortstars blacklite. Actually I dont know, is there glass layer in blacklite, but I guess there in carbon layer in the outside.
The full carbon lay up is something what I want to try, even I know that real canoe manufacturers use something else. If this first try will be OK, I will make another with only one layer carbon outside of core foam. The outer ply might be little heavier, like 285g/m2, but I like push it near to limits. But that will wait until we get this first to the water in next year and see how it is in real life.
This is my first canoe, but it wont be the last. If there would be some problems, I could change things to make next canoe better. Learning curwe can be steep, but I want learn things to make good canoes,
I have quite much resins etc, because I made these skisleds. For the next winter I would make only one skisled, so the rest are best to use something else, like this canoe...
You're clearly well experienced in the various composite lay ups.
I suppose you'll add selective abrasion resistant layer(s) if and when there's a wear issue.
I shouldn't try to impose my experiences on your plans, my hull suffer much with beaver dams, rock gardens, boulder filled rapids, etc.
I'm certainly looking forward to see your progress.
Mike T
