Light weight vs strong laminate
Louisiana
There have been discussions about moving to lighter weight canoes as we age but that tends to mean more fragile construction. I want a canoe that is both light weight and robust! The Flashfire is one of my favorite canoes. I had a Bell Flashfire that weighed about 36 pounds and then when a Placid Flashfire came up for sale some time ago I sold the Bell and bought the Placid Flashfire which weighs 29-30 lbs. It is such a delightful canoe to use for maneuvering around obstacles such as trees in a swamp or snags in a stream. Last week on Magees creek, a shallow stream that flows into the Bogue Chitto, I got over confident and made a last minute poor decision to take a less straight-forward route when approaching a snag. I hit the snag broadside and along with the thud there was a sickening cracking sound. The fabric doesn’t look torn, but the resin matrix is cracked in the chine and also at the shouldered tumblehome, along with gelcoat cracking on the outside. I usually try to baby that canoe but it is such a fun canoe to play with I got tempted to try a move I shouldn’t have. Back when Placid was making the DY fire models Charlie Wilson was touting Placid’s resin infusion technology and saying the Placid versions had greater strength compared to the Bell ones. I’m not sure about that now. I hit the snag with more than a gentle tap but I wouldn’t have thought it would cause cracking like it did.
What trade-offs do you make? Do you struggle with a sturdier but heavier canoe, paddle a light weight canoe but avoid trips or maneuvers that risk damage, or paddle a light weight canoe, take the risks and keep doing repairs? With the back problems I’ve been having, loading a canoe much over 30-33 lbs on the car has become quite a challenge so a heavier lay-up wouldn’t be a great option but neither do I want to keep having to patch my Flashfire nor am I ready to give up fun maneuvering in flat but flowing water that has obstacles that may at times push the limits of my ability to avoid them.
I have a similar conundrum, except mine isn't about weight or fragility. It's about cost and ease of repair between two boats. My w/c canvas canoes are the ones I prefer to paddle, but a mishap on moving water or dragging over shallows could cause damage that would be harder and more expensive to fix then on my composite boat. I could also take a royalex boat and have no worries at all, but life is too short for that.
The conclusion I came to is paddle the boat that I prefer or the one that would work the best for the trip, and hope for the best. Within reason of course. Knowing your skill level and the conditions you may encounter are a big consideration. Take whatever boat you think will be the most enjoyable with a reasonable chance to come out unscathed.
That's me. It helps that most of my canoes have been bought used, with pre-existing scratches and dings - even cracks or worse. So far, at least, my repairs haven't added significant weight. I only have one canoe that is so pretty I baby it ......a little.
I'm a man, so I'm always shopping for an upgrade. One of the things that keeps me from buying a brand new canoe right this minute (besides price and lack of test paddle access) is this indecision over layups. 28 lb ultralight, or expedition weight? Yeah, that's a tough one when you're talking about $4k US. But time for spending the money and wearing one out grows short.....
Pika, as an aside, the area you describe is likely the most vulnerable area on the entire canoe, had you impacted anywhere else, we probably wouldn't be having this discussion.
Choosing "Ultralight" versus "Expedition" layups (and the few in between) is largely an exercise is figuring out how you plan to use the canoe and what are your needs/wants. If you want the weight reduction, then you have to slide towards the UltraLight layups and that will also require you to respect the capabilities of those craft. They are just not going to be as impact resistant as the heavier layups, but if you hit them hard enough, they will also crack.
I think Lowangle summed it it up nicely:
That is an interesting point. The cracks are not directly at the point of impact (at least I don't think so), they are in areas of greater hull curvature above and below the impact.
I'm in the "patch it, paddle it, enjoy it" camp but it depends on the extent of the damage whether I'd bother patching it.
If the glass is intact on both inside & out and the cracking appears to be limited to the core (does a fingernail or ball point pen catch in any of the cracks?), I'd probably just paddle it, figuring the odds of hitting the same spot might be pretty slim.
