• Happy Mountain Day! 🇯🇵 🏔️🌄
Commercial tarp poles: How many? Which ones?
I have a CCS 12' x 10' silnylon tarp, which I've always managed to pitch without poles in treed areas when canoe camping. I use a ridgeline between trees and manage to stake out the sides to something. I own no tarp poles.
Now, all my canoeing is done via car access base camping. There are usually no convenient trees around the drive-in campsites I frequent, but I'd like to pitch my tarp near my tent so I can sit and move about under it. I'd like some sort of telescoping commercial poles. But I don't know how many poles I need. Don't want an A frame set up with all sides staked to the ground. Rather, I want to maximize the underneath space.
Do I really need six (!) poles, two on each end of a ridge line and four raised ones at the corners?
Plus, what kind of commercial poles to buy. Some of these poles are astronomical in price: $90+ USD for one pole in some cases and places.
Any recommendations on the number of poles for a full canopy pitch, and what kind of reasonably priced poles are available?
I have three poles that I bought from CCS. Two of the shorter ones and one of the taller. That seems to work for me. They were not inexpensive but I liked the infinitely adjustable last section for fine tuning the height.
In my experience, in a scenario similar to what Glen described, six poles are needed to maximize the tarp's stability and water-shedding capacity when it is not possible to tie a ridge line to trees. I have the 6 ft adjustable tarp poles from REI and have had no issues setting up my tarp in a scenario similar to what Glen described.
MSR makes a pole similar to the REI poles in 4-, 5-, and 8-foot lengths. I have used the 5-foot model, and it works well, although when fully extended, it is not quite as long as the six-foot REI model.
A nice feature of these poles is their reasonable weight and compactness for packing for use in the backcountry.
You might want to check out the collapsible tarp poles from Tatonka.
Take a look at the pictures - I’ve set up a 4x3m tarp using four of those poles.
View attachment 153724 . View attachment 153725 . View attachment 153726
on this pics you see a DD-tarp 3x3 on trees and poles ...
View attachment 153728 . View attachment 153729
Those look suspiciously like the 5 piece Eureka poles I've had for about 25 years, I wonder if Johnson Worldwide sold the patent to them when they Folded Eureka
you don't need 6 if you rig in a diamond pattern, and if you don't mind long guyliness you can get away with 2- put your 2 poles at opposite corners, and guy out the other two, for more space you can add 2 shorter poles. it also helps with drainage because you're pulling along both edges not just one with each guyline and you can pull that nasty sagging center tight by adjusting the tension.
Buying any machined metal parts is a shock these days.
We use two 8 foot telescoping poles we got from REI. (As linked in Simuliumvenustum's post.) The 8 foot height lifts the tarp high enough to provide a usable space underneath. Not inexpensive these days at $80 each but they're pretty darn durable. We used inexpensive aluminum nesting poles for some years but they began to split so I tossed them. You could try using one pole and one tree but having two poles lets you set the tarp up pretty much anywhere.
As for increasing the area under the tarp, we use two 4 foot poles, one on each side of an A-frame set up. It lifts the sides up enough to see out when sitting in a chair. We got those poles from Cascade Designs/MSR. (Again, as linked in Simuliumvenustum's post.) They come as a pair for $70. I like A-frame setups because they provide good rain and shade coverage and deflect the wind fairly well.
But the current pricing would put you at $230 for a set of four quality tarp poles. Darn that inflation. ;)
I’ve used the single long pole the most, as it gives plenty of headroom.
High enough to cook under. I’m baking some sort of desert most likely.
So the point of the pole doesn’t poke through the tarp I made a little disc to spread the load. The pole has other uses too, I made this hook thing to reach high and push a weighted line through tight branches to get a guy line right where I want it and the hook portion can grab the weight on the other side to pull it down.
I did a thread on these a while ago when I made them but if I didn’t follow up they worked great and the hook thing made like a lot easier.
We use two 8 foot telescoping poles we got from REI. (As linked in @Simuliumvenustum's post.) The 8 foot height lifts the tarp high enough to provide a usable space underneath.
The 8 ft telescoping REI poles have worked well for me the few times I've set up a tarp. Bought mine more than a decade ago.
We bought 2 of these Green Elephant last year. No complaints.
We use 2 of them for a high side of the tarp, and use spare paddles on the back/ low side. It still gives plenty of head space.
I 1st saw these on Outdoor Gear Review which gave them high praise.
Tom, I saw and saved those poles in my Amazon cart along with these AVOFOREST ones, which I tentatively like a bit better because the removable top bulb is bigger, the tops of the poles have additional eyes to tie guy lines, and they are rated for 10 pounds more force. They also seem to come with stakes and lines, which I may not need but more is better than less.
For when I'm treeless, I'm now thinking of a five pole pitch—one pole at each corner and one in the center—for a good compromise of high and uniform elevation plus rain shedding slopes. Abutting one of my tent doors like a veranda.
Cut some wood poles in the woods. Lash 2 pairs of poles to together in an X with the lashing toward the end. Lay a ridge pole between the pairs of crossed poles.
I used that set up here in Nevada even in high winds.
Not my situation.
This is my canoeing program in my ninth decade: I drive hundreds of miles to watery places in in the Adirondacks, New Jersey or northern New England. When I get there, I base camp out of a tent in commercial campgrounds or trailer parks, from which I do different day paddles for 4 or 5 days. Most often, there are not sufficient, or any, convenient trees to which I can attach tarp lines.
I can't cut poles in these commercial campgrounds. Nor can I tote long poles in or on my mid-size sedan, which is my only vehicle nowadays.
I'm looking for collapsible or telescoping metal poles.
Cut your poles once. Find them where ever you can, not in a campground.
How do you carry a canoe? Put the poles next to your boat and lash them down.
I bout a couple pairs of telescoping poles, but use 3, 2 with mounts in the canoe and one tied off to rocks or driftwood logs.
