• Happy Birthday, Nicholas Katzenbach, my old boss (1922-2012)! ⚖️
Kite +6%
It's looking good! I imagine that planing down the inner stem like that could be a real hassle depending on grain and what tools you have available. For sanding it's hard to beat that random orbital though! I had the pleasure of borrowing the larger festool random orbital (with a 8" pad or something in that ballpark) a few years ago, and I've never had an easier time of a tough sanding job.
Out of my budget at the moment but boy... if you're looking down the barrel of a bunch of sanding and have the $$$ they are amazing!
Interesting, I've always just left my inner stem sticking out, similar to the look on a wood canvas canoe. Never occurred to me to plane it flush. Looks like a fair amount of work, but it will make your fibreglassing easier.
I snow-blowed (is that even a word?) for three hours on Thursday, the results were predictable, lots of snow moved corresponding to my body barely moving on Friday.
Hi to all. I just found this forum while looking for others who’ve built Kites. I’m just starting my build. I’m finding lots of great info and see people I’ve interacted with before on other sites
I’ve built a number of boats, and use them regularly here in Nova Scotia on both fresh and salt water. I do some back country trips, and was looking for a craft that would make solo tripping easier. My Redbird canoe is a lot of boat to solo in, and my Petrl Play is tight on cargo space. Love both boats, but a solo tripping canoe seems like a good choice for a couple nights in the back country.
Welcome Farback, good luck with your build.
I planed down the stern stem today then did a little grinding with a burr and a stone. I want to round out the stems so the glass lays in there nicely without me having to add an epoxy fillet joint. It will take a little more work yet.
I have a question about glassing if anyone's done this. I'd like to lay a 5' piece of glass into the cockpit and a little in the stems. Put it in with a squeegee and no fill coat. Leave it overnight or longer, rough sand for mechanical bond, vacuum then do a full length layer of glass over top. My question is how clear do you think it will be? Will the sanding of the exposed weave make a mess that won't be covered by the next layer of glass?
Thinking of doing it this way to prevent having to work with two layers at once.
I would say it will be fine, but I'm pretty sure your expectations might be higher than mine, lol. Whenever you work with more than one layer, there is a slight decrease in clarity, not noticeable by anyone else, but perhaps by yourself. Standing scratches will generally disappear with a new coat of epoxy, I wouldn't worry about that. You could always run a small separate test panel to see for yourself.
I'm of the school that the interior looks are secondary to reducing my suffering, so I don't worry much about aesthetics. I run three or four pieces across the hull, with overlap, instead of one big piece.
Like mem, I run 30" wide glass across the hull with a little overlap (inch & a half or so) and, even though aesthetics aren't terribly important to me, I don't think you'll see a noticeable decrease in clarity unless you use s-glass (& trade clarity for strength).
The scratches will disappear (remember that you're going to sand the epoxy before you varnish & they'll disappear then too).
When in doubt, test panels are always a great idea
That is a Veritas miniature shoulder plane. I bought it to use with Nick Schade's Robo-bevel but I have been using it a lot since Scratchypants suggested using it outside of the Robo-bevel. It's a pretty handy little tool for slow wood removal. It can work in a concave surface providing it's wide enough but it's pretty slow compared to the pencil grinder with that stone in it.
The inside won't be as pretty as the outside anyway. I only intend to fill coat that 5' cockpit floor section for ease of movement and the leave the weave exposed everywhere else for weight savings. I plan to use Epiphanes rapid clear varnish on the inside that doesn't need any sanding between coats so that should be fine with the exposed weave.
Gamma, yes it will be S glass again. The premium for S-glass doesn't seem that much more when compared to the hours you put in on a project like this.
I have the same plane and Nick’s robo-bevel. Recommend both. The plane is very handy both in and out of the robo-bevel.
S glass is quite transparent for our build purposes, if you buy the wrong weave it may be a little difficult to wet out .... but it is clear
I've used s-glass on my builds and it's plenty clear enough for me but it's not quite as transparent as e-glass and the OP was already worried about transparency of the s-glass that was used on the stems. I thought it might be an issue... (again, test panels are the way to go IMO)
My experience with the S glass is that it shows more "silver fleck" as well as the weave when you get up close. Also when using multiple layers it shows a fair bit more than E glass. Clear enough though and fine for our build purposes as Cruiser said. It does matter on the dark woods where you're using multiple layers. I had issue with it on a previous build where I used multiple layers on walnut. I took care to try to make it turn out better this time but it was still so so. I'll find the pics later for an example.
I finished rounding out the inside of the stems. I ended up using my Dremel in the end to finish it up. The pencil grinder was a bit too big. I've been mostly using the random orbital with interface pad to sand the inside but broke out the long board again for the inside of the tumblehome section. Standing the boat up to sand it it's crazy light right now. Sadly it's going to get so much heavier.
I tilt my hulls as you did.
Makes it so much easier to get at the tumblehome, and actually seeing what you are doing.
Carpeted saddle stands work great for that.
Looks like you have the sanding part down !
TPG, I think only the top couple of inches of stem will be exposed after I put in the float tanks. Just trying to do what I can to keep the weight down but yes that's a crappy spot to work in.
As for the S glass over dark wood here's an example of a couple of layers over walnut. Up close you can see it pretty easily with the dark wood under it. The circle in the center was from an air bubble I had. I thought I'd just drill it out and put some fresh epoxy over top to hide it. That idea didn't work out so well. It's definitely clearer when I apply it on the flat where I can use a squeegee for the initial wet out. There might be a trick I'm missing though.
So I was finishing up the last of the inside sanding yesterday. I was moving the boat around and heard a loud crack as some glue let go on the bottom. I quickly moved the foam supports out to the ends and put the center from back in. Lesson learned, don’t move it with a form in place and get a helper. It changed my mind in a fraction of a second about having a light weight boat. I think I’ll be adding that extra layer on the football. It also has me wondering about the strength of hanging the seat from the gunnels. I was planning one full layer plus the additional transverse layer in the cockpit. I’ll make the filet joint at least 1/4” wide along the inside of the tumblehome section. You guys think that amount of glass is enough to support the seat?
I wouldn't sweat it. I built a super light hull where a glue joint cracked down the center when I set it on the floor and the very flexible bottom pushed in (only the outside was 'glassed at the time). That boat, as I recall, got a single layer of 4 ounce cloth inside and out and was built with 5/32" strips and it was fine once the inside was 'glassed.
Once the inside is glassed it will make a world of difference. I still think you'd be fine with a single layer inside and out so just do whatever makes you feel best.
If after you get the hull in water, and you have a lot of oil canning, you can always add that 1/2 layer.
For a solo, I prefer a pedestal mounted seat. Other seats I mount to cleats that are epoxied to the hull, sometimes with added glass reinforcement
It's hard to get away from the idea that the wood isn't actually providing measurable strength to the boat, that all comes from the 2 layers of glass/epoxy sheath, once completed.
If you are worried about hanging the seat, add a layer at the seat location or maybe take a walk on the dark side and consider cleats.