Of course, your destination may impact the level to which you repair also... If you're headed to Crown Land for a 3 week, off grid, solo I'd be more likely to repair than for a day paddle on local waters with easy road access.
I have been struggling with the same problem. I tweaked my back playing pickleball recently (second time in three years). I am still able to lift my 65 pound Royalex OT Camper but I turn 68 soon and at some point in my future the weight will probably be a problem. The lighter more fragile layups would be nice to lift and paddle but I know that I will not be able to avoid exploring the water here where an unexpected oyster bed or really narrow mangrove tunnel is sure to turn up. I have decided to give up pickleball keep going with the “bulletproof” Camper and hope that my strength holds up for a few more years.
A lot of the modern “tough” composites are a decent compromise. Most can take a decent impact without too much issue, and are still lighter than royalex. A Flashfire made by Swift in their Expedition Kevlar, or a firebird in IXP would still be fairly light and able to take more of an impact. I try to avoid major obstacles but the Ozarks are just super hard on the bottom of boats. No manufacturer I’ve found makes a boat abrasion resistant enough for years of regular use in the Ozarks without a rough looking underside, unless you only go when the water is fairly high. My IXP Phoenix takes impacts just fine but still scratches badly on the bottom. Same with my Swift Starfire. I’ve spider cracked my gel coated Bell Starfire but it handles the abrasion a little better than the others (plus the ivory color helps hide scratches). I had a T formex boat and the vinyl wore very fast in my opinion. Faster than older stiffer Royalex. But the old Royalex wears fairly fast too around here. Obviously they take an impact pretty well though. I go for durability over lightweight because we don’t portage here and it’s shallow rivers full of gravel, rocks, and strainers.
Keep in mind I wet foot entry/exit, and try my best to avoid shallows, but they’re just pretty unavoidable on these rivers sometimes.
Phoenix after less than a year:
Phoenix stem after taking a very hard impact on a truck sized rock on the upper Buffalo (no structural damage at all):
Swift after second paddle (very rocky river, low water):
It’ll look better after I get around to applying some 303 but still…
T-formex after a year:
The most prominent scratch here is my most recent cosmetic work on my Blacklite Trillium. A rock got sneaky on me in a 1+ rapid, I went right and took the rock on the side. Bounced right off and kept going. I wet launch but have gotten over being gentle on it, so far it's taken everything I've thrown its way.
To answer your question, I went with Blacklite because it's light but still has some extra durability vs some of the lighter Northstar layups. A few pounds is worth it to me for the extra durability, and if Blacklite HD had been a thing when I got my Trillium I probably would have added a few more pounds for a little more durability. But for my paddling I skipped the additional weight of the IXP layup that ABT uses. I don't do rapids over 1+, and if water levels are low enough to make rocks a real concern I head to a lake.
I use my carbon kevlar (no foam core) Yellowstone solo for exercise paddling in rivers. It has taken several really hard hits from snags. It is fine.
I don't think I'd go for ultralight layups. If I bought a new solo I'd be tempted for a composite with an extra layer. I would avoid solos with a foam core, it makes repairs harder.
I try to just accept it is a piece of gear and use it, although I cringe whenever I hit something.
As someone who’s beat up a few expensive boats on small streams, I feel your pain. I almost cried when I saw the cracks in a Gelcoat Swift P14 after a spring trip down the totogatic. IXP holds up pretty darn good compared to other compositions. I wouldn’t hesitate to use a smaller hull in IXP. Or, just get a small 40# tformex hull for streams and use the Cadillac boats on flat water only. That’s my plan.
Just look at the cracks as battle scars. You can Dremel out the crack and apply Gflex, but it may look worse.
I have once again had my mindset tweaked on this. My YouTube watch history for the past couple of weeks has largely consisted of events like the Texas Water Safari and the Au Sable Canoe Marathon. Those boats are LIGHT. Like 28lb tandem light. And somehow, they survive being thrown down waterfalls, levered over dams, jumped into, and banged off of every other obstacle. They dont all look show room pretty, but maybe thats the thing: desired toughness is perhaps really a measure of how infrequently you want to effect repairs. I'm still very much a canoe novice, but I was blown away by some of the abuse I saw those boats shrug off.
