As stable as a Camper but lighter
Bradenton, FL
I might be asking for the impossible but here is my question:
Is there a canoe out there that has the initial stability of my Old Town Camper but weighs around 40 pounds or less?
I have been paddling my camper for many years, first in New Hampshire and now in southwest Florida. I love it but I am looking to the future where the weight will be concern. The literature list the camper at 59 pounds but mine weights 65 pounds (I replaced the seats, yoke, and thwart).
I paddle sitting in the bow seat facing the stern with some ballast behind the stern seat. I am happy with this arrangement but am open to a solo canoe. I test paddled a Wenonah Vagabond but found it a little to “tippy”.
The Vagabond was advertised as being very stable so that makes me think that perhaps I am asking for the impossible.
A secondary concern is durability of the canoe material. I like to explore the mangrove tunnels. I am a pretty good paddler but occasionally I run up against a mangrove root or have to “scoot” over a fallen tree. My Royalex Camper is basically bulletproof.
Light weight stability is definitely my primary consideration, but I don’t want a canoe that I have to baby.
View attachment 155412View attachment 155413
Today the tide and wind predictions were just about perfect for one of my favorite paddles.
Paddle Plan:
•Launch at Robinson Preserve south ramp
•Paddle through the preserve to the north cut into Tampa Bay.
•Get to the cut at high tide (current can be strong at other tides)
•Head west to Perico Bayou with a tail wind
•Return to the ramp through the mangrove tunnel.
The trip started out great. I got to the pass at high tide and Tampa Bay way calm with a nice view of the Sunshine Skyway Bridge (first pic).
Tail wind paddle through Perico Bayou and found the entrance to the tunnel without having to cheat with my phone map.
The tunnel was navigable with a few obstacles to get around (second pic). About ¾ of the way through the tunnel there was a medium sized branch blocking my way. It was too high to scoot over and too low to limbo under. I was about to head back the way I came but I really did not want to fight the wind and the outgoing tide at the cut.
I decide to try to move one end of the branch. It was tricky maneuvering myself close enough to grab the branch but I was able to pull one end of it into the water enough for me to scoot over.
I would not have tried this in a canoe less stable than my Camper.
I don’t love lifting the 65 pounds but the stability and Royalex durability are too good to give up. I guess that I will keep it until
I can not lift it anymore then figure something else out.
Sounds a little like what I contend with when I paddle up the local lake inlet to get close to the heron rookery there. It's a narrow passage, littered with fallen limbs and partial logjams. I sometimes have to slide over floaters, duck under low hangers, and wrestle waste high limbs out of the way. Then on the way back I'm often fighting a headwind and rollers from the long fetch.
The canoe I'm usually in is the Clipper Solitude. As I read your post, I was thinking that seems like you need something similar. It's a very stable solo. Not the fastest for its size, but reasonably fast. I sometimes stand in it to pole the shallows. The bucket seat is very comfortable and it's adjustable. I keep it in the middle height position, but it's even more stable when lowered. It has an adjustable foot brace, and that also helps with stability. It's my favorite fishing and photography canoe.
I had a Camper, so I know what you mean about its stability. But that flat bottom isn't so great if things get sporty when the wind comes up. Neither is that high shear line. You need not be in a hurry to replace it, but I'd suggest that you keep thinking about a more suitable (and lighter) solo.
Oh, another that would feel more like your camper but less effected by wind is a Mohawk Solo 14. It will have to be a used one, as it's no longer made. Weight is right at 40 lbs. Also very stable, although a little slower than the longer solos. I have that boat too, and I've poled it as well. Fished out of it too with little care about balance. It's the boat I keep for introducing novices to solo canoes
A stable solo canoe sounds like if might work for me once it gets in the water. I am still concerned about the absence of a center Yoke to get from my car to the water and back. I have seen some removable yokes online but I can not say that I am excited by that solution.
What do all of you solo canoe paddlers do?
I added a couple lugs to my carbon fiber over foam gunwales in my carbon copy Kite.
Thwart is an old one that I made in 1987, it's been mounted and abused on many hulls.
Don't have any really good pics, but I'll include a couple so maybe you can see what I've got...
I use a removable portage yoke. I have 2 portage yokes. One is homemade using plans from Cliff Jacobson’s books for my Old Town Discovery 119 and the other is a CVCA portage yoke for my Wenonah Wilderness.
If it's just from the car to the water, I hang it by the gunwale from one shoulder. If I'm portaging any distance, I tie two paddles from the seat to the thwart (which I have set 28 inches ahead of the seat for that reason).
That way, there's no extra weight, nothing to lose in camp at night and I'll always have an extra paddle anyway.
My Solitude has a sliding bucket seat. I just slide it all the way forward and set the leading edge of the seat on my shoulders. That balances the canoe slightly stern heavy, and gives me a perfect reach to the forward thwart so carrying is fairly effortless. Due to the contour of the front of the seat, it's more comfortable than it sounds,
For short carries, my Wildfire is light enough (30 lbs) to just sling one gunwale over a shoulder. I replaced the seat with a mini-cell saddle, so on longer carries I set that on my shoulder.
With any solo no more than 40 lbs, setting the front edge of the stationary bench seat on my shoulder has worked, but that makes it bow heavy so range is limited. For longer carries, I use a padded clamp-on yoke.
I know someone here has done something with web strap that looks like a great solution.
How far are you carrying to the water? Normally I either throw the gunwale on a shoulder or just carry it over my head. Even with a tandem I'm more likely to shoulder it than carry it by the yoke for quick carries.
