Wilderness Express AKA Chestnut Pal
Geraldton, Ontario
Many years ago, I acquired a set of plans from Carrying Place called the Wilderness Express. The fella told me they were essentially a copy of the Chestnut Pal. I build several of them, ranging in length from 16 to 17 feet. I found the 16 footer to be a good solo, but unless you had two lightweights without much gear, it wasn't much of a tandem tripper.
Fast forward to now, I went upstairs in the high school wood shop and dug out the old forms for the Pal. The Outers club is looking for a solo canoe, and I'm thinking some kids in my senior woodworking class might build one. However, I don't want to build a Raven or Osprey or something with difficult knuckles and such. I recall the Pal was a pretty easy build.
If I shorten the stations from 12 inches to 11, I come up with a canoe around 14 and a half feet long. However, the center station is around 35 inches across. I'm thinking this would be a beamy thing for a solo, but if I set it up solo, the neophyte paddlers probably wouldn't be able to tell.
I don't want to build new stations for a new canoe, trying to keep costs down, as there is basically no budget.
I also did a test panel with the cheap table top epoxy you can buy on amazon, for ridiculous prices like 4 gallons for 250 bucks. It was a little thick, but it actually looks good and seems tough.
Any thoughts on a beamy tub built with table top epoxy from amazon?
You're not the one that has to paddle it so I say go for it!
Kidding aside it will probably be fine. Like you say, a newbie paddler probably won't know any different.
I am looking forward to (hopefully) see this project come together and watch you and your lucky students make this canoe.
Is the art teacher going to have a hand in letting students paint it like you did with the paddles?
I have fond memories of Mr. Clemonson & Mr. Gunderson involving my classmates in some wonderful woodworking projects when I was in school. Wish we had made Wannigans, pack boards (like Canotrouge’s Trapper Nelson masterpieces from a few years back) and canoes.
Our school was too poor for a lot of things, but wouldn’t it have been great to have had an industrial sewing machine course in making tarps, tents & packs.
I was too late in thanking many my good teachers for the education I received. The ones that were still living when I called to thank them must have been shocked that I had turned out somewhat better than they had thought I would.
You could eliminate the center station to narrow it down a little.
That's a really good idea. I had measured the the two stations on either side of the centre, and they were around 33.5.
If you can do this, 33.5" is a much better beam for efficient paddling than 35" for a 14.5' solo canoe. It still should be plenty stable enough at 33.5" beam for a tyro. On the other hand, if you just want a very stable "platform" canoe for stand-up fishing or such, then a 35" beam is appropriate.
I think you could eliminate the center station as DB suggests or narrow the center station to 33.5" and shorten the station spacing. Maybe eliminate the center form & one of the stations beside it, use the other 33.5" form as the center and maintain the original spacing? That would shorten the canoe by 2 feet giving you a 14 foot solo.
Will it be used by the Outers? If so, maybe just eliminate the center and build it 15 feet long to allow for gear?
Yes, the idea is to give it to the Outers program when we finish.
Boreal, funny story told to me on Friday. One of my colleagues overheard the grade nines talking, they were saying that the teachers were nice to them because they had to be, it was part of the job. One of the kids piped up and said "Not that old guy teaching woodworking, he actually tells you when he doesn't like you". Made my day, lol.
I'm on March break right now, a week off from school. When I get back, I am going to start the Pal solo build. I've got a couple of good kids for the entire afternoon, so I'm pretty sure they will be able to finish it before the end of June.
The forms for the Pal start with one centre form, then matching pairs all the way to the bow and stern. At first I was thinking of just eliminating the centre form, as suggested by Dogbrain. I measured the next stations, and they came in around 33.5, which I still thought was too wide. The third set of stations comes in around 31.5. I was thinking of making an extra copy of that station to serve as the centre. That would give me roughly two feet of the hull that would be identical, no variation in rocker or hull dimensions. I'm going to aim for total length around 14'6". I'm going to use both internal and external stems, of course. I'm going to pick up some donated cedar this week, but I'll be nixing the idea of the table top epoxy, I'll find the funding for the good stuff somewhere.
Looking forward to the build, if it paddles well, I might have to make one for myself, lol.
This is a great idea. The narrower hull will make it a much better solo canoe. Increasing your station spacing to roughly 12-1/2" brings it to about 14.5'. It should end up being a stable solo canoe with plenty of displacement for a tripping load. Once you build the hull you may even be able to get away with pulling in the gunwales in the center a little bit too for more reach. Are you planning to reduce the height any? Looks like it will end up around 13.5" in the center and 21" at the ends.
Hi Mem.
This sounds exciting with all that tweaking. I was just thinking that maybe it would be better to just scale the forms but only in the width dimension to make the canoe as narrow as you want it but avoiding the flat or no-curvature section you get in the middle from the method you describe above.
If the lines were scaled down to the width yo want you could then re-cut and use all the forms and just space them out to get any length you want. The fair curvature of the hull would be kept intact this way, but you will no longer have the original forms of course.
I had thought about doing something like that, but two things deterred me: I'm probably not smart enough to do that, and I wanted to still have the full Pal forms in case I build another full size Pal. It will be interesting to see how it performs. Got the second set of stems glued up today and one of the kids is working on refurbishing the strong back. Hopefully have the forms up next week.
Latest update.....I got one of the kids to mount all the forms, with three #2 stations in the middle. Total length came to about 15 foot and change. I didn't like the looks of it, too square in the middle. I took two of the #2's off and decreased the side profile to be in between the #2 and the #3 form. Nothing scientific, just used the existing forms moved in an inch or so and traced. Very sexy looking now. Decreased the height of the stems by about 3 inches, might regret this, but still able to fix it if i change my mind.
I've got a really good student who has milled most of the strips and is now stripping the canoe. The cedar I got was only 5/8 inch thick, so the strips are quite narrow, but the kid is making good progress. He's a natural. only needs to be shown something once.
There appears to be more rocker than I anticipated, if I measure rocker from the centre station to the end of the bow, comes in at over 2 inches. I like that, especially in a 15 foot solo. Really looking forward to getting this on the water.
Having never built with stems, I'm curious how you would add the length if you decide you've cut them too short. Aren't they the first thing that goes onto the forms?
5/8 x 1/4 strips? That's almost square! Definitely sexy and I like seeing the knots... Should look very cool when done.
The inner stem continues down another three inches, it would just be a matter of attaching more strips to the inner stem and extending them toward the middle, then trimming them up. However, for the moment, I think I will leave things as they are.
I have always loved big canoes with depth and carrying capacity.
But now I am older and like paddling solo much more. For certain things like trapping the old 12 foot Pack canoe is a great design. Canoes can be very personal. You are on the right track for expressing your personal preferences.
