Show me your canoe truck
My first truck as a 1982 Toyota SR5 4x4 pickup. Canoe at the time was a Scott Tripper. I did some serious off-roading back then and took the canoe everywhere that water existed and frame twist was an issue where we went. The Scott's at that time had cast aluminum end caps with a 3/4" hole in them. I fashioned an alum tripod that I bolted to the winch kit on the front of the truck with muffler clamps. The top of the tri-pod had 1/2" threaded rod and shock absorber bushings. Spin off the nut, pull off the top bushing. The hole in the end cap fit over the 1/2" rod, slip the bushing back on and crank the nut back on with ratchet. There was sufficient room inside the boat to get the socket/ratchet on the nut. The urethane bushings had enough tension the nut wouldn't back off ever but allowed the boat to rotate. The middle of the boat was supported by a single oak board that I attached to the top of the roll bar with carriage bolts and wing nuts. I had just drilled down through the tube, made stand offs that fit the shape of the bar, put some rubber on it to avoid slippage and the sides had u-bolts where the boat sat, so it never went sideways on me.
Mind you, when not hauling a canoe I did have off road lights on the bar, so I fashioned a light bar with hinges, the hinges were welded to the existing light tabs on the roll bar and carriage bolts and nuts held the bar in place when the lights were needed, when I mounted the bar for the canoe, the lights would fold down out of the way and bolt in place to avoid vibration. That set up worked for the 10 years I had the truck and it travelled as far as North Carolina without any issues. It allowed the frame to twist as much as it needed to without ever putting that torque on the boat itself since it just rotated on the tri-pod front mount.
The truck itself over time got a 3" suspension lift, 2" body lift, 33" BFG Mud Terrains, Warn 6000 lb winch on a Warn combo kit up front, it was factory yellow when I bought it in '83 and over the years it stayed yellow and the last iteration I painted it Toyota MR2 yellow.
I don't have any digitized photo's but might try to scan the odd photograph I still have off that old beast if anyone is interested. In the end the frame broke due to mud inside and it rotted from the inside out.
Now, I have the 2004 Toyota Highlander which is my daily drive and canoe hauler and potentially if I ever get it where I feel I need it to be, I have a 1990 Toyota Hilux pick-up, extended cab, 4x4, V6 with a new frame and no rust. The pick up is paid for, the Highlander will be in December.
I used to be a smart chick, now I'm just crazy.
Karin
Yes Karin, we'd like to see that truck!
Keen eye memaquay, that photo is when I hauled the Raven home. It still looks almost that good.
So many cool trucks in this thread. I like seeing the variety.
Here's a previous Taco I owned that I got stuck good. My friend winched me out with his Jeep.
Hanz, I think you were supposed to leave the truck at the put in and take the canoe down river. That's how we would do it in Iowa any way.
Not the fastest, but great mileage! Otherwise, my 2001 Tacoma gets me where I need to go with only minimal fuss.
never confuse your canoe and your car( not mine. This is at Attean Pond ME launch in a flood. Sane people used the uphill parking lot.)
All this truck porn makes me wish I still had one. However I need a van for work, and although I've tried and tried to convince my wife that she needs a truck, she refuses to give up her car. So instead, I just keep flicking through these full colour full frontal photos late at night. Please note, I look at this site for the informative articles, right?
Vans are good. One of the banes of trucks is that the usable bed space is shrinking. I miss the seven feet of bed I had with my Tundra (2000) extended cab.. Bed was not an issue.. I had a futon mattress in the back and drawers underneath for wet stuff and paddles.
Alas the new Tundras have been fed way too many steroids.
Full sized vans aside, I drove a little Mazda pickup for a few years. Not very suitable for work, with or without a cap. Perfect for tripping though. The 1/2 extra cab nearly fit our small kids. I added an extra seatbelt so all three of them could be shoehorned in. And then they started growing. And kept growing. And then # 4 came along. Time to get rid of the pickup. Nowadays my minivan accommodates an inflatable mattress for she and me. Comfy for overnight wherever. Still a tight fit for the gear and us however when the bouncy castle is employed. She finds sleeping in it claustrophobic.
