• Happy Groundhog Day! 🦡🌡️❓🤔
Aluminum Canoe Rigging
I have been rigging a Alumacraft QT17C for racing. This one this specifically the Texas Water Safari. But this can be used in any race as far as I know as there are no exterior hull modifications. As far as which aluminum canoes work best. The Alumacraft Vouyageur is the sought after canoe. With its lowest weight out of Alumacrafts lineup. But they are only produced every so often. See the chart to see the weight difference between models.
The first thing I do is strip the canoe of everything inside. Taking a 3/16” drill bit and drill out the rivets on the decks and the seats. Parts of the decks will be reused so do not toss those just yet. Seats can be set aside will not really be using them. Take the thwart and yoke off with generally a phillips and a wrench. Now left with the bulkheads I take an old flathead screwdriver that I have sharpened. And work the tabs away from the canoe walls and then turn the screwdriver perpendicular to the tab and slice the tab down to the rivet. Then work it out and around the rivet. Do this for all the tabs. Then remove the foam. I had timelapse all this but my phone died and I guess in the process did not save the video. This is the best picture I have of the blank canoe.
So now I start with cutting down the decks and installing those. You want to find something to create a smooth arc like in the picture. And go ahead and attach those with some 3/16” pop rivets.
At the time of building this canoe. Wenonah did not have any sliding seat frames or foot braces. I generally weld the sliding frames anyway but for people looking to buy or use the measurement that I’m using. Beware that if you buy from Wenonah then your measurements will be different.
I use 1” x .058 6063 aluminum tubing for most of the rigging. The side tubes the “slide” are 1.25” x .058. The 1” saddled tubbing is set up 6” center to center for the Wenonah bucket seats. I also like a 16” center to center wide spacing on the sliding rails. Ample room for the legs up front in an aluminum. I get everything cut and preped for the slides. Then weld them. And I’m no professional, I know the welds look like a dirtdobber.
Next we will cut the rails and the cross supports along with the thwarts and yoke. After getting them cut you will want to heat the ends up that need to be flatten with a propane torch to anneal them. If you do not the ends will crack when you go to flatten them. You can also cut 4-2” long pieces of angle from one of the seats. The picture below is what I use. But like I said beware and adjust if using different sliders.
For the thwarts and yoke I use 1/4” rivets. I like a pretty smooth top gunnel and do not like bolt heads sticking up. Each ends of these will obviously be flatten about 1.5”. The thwarts will need to be trimmed at a slight angle.
The cross supports will have each end flattened. And you will also add the a piece of angle to each end that you cut earlier. The rails that the seat slide on will have one end flattened about 2”. The other end will be left alone and will rest on top of the cross support. Below is a Timelapse of me putting together the bow seat frame and installing it in the canoe. I also use solid rivets so the camera moves a little when I’m hammering them in.
Here is the canoe as it sets now. The original weight before working on it was 76#. As it is now is 63#. So the goal here is to make it comfortable, functional for a multiple day race and hopefully lighter. We still need to add the bucket seat, floatation foam/jug holder and foot brace. When I install these other things I’ll add on to this post. Until then if you have any question let me know.
Nice job, welding is a skill I never learned but wish I had.
On the stern seat doesn’t the cross arm for the frame of the sliding seat interfere with the knees/legs of the paddler? I often just sit on the front edge of the seat and if it is slid back then I can only sit in one position.
Clint, as an overall question, why do you use an aluminum canoe for TWS racing rather than a composite or plastic one? Cost? Weight? Strength?
Why do you remove the end bulkheads and foam? To add more room? Reduce weight?
Aluminum canoes on this list are beamy with blunt looking entry lines due to the limitations of the material. How can you plan to be competitive at all? Is the the race Al canoes only?
Thank you. The stern seat has the least amount of adjustment. And so far I have not seen anyone complain about the bar. If you have it adjusted all the back my knees are still right at the bar. I’m 5’4”.
I’ll kind of answer both of these questions together. The TWS has many categories you can race in.
Solo
Tandem
up to 6 person teams
So in each category you race against those canoes. In the Novice division you can only race there if you have never finished the TWS and can only be done in an aluminum canoe. Using an aluminum is also somewhat a gateway canoe for people. If you are not looking for the lightest out there. Some show up in a Grumman and take off.
Then there is just the straight up Aluminum diehards. And some of the fastest paddlers I’ve seen. If I remember right one year an aluminum won the TWS, overall.
My partner and I are getting ready for the Aluminum nationals this year that are held in Louisiana. Excited about that race.
Glenn, the other part of your question is yes. For the bow to make room for a foot brace, room and to reduce weight. Stern, just to reduce weight.
Love the questions!
Today I was able to get all the foam prepped for the boat. It is 2lb closed cell foam. Took and cut holes in it to match the water jugs that will be stored in it. Also cut channels in the bottom to allow water to drain.
Then took some aluminum angle and cut a slit down it. Cut some cross tubes flatten the ends and added some knobs. Now have a home made foot brace.
Using contact cement to glue down the foam jug holders and the spare paddle holder. Attaching the Wenonah seats are about the only this left to do.
The composite Wenonah seat I have is glassed to the aluminum truss. Bolt heads are going to make for some uncomfortable pain risers! Unless you plan to glue on a layer of foam padding or wear padded bicycle shorts.
Never really had a problem with it. The seat in the video are custom carbon fiber seats that I make and I'll use a flathead ss screw or an aluminum rivet. In my solo no foam. But in any that are for long distance there will be foam glued down.
The seats that go into this boat will be the plastic bucket seats. They have a spot on the bottom to attach to the cross tube. Then foam will also be glued to the top.
This is how the plastic bucket seat in my Prism is installed. My encounter had the composite seat. It was small and uncomfortable! I don’t miss it in the least. I’ve still got the composite seat that came out of the Prism.
Where did you get your foam, did laminate multiple 1in blocks or did you purchase thicker blocks?
Jacob, welcome to site membership! Feel free to ask any questions and to post messages, photos and videos, and to start threads, in our many forums. Please read Welcome to CanoeTripping and Site Rules! Also, because canoeing is a geographic sport, please add your location to the Account Details page in your profile, which will cause it to show under your avatar as a clickable map link. Many of the site's technical features are explained in Features: Help and How-To Running Thread. We look forward to your participation in our canoe community.
The member you're asking for info, @Clint, hasn't logged in here for about two years. If you send him a direct message (DM) from this site about your question, that will also generate an email to him that will have the content of your DM. He may or may not reply. Meanwhile, someone else here may have some experience with the question you're asking.
On a slight tangent...does anyone remember those 18'6" all aluminum competition cruisers? I think they were Beaver River something or other. This would be in the late 70's or early 80's.
IIRC, there was even a special class just for them in the General Clinton race. I was surprised that they never really caught on.
Yes, they were Beaver canoes made in Missouri for a few years in the late 1970’s into the early ‘80’s. I met a guy from Minnesota a few years ago who took my 40+ year collection of Canoe and Canoe/Kayak magazines. As I recall, he had collected 6 or 7 of them - he was hoping to get at least one of every model they made.
