Kite +6%
You guys think that amount of glass is enough to support the seat?
Seems almost like overkill to me.
Honestly, as stated above, I think you'll be fine but you have to be comfortable with the layup or you'll be timid about taking it on backcountry trips (where it's longing to go).
I think you'll be shocked how much stiffer it is with the inside glass but, and SG says, you can always add another layer if you're still in doubt.
So I was finishing up the last of the inside sanding yesterday. I was moving the boat around and heard a loud crack as some glue let go on the bottom. I quickly moved the foam supports out to the ends and put the center from back in. Lesson learned, don’t move it with a form in place and get a helper. It changed my mind in a fraction of a second about having a light weight boat. I think I’ll be adding that extra layer on the football. It also has me wondering about the strength of hanging the seat from the gunnels. I was planning one full layer plus the additional transverse layer in the cockpit. I’ll make the filet joint at least 1/4” wide along the inside of the tumblehome section. You guys think that amount of glass is enough to support the seat?
Yup. Early on, a guy climbed into a Wee Lassee I built. Heard the crack also. I double layer the bottoms of all my strippers.
To me ? the added durability is worth it.
As far as hanging the seat from the gunnels ? All but a few Wee Lassee's? I have hung all mine from the gunnels, and never a problem.
That extra layer is optional, in a kite ? Maybe a good idea.
Got the fillet joints done and the seal coat completed. I used my wife's icing bags and the disposable wooden spoon again for the fillets. I only mixed up 2 pumps of epoxy this time instead of 3 when doing the seal coat. It allowed me to get it on thinner by getting it all on before the pot life timed out.
I'm sure an icing bag works better but for anyone else reading that doesn't have one laying around I've had good luck doing the same with the corner nipped of a zip-lock baggie.
The boat is looking great. Can't wait to see the inside glassed and trim going on.
Gamma, the masking is for the fillet joint. I find it helps keep the mess to a minimum but more importantly it acts as a guide to get a uniform width joint. I made the joint slightly wider in the cockpit and tapered it towards the ends. I also added a little filler at the ends where the tumblehome tied in and it was uneven. With either the icing bag or a ziplock bag I find a 3/8 wide cut at the end just about perfect.
In the spirit of full disclosure I should share an oops I had. I was using my random orbital and interface pad cleaning up around the bow inside stem. I had my headlamp on which while it gives great light you miss details sometimes when it points straight down. In the first picture everything looks good but in the second with the light at a different angle you can see I've removed way too much material and am dangerously close to sanding through. I'll be adding an additional patch of glass there to strengthen that bit.
@stripperguy roughly how long are your float tanks?
Not sure if i would add air tanks. Your boat stays afloat without them and is serious stuff you need more flotation then there is in airtanks. That where my toughts on my home build. And on all 3 wooden canoe i currently own. Airtanks on composite boats yes please if they are used on friendly waters where chance on capsize is low. In rough conditions i want a lot of flotation (airbags, big airtanks or strapped in bags/barrels)
Agree with Dutch, I've never added float tanks, I have submerged cedar strips on purpose many times, have always been able to self rescue. Plus, you have done such a beautiful job on your internal stems, why bury them under a chamber?
OK Bulkheads or not ?
Stripp[ers will float, when filled with water. push down on them with little pressure. They will sink, and take a long time to return to the surface. I have actually tried this.
Flotation chambers will bring the hull to the surface almost immediately.
If you plan a Wilderness solo trip ? Go with bulkheads.
As for the size of my flotation tanks ? Mine are about 24" long depending on the canoe size.
I have a thread way back somewhere. That gives details on how I measure for fit.
I found the thread, on how I build my Flotation chambers.
It's in my Nokomis build thread.
Sorry for the Photobucket interference !
Direct link to page #6 which discusses the float tanks
Thanks for all that guys. I didn't sand my ends with the intention of using float tanks. I'll have to think about it.
Well, I just went out to the garage to measure the decks and bulkheads in my carbon copy Kite.
Haha, the trick's on me!! I don't have any decks or bulkheads. Goes to show you how much I've paddled this past season...Don't even know my own boat!!
Anyway, I looked back on build photos of my stripped Kite, I'll add them in here for clarity.
Decks I kept a couple inches below the gunwales, bulkheads are roughly at the second form, each end.
Decks kept lower to not interfere with the foam/carbon gunwales, mostly, but also to fit better with that creased tumblehome.
The main reasons I like decks and bulkheads are four fold:
1. Hide a multitude of sins.
2. Provide tremendous strength increase.
3. Flotation, duh.
4. Provide a convenient step/foothold when breaching beaver dams. (I do that quite frequently on my infrequent paddling)
Bulkheads and decks are stripped from WRC, sanded and glassed both sides. Bulkheads were epoxied in place with Cabosil thickened epoxy, glassed in place on the inside, in case they ever get kicked hard.
Decks and bulkheads glassed to the inside of the hull all around. Decks epoxied in place on cleats that were epoxied to the hull. (again with Cacosil thickening)
Pics below, as mentioned.
