• Happy Invention of Scotch Tape (1930)! 🏴󠁧󠁢󠁳󠁣󠁴󠁿🧻3️⃣🇲
Solo on the Light Side
If I attempted that, I would probably end up having a fever dream resembling an LSD trip, where geometric designs danced in my sight line to the tune of some obscure Pink Floyd tune, like Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a Pict.
I admire your perseverance and they do look very cool. When I couldn't get the sides of my decks to line up with the gunwales, I stopped using them, so now I have deckless canoes, but the grab handles are sanded, at least, and once they get banged around a bit, they get dark spots on them, which greatly enhances the mediocrity.
I bought my wife a bunch of really original Valentine's presents, and a neighbourhood couple was visiting. We didn't know that he had not bought her anything, so my wife was showing the gal her nifty presents, and the neighbour lady's face kept getting darker. She gave her husband a very evil look and he said "hey hold on, I caught you four walleye out ice fishing for your Valentines present", at which point she growled at him "They are still in the sled, frozen and uncleaned". Later that night, my pal said to me "why do you have to wreck it for all men, dial that sh!t back". I'm not saying your canoe decks are in the Valentine's present orbit, but.....well.....you're making us all look bad, LOL!
Given one of the goals for this build is to maintain the same weight, while extending the original 15' design to 17'. Weight is going to be part of every idea/decision made along the way and sometimes you try stuff that is a bit out there, which also means there is a chance something is not going to work out like you plan.
Thwarts aren't a big part of the weight budget, but since every part is being considered ... I had an idea for them ... BALSA and fiberglass
So here is my chunk of balsa 2" x 3" x 36", very light, very pale and very boring from a wood visage vantage
First issue is that balsa is quite soft and these are going to be bolted to the gunnels, so i will need some hardwood, at least where the thwart terminates and it gets bolted. So the balsa gets milled up to 1.5" x .75" pieces, a taper cut just over 4" long is added and cherry blocks to fit those tapers are cut (FYI that is more than a 10:1 skarf, so it is structural)
Standard epoxy procedure, to glue the blocks on, coat with unthickened epoxy, followed by a thin layer of thickened epoxy
after clamp up we have a really awkward looking balsa/cherry piece
The extra cherry is taken off with the radial arm saw and then passed through the planer to get it perfectly flat. I think using my bandsaw would have been easier and safer for removing the chunk, but I discovered that using the blade on brass (as the package says is fine) really dulls the blade for wood, it needs to be changed and I got lazy.
The radial saw was setup to rip the chunk down the middle
and then make the cut, the pic shows what I was after ... the cut on the left side and each piece rotated 45 degrees on the right, giving a nice symmetrical triangle cut on the planer flattened surface (so ready to glue)
There were a few cherry strips from another project laying around, so I added one to the middle, just because it was needed visually IMO
Spring clamps are a nice method for epoxy clamping, they don't over pressure the joint
One side gets roughly flattened, then on through the planer to finish the job
Small taper added with the radial, this is both to trim a little weight and I think it looks better
A quick round over on the router and the blank is ready for sanding
and now the final step, adding the fiberglass. This 2 oz sleeve material I picked up along with shrink tube for epoxy layups .... this was quite expensive, but I wanted to make this work
and after setting. 1) I ordered the wrong shrink tubing 2) the glass sleeving doesn't get fully clear .... both learning points, but frustrating
I am not going to use these, so I have to make another set. You have seen the general construction technique I am going to use, so I will skip through the second set in less detail. These will be a conventional set with no fiber glass and will use red cedar, ash and cherry.
This is the assembled glue up and tapers already cut. The thin white strips are ash and the taper is cut to just end at the strip and not cut it. The ash strips are basically the weight bearing rails, so leaving them intact is the priority, the inner cedar strip is thicker to allow for sufficient hardwood territory for the eventual bolting on.
and a few more cherry blocks
where I discovered the dull bandsaw blade
and back to the radial for the trim instead
cleaned up in the planer
Setup and cut in two (again), you can see a small saw cut line on the right pair, that is from the band saw wandering, fortunately it will disappear with the epoxy glue up
You can see how even the wedge shape is here
Dry fit for glue up, adding cherry rail to centre
and the epoxy glue up ...
