• Happy Birthday Marco Polo (1254-1324), James Fenimore Cooper (1789-1851) and Fay Wray (1907-2004)! 🐼🪶🦍
What do you use for a table?
I have an assortment of aluminum slat roll-top tables but after seeing someone else using it, this is what I bring on most trips these days: ALPS sidekick. It is a small stool/table that is much quicker to set up and take down than the roll-top tables. Besides making a good side table for holding a bowl of food and a drink it also works as a footstool for relaxing with feet up and a night stand when car camping with my roll-a-cot. The Alps table gets thrown on top of other gear in the canoe and can be set up almost instantly along with my Lafuma maxi-pop-up butterfly chair, even for just a lunch stop. Most of my canoe camping is one or two nights on an easy creek/river or a paddle-in campsite on a lake, not extended trips or portages.
That’s not unlike the one I made and I like the use of the strap. I have some old straps the I wouldn’t use to secure a canoe anymore I’ll cut one down to an appropriate size.
Thanks for sharing that Kahel.
I've been in the flattish rock etc crowd for a while.
But last fall we happened to end up at the lean-to on Follensby Clear Pond (Adirondacks), which had a high table built into the outside wall. I was deeply appreciative of a level surface high enough to stand at while cooking.
I agree with Chip that portaging in clears the crowds so I've previously shied away from adding furniture to the kit. Many tables light enough to pack are so low that I don't think it justifies the weight. @kahel 's DIY table hung from tree seems a great idea, being infinitely height adjustable as long as there are trees. I'll have to try making one!
@kahel a year later and I have a trip upcoming and am finally looking to make myself a hanging table like yours. Can I ask the dimensions? What radius did you use for the curve? Are you happy with the size and shape or would you change it if you were making another?
Flattish rock if available. On the ground otherwise. I am more comfortable sitting on the ground with various pots, food stuffs, stove, etc. spread out around me within arms’ reach.
For big western river we do not portage. We leave a lot of equipment in the canoes. Most of mine are not flat on the bottom either. We don't usually have good rocks around. Roll up table is worth its weight.
I made this last spring & it has been on one group trip. Left it home on solo/small group trips.
My back hates me when I clean fish hunched over. This table can be set up at any height (~elbow is great for processing fish) and is rock solid. Properly set up there is no give, up, down or sideways, and I can clean many fish in relative comfort. One might be able to use it as a chair, but that is probably pushing it.
A change I made this year since this photo was taken: cam straps to go around the tree instead of paracord & amsteel.
It goes in on our trip next week; 5 of us.
Weight is 3.5 lbs. Wish it were less.
Like you I've never felt the need for a table and I'm also a minimalist chef. Food prep amounts to counting handfuls of ingredients dumped into a pot.
Rocks, tree stumps, and the ground all serve as a table as required. The uneven surfaces appeal to my inner bad boy. I like the sense of danger.