I have once again had my mindset tweaked on this. My YouTube watch history for the past couple of weeks has largely consisted of events like the Texas Water Safari and the AuSable Canoe Marathon. Those boats are LIGHT. Like 28lb tandem light. And somehow, they survive being thrown down waterfalls, levered over dams, jumped into, and banged off of every other obstacle. They dont all look show room pretty, but maybe thats the thing: desired toughness is perhaps really a measure of how infrequently you want to effect repairs. I'm still very much a canoe novice, but I was blown away by some of the abuse I saw those boats shrug off.
Good observations. I think most people (me included) tend to over estimate the water they paddle and how hard they are on a canoe. There are a lot of very lightweight builds that have been punished and paddled on remote waters yet they did fine. Lightweight canoes have been common since the mid-80's and the amount of people crying about how they broke theirs is virtually non-existent.
In the early 1980s, I wanted to make the trip from my home, not far west of the Blue Line, on a NE diagonal route across the Adirondacks to my daughter's then home, beyond Plattsburgh across a northern bay of Lake Champlain to near the ferry launch. I knew I would have many miles of carries, so I began to look for a lightweight canoe. I first looked to the GRB Peeper, but none were available. So I made a visit to Pete Hornbeck's shop. He showed me dozens of yellow kevlar boats hanging vertically in his barn attic like sides of beef as the stock he had built over the winter. But on his office floor rested a shiny black beauty. What is this, I inquired? Well, it is a trial prototype, the first of its kind, a carbon/kevlar hybrid, weighs in at 14 pounds, he just wanted to try something else with it. He was also working on an all carbon fabric version, at 12 pounds (I believe). Which I have seen previously and I was not impressed, as the one I saw had a stress cracked gunwale. "But I do not know if the hybrid is practical," Peter admitted. After taking a brief paddle excursion in his pond, I bought it on the spot.
So on to my trans-Adirondack trek. which ended up at 185 miles, with 62 total miles of carries, taking me exactly 7 days. It was the year before the NFCT was announced, but one of the original organizers helped a great deal by releasing to me an early unpublished version of the NY NCFT route. Of course, I was by then well experienced in the 90 mile race route. Ron’s assistance was most helpful for exposing which side of the waterways to exit and enter beyond Saranac Lake village (the 90 miler finish) for the safest and best carry routes. Nevertheless, I encountered much shallow boulder filled water in many places along the way during that dry hot July week. The poor little Hornbeck suffered greatly, regardless of how careful I was. More than once stuck between a couple of boulders at the chine, only later I discovered the fabric had been weakened and crushed. The bottom of the canoe is streaked white with dozens of unavoidable scratches. All worth it to see my daughter waiting on shore for my final paddle strokes in a Champlain gale and me bouncing over 3’ rolling waves.
Weeks later I took the boat to Pete Hornbeck to see what he could do. To his credit, he put reinforcing patches on the cheeks and another on the bottom, no charge (he said "I'd do it for any customer"). Thanks Pete. As for the scratches? "invest in black felt tip markers".
Day 1, on my way.
OK, Alan, ya talked me into it... My next build will be 2 oz e-glass with a 4 oz s-glass football & an extra layer on the (stemless) "stems"
for over 20 years, my Kevlar fusion Swift Kippawa has been dropped, slid down granite ledges, boofed ( both intentionally and un intentionally) run into and done the running into boats full of teens, carried way too much weight, dragged over dams, both (beaver and cement) with said loads, dry-footed extensively, and generally abused within an inch of it's life. There are so many scratches and gouges in it it looks more white than yellow, and I'll probably need to skid plate it this year because there's no gelcoat left on the stems .
my point being, if it's a working boat and not a cottage princess, those scratches and chips are just cosmetic, and structurally I think most boats are far tougher than we think, even the ultralights, but then again I grew up at a time where fiberglass was the primo whitewater boat, and damage was expected on every trip...