Quick sand with 80 grit on a flat sander to get a mostly flat surface
then clean up with the planer and taking them to the final 5/8" thickness
Rounding the edges with a 1/4" round over bit
adding in the edge taper detail using the radial saw
and the finished product after sanding with foam block (80/120/180/220), ready for finish
This was an interesting experience, I had high hopes for the balsa fiberglass experiment, but visually it just didn't work with the sleeve I picked and the I doubt the shrink sleeve would have made much difference to the cloudy presentation. Weight wise the 2 thwarts produced weighed 135 and 150 grams (4.7 oz/5.3 oz), the difference likely epoxy application rate. These appear to be quite stiff and strong, but I won't be testing then to breakage to find out.
The replacement conventional pair was interesting, I like the general appearance more and the weights came in at 137.8 g and 137.8 g (4.9 oz), so pretty much identical. These are also quite strong, with just a little more spring ... quite suitable for purpose IMO. The outside rails are rounded over, but leaving the edge entirely covered in hardwood, this is for wear ... the hardwood will stand up better to hands and ropes that get slung around the hand holds from time to time.
The second set was made from saved scraps of other projects and did just as well as the made for purpose (read that expensive) versions, lesson for me is to not get too clever, there is not a lot of weight saving to be had in this area, so just do a simple plan for hardwood placements and don't over size and you will be in light weight territory.
Those look nice! I've done cedar/oak laminate beams before (seat rails and sliding mounts) and was (continue to be) well satisfied with their performance. Mine didn't turn out looking that good, but I didn't put in the effort, either.
This will be a bit of a cleanup post to finish the handles and thwarts part of the build.
This part of the build is a bit chaotic for me as I near completion, have to fight impatience (generally, impatience = lesson) and usually there is work progressing on several smaller things at the same time, so there isn't bigger things to write about ... most stuff is in pieces.
This post will cleanup the handles and thwarts to the installed stage (finishing/varnishing not done)
First up, handle material glueup ... the colour layout is the same as the thwarts, combining thin ash rails for strength and edge durability, narrow dark cedar for spacers and a cherry centre rail. This will be a straight glueup, just making a longer piece from which the hand holds will be cut. I find the spring clamps are pretty useful in applying just about the perfect amount of pressure for clampup and they are so much easier to add and remove.
Cleaned up and thickness planed to .5 inches, you can see the colour scheme and with this much hardwood the handles are very strong.
Next is a quick edge routing with a .25" roundover bit and you get this final profile. These handles are a little beefier than my normal ones, when the new vehicle gets here, the handles may be a tiedown point, so a little beef is in order IMO.
The inside gunnel flat spot is about .5" deep. so some .5" stock was made up from that extra cherry piece (gunnel leftover), so that all the cherry matches (and fits). There is only about .25" thickness on the inside face, so small "extra" pieces are added for mounting purposes. The gunnels near the the stern/Bow are quite angled due to the canoe design, so some "adjustments" are made to keep all mounting surfaces flush.
In this pic, 2 extra pieces are being added to mount the bow hand hold, again spring clamps are my choice. If you look at the bottom of each extra piece, they have been angled slightly to present a flush mount surface for the hand hold.
after clamping
and then cleaned up a bit
Vertical Forstner bit to create a parallel surface for screw (flush mount, hole goes straight down, not slanted)
handle fitted and mounted
The hand holds use a traditional "under the gunnel" attachment, but for thwarts I like "over the gunnel" as it leaves me more space to slide gear under.
The gunnel angle at the thwarts is not much, but it still needs some attention to create a flush mounting surface. The "extra piece" is mounted about 1/16" above the gunnel lip to allow filing the area flush after glue up.
To make the flush area for the gunnel to mount, I like to use a small shaping rasp, mark up the area and make it level
and try the thwart to check the fit
For this project I am using 4 mm flat head bolts, the head is just under 3/8", so I first make a flush surface score with a forstner bit, so the bolt head sits flush, then proceed with boring a 4 mm hole through thwart and "extra piece"
Gluing these bits on is why the gunnel doesn't get finished until everything else is done ... I did it early once and fitting bits to a rounded surface is not fun. These mounting pieces will get a full cleanup and sanding when the gunnel gets finished, for now this gets the thwarts and handholds mounted.
Part 1 - this post exceeded the photo limit
The seat on this build was a bit of a design challenge. I find my usual seats aren't as comfy as I would like, with the relatively narrow cross members causing some discomfort after a few hours.