AP1GczMrtgQSg1BM0gEL5R22sNe4RhJ86bU6IhiHQgIQW3N4v7cFLoCvNcJ9uqILWSoWpFiw_F963CxnXhhqd4iNsl255mhjbWb0Ilc1q-l7FFr6iHMaxOYHxeH276hVQOVsuY80mLcS_29q-T3FaOcAt4xoLA=w1339-h896-s-no
AP1GczMJGlHRhdpwhKFE9nYE7JoemotIdfzxbgDTZMZjYZkbhFNzUuF4KsGkElqGiUD2FSOGo4AMc4dNNLru5s3twBDRwB7iS3j28M6EWSEGwkC-aYm-xFKiXjv_1aGw9e0LqU_qylNQo5pTaSzueGN_cqhyfg=w600-h896-s-no
AP1GczO0qIuDhC7PvKvz7jK7UW8P6SlcbNDj4P9CNriGeGXnxa6qd8T_A6BIUTm1YgEsWO3jKUSWdP4Nit_bvZY_MipihM0TXnHi_khaYuseT7c5T79Zf3Yxe8e-tSoqlTIxR7kd5_QcEGrrxR3NMWT4JuMlcQ=w600-h896-s-no
AP1GczM314y3gceYpYTSpV450rZD-_3V7jPmIEAIOkAdz_yZ1wYRJOd5m1i70uLN1Kb60UThk_FOseScVEDtCdpJsTswLlJ8K1-3bD4DdBhe0ZeOMRi1m3DIQUf4NlJBCrIzbLWv1AADTYG2sbqe9g6g-VLOag=w600-h896-s-no
AP1GczPsLSzF8TYG1oWndh7oi1bT4l8w9-94qnz9F_w-8-t9Xa1rs7mXcas_TvlTN4ifAgcHjxlXgYESat98DKBf4yVhgCRuW0RmvPtMBkW5gWN1vQNjvs7v954eGwRupXrRwGZojsnYostjvX0mOBAwoQEWDg=w1338-h896-s-no
Floatation tanks might add a little more buoyancy in a complete submergence, but they will not make a huge difference in self rescue techniques. As previously stated, if concerned in whitewater situations, put airbags in it. If you are tripping solo with a load of gear, running rapids, chances are self recovery is not going to occur on the water, but more likely on shore. If you dump in whitewater andyou tie your gear in, the canoe will float. if you don't tie your gear in, the canoe will float. How do I know this? I have encountered both situations, in a cedar strip Osprey and the Raven.
My other thoughts on bulkheads are that I often stash light weight things all the way in the bow or the stern, things like removable carrying yokes or pieces of loose gear I don't want rolling around. And as a final thought, not to be provocative, and clearly just my own preference, but I find bulkheads unsightly, I think they take away from the "canoe" look of the canoe.
The pic below is of my Osprey (left), basically the same canoe as the one you are building, and the Raven on the right. I built the Raven after the Osprey, and didn't even bother with decks.
Stripperguy, I really appreciate you taking the time to dig out those pictures. They help a lot.
Mem, you keep calling your work butchery but it looks very nice to me. Also how many canoes have you built now? The more I read on here researching various models it seems you have built that one too.
In the end I've decided to stick to the original plan and go with the tanks. It was a tough call since Memaquay's stems look really good there. Thinking I probably should have just left the walnut proud and called it good. When I ground it down I marked up the wood a lot on both sides. So this falls under SG's reason #1, hides a multitude of sins. I had planned a couple of details for the tanks as well. Not as fancy as Jim's but something similar.
I had planned for glass on Monday but life got in the way. Glassing tomorrow instead.
When setting up for glassing I used foam cradles out near the stems where the boat is already tough. I didn’t want to risk the hull deforming from it’s own weight and then me glassing it permanently to that shape. I masked off the edges and pre-laid the glass. I would just pull it back to wet out the overlaps. I’m not sold on using 30” glass sideways. It’s finicky getting your overlaps looking good and keep them straight when glassing. It did allow me to save a big enough piece of 60” 6oz though to do my son’s boat so that’s good. I did a butt joint in the center of the boat so I wouldn’t have a crease underneath me but otherwise did a 1.5” overlap on the other joints. There is a transverse piece of 60” 6oz s-glass over top of that butt joint to tie it together and help keep the cockpit smooth and tough that I put on after. In the stems I laid a couple of pieces about 6” x 30” that I tapered the ends on. They sit in the bottom and I cut a couple of pieces 24”x 18” for the top. I folded those to 12” trimmed the corners to match the stems. They overlap the bottom and then are overlapped by the last piece of 30” 6oz s-glass. That last tranverse piece of 60” was a right pain. I waited until it was almost tacked up but there were still sticky bits. I fought that piece for about 2 hours. Re-wetting the sticky spots and fighting wrinkles. In the end it looks ok, still some wrinkles and a small ridge at the butt joint. My sharpie markings for the overlaps also ran down onto the yellow cedar on the inside with the epoxy, stuff happens. I have one more fill coat to put on tonight.
I forgot how forgiving fiberglass is with your wood work. All the gaps seem to disappear nicely. Even the all the rough bits in the ends were substantially muted. Not the most fun day.
