If you do decide to epoxy them ... make sure you also have enough clamps. I have quite a few ... I bought them on sale
Now for the current build, I have a wack of Jimmi clamps that I think will be a lot easier and faster than these.
I am 98% sure that I will be epoxying the gunwales. The material is much thinner now for the outwales and inwales so I think the best for this situation will be to bond with epoxy. I definitely do not have enough clamps for this technique though. C Clamps are expensive. Will spring clamps do the trick in the non aggressive bend areas? If so I will pick up about a dozen C Clamps and utilize the spring clamps that I have on hand as well.