Last season, the seat in my current boat was removed and a bucket seat supported by birch ply rails was temporarily installed just to see how it would work. The seat was quite comfortable as expected, but I found it really locked me to the boat centre and interfered with body shifting to respond to waves and water conditions. This actually scared me a little out on the lake, things got a little bouncy as waves hit ... so no bucket for me.
However, the rails were a surprise to me, very light, compact and gave me an idea for how the new seats would be designed. Around this time a friend (yes Tim, if you ever read this, your seat idea spawned this one) asked for some construction critique on a seat he was putting together to serve both kneeling and seated paddling. His alternative view and my current design gelled into a wide railed, multi layered approach, which hopefully softens the impact of the rails after hours in the seat.
I have cherry set aside for the seat, but since there has been change in seat design, thin milled 2" ash strips are going to be used instead.
Last year I milled up a batch of ash strips for use in making a batch of paddles (planned after this build), these are just over 2" wide and ~3/32" thick. They are in the rack, it is winter ATM so I am just going to use what is on hand.
First step is to determine the CoB (Centre of Balance), I do this with piece of stock that fits under the inside of the gunnels and move it around until the boat balances, marking each side at that point. I double check that each mark is evenly spaced using a scrap strip and measuring along the gunnel from the end of the decks. The marks are adjusted if required and the CoB rechecked.
Determining the CoB is the first step in seat construction (for me), the seat forward edge is 7" aft of the CoB .... now I can mark out where the seat is going to be placed and determine the widths for the front and rear seat rails. The rails will be bent lamination's and give gentle curves side to side and a slight dip to the front to help with leg pinch.
For the lamination's I start with some 2" x 6" material cut into appropriate lengths for the rails and cross members, for 2" strips they will need to be doubled up and planed to thickness
next the curves are drawn on for each
The new bandsaw does a great job of staying on the lines and giving perfect vertical, previously I used my jigsaw and sometimes got a little waver and not a vertical cut on thicker pieces .... both work and give acceptable results, but the bandsaw is so much better for this.
The rails will use a 6 ply construction (~.5" thick) and I can get several pieces from each of the precut strips, 5 piles of precut strips 2 for main rails, 2 for side rails and 1 for wedges I plan on using
These will be epoxy lamination's, wetout with unthickened epoxy, butter with tinted thickened epoxy
Lamination's are complete, but are a bit messy
To get one clean edge, I just made a small clamping jig and passed them through the saw, to get a clean edge to work from
The pieces got taped together, used the planer to cleanup the remaining messy edge and size the pieces to an identical width
The dip on the side rails is about 1", so the front lip dips down and relieves pressure on the back of the legs, this isn't really apparent in most of the photos, so here is a shot of the piece and the mould, you can see the 1" dip pretty clear
The seat is going to use simple lap joints, each backed up with the wedges I mentioned. This for looks, strength and comfort ... lap joints aren't particularly strong, so backing the joints is likely stronger, a tapered transition will lokk better and not having a hard edge on the side will likely avoid discomfort if I ever get over that far. The reason this gets mentioned here, is that since I was making the rails laminated, I also made the piece for rails laminated ... this was not a good idea, the laminated rails are quite difficult to shape and all the exposed edges look ... ummm ... ugly.
So a quick detour to make up some plain ash pieces for wedge making
This offset jig made short work of making nice wedges safely ... another time that the jig takes much longer to build than the operation it does.
Now the rails are measured and the wedge locations all marked on the rails ... there are wedges both top and bottom of each joint, wherever there is a 90 degree transition
now each wedge is glued in place, 2 for each rail
The advantage of pregluing the wedges, is they then become assembly guides for the seat. Each flat end of the wedges is cleaned up prior to final glue up. This is just prior to glue up
Joints are coated in unthickened epoxy, then lightly buttered with tinted, thickened epoxy. They are put together, shock cords as clamps for and aft, then spring clamps on the lap joints
While that was setting up, I decided a few dowels might be a good addition. A Red Oak chunk from a previous project was selected as the donor, some guide holes were started with a forstner bit and the piece clamped down to drill the dowels
The cutter I use yields 2" x 3/8" dowels, I use a slow rpm heavy duty drill for this, battery units and most regulars drills just aren't enough torque
Two ways to separate the dowels, twist with a screw driver or cut. Never had much luck with twisting, so I normally just cut at the 2" mark to release the dowels
new dowels are ready
Made up a marking template and marked where the dowel locations on each corner
Rough shaping and joint cleanup prior to boring dowel holes
Forstner bit to drill nice clean hole for the dowels in each corner
Setup a work area, mixup a small batch of epoxy for the dowels, as an aside ... I stopped using pumps and switched weighing the epoxy, find a lot more reliable, these are the charts I use
with the epoxy mixed up, coat the holes and dowels with unthickened epoxy and allow to stand for a few minutes (to soak in), then thicken and tint the remainder to peanut butter consistency .... coat each dowel and slide some around the inside of the holes, then insert all dowels so they protrude on the opposite side. Wipe around the base of each dowel to make a small fillet all the way around.
