• Happy National Iced Tea Day! 🧊🫖🧋
Installed Footbrace on P15
SW OH - Land of Opaque Water
It was warm today so I got the Esquif Prospector 15 down and outfitted her with stuff I need. I placed the footbrace so it can be used from either seat. Thanks to whomever gave me the tip about dipping my finger in mineral spirits to finish the adhesive beads. Looks very clean. I used one rivet to hold the mount in place and add a little security to the joint. I always put a 3/8” thick nylon washer in the ends of the tubing to keep it from crushing when the knobs are tightened.
I’m anxious to get this puppy out, but winter’s not done with us yet. Both cars are ready with a kayak and a canoe rack, so wife and I can shuttle on the river. Nice to get out before the outfitters get going. I have no idea what this thing weighs. It started at 60#, and getting it on the roof by myself was challenging.
PS - I’m not sure how well the adhesive adheres to Tformex. We shall see.
BF, maybe you said this in another thread, but what adhesive did you use?
Also, two questions about the foot bar. Did you have to bend the bracket at all to follow the curvature of the hull? And how does that bar slide forward and back on the bracket, given that the hull width narrows from back to front? I can't tell if the bar slides into itself.
Id be interested in seeing some pictures of the rivets through the hull if you wouldn’t mind, my wife wants a foot brace on her Royalex boat and I’m a little nervous about drilling and riveting.
Yes, I bent the bracket just a little in a vice to better fit the curvature of the bow. Also, the rivet in the middle hole pulled it right up against.
The adhesive is a fast drying kind that gets really hard. I’ve used it before with the carbon fiber mounts on Kevlar boats. This is my first time with rivets and on plastic. The adhesive has always held well before. I did sand the mount area and cleaned with alcohol as prep. If it loosens, I’ll remount with 2 more rivets (3 each side), and maybe thick Gflex.
The rivets are 3/16” aluminum ones. The adhesive squeezes around the rivet effectively sealing it, except for the nail hole which a dab of epoxy will resolve, if it bothers you. The main tip I can provide is keep the riveter straight and flush when tightening the rivet so it doesn’t get angled. I used rivets without adhesive on my last CF/kevlar NC P15. Aesthetically, not as nice as the glue.
The aluminum mounts allow for on-the-fly adjustment (no wrench), which is important if you want to change seats or just get more comfy while paddling. The CF mounts are lighter, and hold well, but not as useful for a tandem application.IMG_0789.jpeg
Is the bar telescoping or are the holes in the bar slotted to allow for the width difference of the hull as the bar is moved forward or backward?
Yes, the bar telescopes. It is important to remember that the Northstar Footbrace is made for narrow solo canoes. When ordering, I asked NS to cut the tubes a few inches longer to fit a 35” wide tandem hull. They were happy to do it. This is my 2nd P15 install. It’s great to talk to suppliers who get it and are eager to help. Cudos to the crew at Northstar.
Sorry to derail the conversation a little, but is your roof rack set up for a canoe and a kayak? It looks like there's a foldable j-style rack on the right?
Thanks. That looks exactly like the set up I should have gotten on my current car, and thanks to all your posts it will be on the next. My wife also prefers her kayak, and in all fairness it's very fun to paddle. I'm going to try to sell her on canoes this summer, we'll see how that goes.
My wife used to trip with me. She paddled a solo canoe through Woodland Caribou PP in 2018. She enjoys not being in the bow and controlling her own pace. She still enjoys a canoe on lakes, but on the rocky streams around here, she’ll either be in the P14 with me or in her plastic yak. It’s a practical choice.
Black Fly - I am also going to use the aluminum footbrace this year. Is the rivet necessary or can I just use Epoxy for the side pieces? Love the racks on the car. My wife is also more comfortable in her Kayak - They (Canoe/kayak) both have their advantages.
Just fyi the Wenonah footbrace is about half the cost of the Northstar version. Riveted only. Put one in my Rx Wilderness when I first got it. Pretty easy install even for non-mechanical me, though definitely a little nervewracking. Worked great. Don't have that boat anymore but the factory one in my u/l Wilderness works just as well.
To me installing something with nearly permanent epoxy would me more nerve racking. :)
I’ve installed a few of the northstar epoxy (superbond) ones, both aluminum and carbon, and thought it was pretty easy. I just can’t bring myself to drill a hole in the boat, especially near the waterline. I like the fact that if I or someone else wanted to remove them they could do it so it would be almost impossible to tell they were ever there. I’ve also been VERY impressed with how strong they are. Pretty sure I’d break the foot at before the adhesive bond unless there was heat involved.
Thank you all for your advice. Yes the NorthStar one was crazy expensive and carbon to boot. I'll pick up some thin aluminum angle from Lowes and modify it to fit with holes. Still have to think about the rivet.