This is my current pick up. Bought it for $1200 not saftied. It had 33's on it, light bar drilled into the roof and another pair on the front bumper. It was all grey primer at the time. Sold all the lights, wheels and tires for about $800. Put another $2000 into parts to get it on the road. It is mostly used for dump runs and Christine takes it to work some days. It is pretty rare up here to have an old one without rust and a solid frame, might sell it, could maybe get up to 5K for it, although the fact I painted the entire truck with spray bombs of Tremclad might bring the price down a bit.
I had just parted out a 1990 Forerunner in the same colour so we scavenged good body parts from it for this one.
LOL, I did a lot wrong that day. Lucky for me, my friend brought his fishing waders and hooked me up to his winch. I didn't exit the truck and get wet or dirty, but I did have to wait two hours for him to get there. Saw a huge Whitetail Buck while waiting. I won't soon forget that day.
Some call it a truck...some call it a van...it will always be a bus to me. Such a great expedition rig. We had kayakers that trip, so there are A LOT of dry bags!
Hanz, that looks familiar, toppins path? I can never remember the names of those trails out there. All I remember is the ticks!
Yep, good memory - That is Toppings Path. It's completely redone - no more bug puddles but the ticks are still there.
I like that a lot. Very cool.
Here's my Sweetheart's Honda Odyssey on our way to Adirondack Park:
HudsonWalkway-1.jpg by Hansen.Dougie, on Flickr
In case anyone is wondering, the rodents at the parking area for the Bog River Flow/Lows Lake can and will get into a 2014 Odyssey and nibble on your snacks.
I had to put my truck in this post as there are way too many Toyota's. In defence of Toyota, I have had many in the past. My trucks have always been Fords or Toyotas. My current truck is a 2012 F150. I had looked at a Taco but as I get older the "sitting on the floor" seat position of the smaller trucks has lost its appeal with me. My current truck pulls and hauls 3 times more then the V6 Taco. My F150 has a smaller displacement motor but has almost 150 more HP. As a full size truck it gets as good of fuel economy as the V6 Taco (if you drive it like a "normal" person). One major thing that made my decision was Toyota hasn't changed or updated the Taco since I don't know when. The other biggest thing was that there was not much difference in price and how do you beat Fords 0% and rebates compared to Toyotas next to nothing incentives. I love all trucks but am very happy with my latest choice.
Perry
Even if I won the lottery I would still buy a Tacoma. I don't need all the HP that the big 3 are still offering. Ideally we all need someone to bring out a hybrid or electric vehicle with 1000km range and the ability to take at least 2 canoes on the roof plus all the gear and people. Until that time we are stuck with using dirty oil.
I am still waiting for 1/2 ton and smaller diesel trucks to be available in the US like the rest of the world drives. I love my one ton Ford with 24 mpg, but could get by with a smaller truck now. I no longer haul horses or a camper.
Amen to that.
I think Toyota sold the Hi-Lux diesel in the US in the 70’s,and some of those are still kicking and sought after.
That was a different time for mileage demands, and for diesel acceptance and availability in the US.
Just like 2015 is a different time for the above, the current Whoopie! of $2.25 a gallon regular notwithstanding.
A small to mid-sized pick up with an efficient diesel engine ougtha get, what 40 mpg highway? Hell, crossbreed a VW Jetta with a small El Camino (someone probably has).
If a small diesel pick up with modern engine technology was available today I know a dozen people who would start shopping tomorrow.
Just like the rest of the world drives. What kind of mileage does a Toyota Hi-Lux diesel get with six passengers and a bed-mounted machine gun.
Still the best testimonial to the Diesel Hi-Lux ever:
https://www.youtube.com/watch?v=xnWKz7Cthkk