Each dowel gets flush cut
then the seat gets a general sanding to smooth out the transitions and dowels
This assembles the seat, but it still needs to be installed. I started using cleats for seat installs and will use it again for this build. I made a side rail template from the gluing jib form and drew in the profile line for the cleat mounts. I am referencing off the bottom of the dark strip, the corner formed by the tap is where the seat cleat corners need to land. The blocks are positioned to show that the front edge is too high due to the side curvature, this far down, so they must be cut to yield a horizontal surface for the seat to land on.
aft cleat marked for cutting
after cutting the cleat is marked to make a notch for the seat to land on
a series of narrow cuts made to help get a clean chisel out of the notch
Continued in Part 2 - next post
Part 2 -Seat construction and Install
The notch cleaned up and the bottom "extra" material marked for removal. This material doesn't really contribute much to the cleat function, so I consider it extra weight, so I take the time to remove it, additionally, I think it improves the aesthetics.
In the previous pic, you can see 2 lines drawn on the block end, these are fitting marks. When you place the block on the canoe wall, it doesn't match the curvature, just touches at the top and bottom. Two choices, rasp off that wood and get a good fit OR pack the back with epoxy and fill the void ... epoxy weighs about 4x as much as wood, you know I am fitting these pieces to keep epoxy to a minimum.
Once the cleat is fitted, a little more "extra" material is marked for removal
giving us the completed cleat
The location is rough sanded and guide tape placed to help manage mess when epoxy is applied. The little pencil guide mark is still just visible in the left hand corner of the notch, the block is held up by tape at this point, I am just eyeballing how it looks.
Last step before mounting, drill out for the threaded insert
thread the hole for the insert, using a 3 mm x 12 mm insert, the hole is 4 mm ... all standard metric threads, using these same 3 mm for fastening jobs on this build.
The cleat and hull are wetout, buttered and clamped ... there are two parts to the clamping solution, the wider piece in the notch, holds the cleat in position and oriented correctly, the the thinner piece is getting the clamp force from the spring clamp applied just below the gunnel. Also, I added a piece of tape over the threaded hole to keep it clean.
This is the seat and cleat arrangement
To do the seat markup, the insert is screwed in placed with a small nail, the seat is placed and lightly tapped to mark the location. (you can still see the pencil location markers in the notch corners, it is right where it is supposed to be)
The marked corner is drilled and counter bored for the marked bolt hole, then the bolt is added to hold the seat position, the next bolt is then tapped and bored, till they are all done. Is the sequential boring really needed? It just seems whenever I do them all at once, one of them fails to fit, this way they have to fit.
All of the bolts are too long, which was actually planned, I can always cut them to size
To install the threaded inserts, I use a thin stick to coat the inside of the threaded hole and let it stand for a few minutes, then slowly turn in the insert till it is just below grade, leave to cure and then run a 3mm tap in and out to clear out any epoxy that may have fouled threads
and this is where the seat is at currently, once it gets a final sanding/rounding/varnish I will add the webbing and post that as a seat install post
The foot braces and stud kit were from Sealect, got them at Duckworks 2 years ago, they are a kayak version and were a bit lighter than the regular versions, sadly Duckworks is no more and I couldn't actually find this model elsewhere to give any reference.
The strips are all running parallel (flat) to the waterline, so I am just going to use the same accent strip used for the seats, as a placement guide for the foot brace studs.
The braces are 16", my inseam is 32", so placing the first stud 24" from the seat bow/leading edge means my foot will be about centre, on the foot braces.
These braces are a little different in that there is a bit of a slot at the front, which gives some "wiggle room" in stud fit. Usually the brace itself is used for positioning, but these are pretty much a flush mount, so I made up a substitute plywood spacer. The space will also be easier to use with my clamping solution.
The target area are roughed up and bordered with tape, the tape just helps control any epoxy that gets loose
To make sure the epoxy adheres to the studs, all shine is removed from both sides of the stud (you can see the stud kit in the background)
One small point, the stud base is flat, the canoe has a small curve where it installs, so a little adjustment is made to get a closer fit
and the result is a small bend which fits the hull better ... mark the top with a black dot, so you can tell how to orient on the boat
The epoxy being used here is System 3, so no sanding is required between coats (within 72 hour, but I am just overnight).
Place the studs in the spacer (orient black dot up), then wet out the hull and backside of the stud with unthickened epoxy, thicken the rest of the batch with cabosil (fumed silica) and lightly butter the backsides of each stud. Press into position and apply the clamping solution (same as seat cleat clamping in this case). Don't overdo the buttering, you want to partially fill the stud holes, if you do too much, you will need to clean then up later ... so be lazy like me and make it easier, lol
Once setup the stud hopefully is about like this
Now to get ready to add a small fiberglass patch over the stud to finish and add a lot of strength. I use ~4" squares of fiberglass (in this case 4 oz S glass, same as used on the boat), cut with a fabric rotary cutter. To install over the stud, do not cut the fabric, just use a pencil (or similar object) to open the weave. Once it is placed on the stud, it will conform around the stud base provide a stronger support
Mix up a batch of epoxy and split once mixed, thicken one batch and butter the stud, adding a fillet to the edge and filling the holes in the stud base
Apply the FG cloth (stud through hole made by pencil) and press the cloth into place, flatten the thickened epoxy under the cloth and do the wetout with the unthickened epoxy portion
The studs on this kit were a little to long
A quick cut off is in order, nut placed on stud just where it needs to be cut
Dremel operation, the stud gets pretty warm, the nut acts as both a guide and a heat sink
and the new length is far better IMO
Foot braces are installed, or at least the studs are
Only one item left before finish sanding and varnishing starts and that is the yoke. Since this project is one of exploring new ways to save weight and do things differently, the standard yoke I usually use is getting a make over.
The finished yoke looks like this (still needs varnish)
If you want to see how I got there you can finish reading this post.
The process is broken down into two parts, the shoulder support and the actual yoke base that attaches to the canoe.
This is the yoke I have used for the last few builds, the drawing is the shape of the inside curve of that yoke.
The shape is transferred to some 1/8" birch ply
this is used as a template for several more that are cut out of 1/2" ply
the forms are added to some scrap 2" x 4" with a dado cutout, the form height is trimmed to get the shoulder arc
and a check to see how we did
First strip established
palletizing tape was used as the clamping method, with box nails as the end hold downs
sanded smooth ready for pre coat
Precoat, fiberglass and final
Mark the cutoff line (inside of last form) and trim the piece with a pull saw
The new shell is removed, sanded, precoated with epoxy and 2 layers of fiberglass are added (FYI .. all FG is 4 oz S glass)
For those who are curious as to why I would take such efforts to make fancy strips for this, well I didn't, they just left over accent pieces, in the rack, from this build.
Setting the shoulder support aside for a bit and moving on to the boat support.
A piece of 2" x 6" was planned to 1" and the support shape was drawn out, you can see the shoulder support portion drawn in as a guide. The only practical limit on this shape is the form size and to make sure the neck notch is clear of the support.
1" strips of baltic birch ply and WRC are milled up for the side supports and glued up with TB III
The centre section of the clamping form is used, as a template to mark out and cut a ~10" NWC mid piece for the support
2 end piece of cherry are added to act as the gunnel anchors ... the tape is holding a small shim on the underside. The middle section also has a small shim, to position the pieces in the centre.
Out of the clamps and ready for a quick planer cleanup
cleaned up
ends trimmed and tapers added, we have a yoke support
Back to the shoulder support. Lower is the basic shape template, upper is template plus curve shape (shape on the curve is about 1/2" bigger all around)
Mark and cut the shoulder support
The next part is a bit fiddly and it is mostly about keeping track of positions on that curvy shoulder support. I did this mostly with tape and pencil marks, keeping track of how the shoulder support got oriented. The actual operation is making a small crater to sit the shoulder support in
Back and forth doing it bit by bit, finally yields a fair fit and enough area to be very strong when epoxied
Position tape pieces and support epoxy precoat done
active epoxy area on shoulder support marked and sanded
The bonding area and the shoulder support received thickened epoxy and the shoulder support was positioned and clamped in place (sorry, no pic). There was a small bead of epoxy around the joint, which I made no effort to remove, it is a very narrow area, it doesn't show and I was pretty sure I would make a mess trying.
Last step is to make a couple of width extensions to attach this to the canoe. Flared screw in thread inserts are used (1/4" - 20), installed from the bottom. these are installed before attachment, as it is a lot easier. This pic is one up and one down for comparison.
Then a quick spring clamp, epoxy attachment and we have attachment points
I like to use a nylon lock nut on the screw attachment, that requires a counter bore on the underside to give the nut a place to float, this required adding a small cherry piece on the top of the yoke attachment area, to accommodate the counter bore.
The finished product
The weight of the new yoke, at this stage, is 380 grams (~13.5 oz)
Weather is finally going to let me start varnishing, so looking forward to the test paddle.
At the stems, I usually manage to over squeegee the sides and create some air gaps like this
This time I just said "screw it", I am not going to try and fill the air pockets. Instead I scraped the area clean back to wood
Laid down some tape and sanded the area
laid in a new piece of glass
and put on the epoxy
It was quick and easy and I think it looks better, this will likely be my new "go to" for stem bubbles under the cloth , in the future
I don't recall where I got it (it was about a half century ago), but I've got a rubber roller that's just perfect for glassing stems or other hard to get at spots- It's about 2 1/2" tall by about 3/4" wide and is V-shaped, it' allows you to get right in the bottom oft hat stem and has enough give to follow the contours tightly while still hard enough to force the bubbles up and out of the stem area. I've used for fixing split keels and stems, reattaching float tanks, and even glassing in seat mounts and various attachments
now that I think about it, I think it was a glass installer who gave it to me to repair the float tanks on a half dozen canoes for a Scout camp
Been a very busy spring, I have been plugging away on the canoe, but been delinquent on posting.
Finally, the time to do the final finishing is here, I am going to varnish the interior and the decks/gunnels at the same time and then move on to the exterior.
The gunnels have received 2 coats of epoxy at this point, this step is completely optional, however I find that it seems to make the varnishing much easier and the results also appear to produce a better finish.
The prep regime is a light sanding with 220 grit sandpaper, followed by a good rub with maroon scotchbrite pads. The pads do two things IMO, they smooth the surface scratches (from the sandpaper) and they get into the dips and ruff them as well ... it is a good addition to the finishing "bag of tricks". I have Boatman53 to thank for the method, he suggested trying them on my last build, I did and I will likely keep them on hand now.
After getting the inside and gunnels sanded and rubbed, the exterior edge of the gunnel is taped off to keep a line between exterior and interior
There are 3 coats of high gloss, clear Epifanes applied with a sanding/rubbing, using 320 grit paper and scotchbrite pads between each. Cleanup between coats was with a vacuum and tac clothes till clean. The varnish was cut with ~10-15% with Epifanes thinner.
I almost always use some thinner in this varnish, it gives a bit more time to get the varnish on and the areas to flow together without overlap seams. How much time you get is a bit of a crap shoot, but the one thing I shy away from is higher temps, the setup is too quick and I always seem to get bands where the varnished areas overlap. So keeping the temps down and a bit of thinning seems to work well for me.
Each coat gets rolled on one way, spread with roller the other way and then tipped off with a Jen branded foam brush. Don't waste time on the application, get it on, get it evenly spread, tip it off and move on ... give it the max time to flow and level itself, if you play around you are just shortening the time the varnish has to level and give you a great finish. If you happen to see a fault after you have moved on, you are likely best to just leave it and address it with the next coat, playing with varnish after it has sat for more than a few minutes has never worked well for me.
This is after the 3 initial coats of interior varnish
The interior is now protected and shiny, very shiny ... sun in your face shiny, so that interior needs to be damped down a bit. For this, Epifanes matte finish works well ... normally the entire interior gets the matte finish, but I decided to try doing just the bilge area this time.
Two things in this photo, the "tape off" of the bilge area for sanding and you can see the deck has also been sanded. In line with what I said before, there was a fault in the varnish I didn't like, but the varnish was starting to set, so it was just left, resanded and I will get it now with the interior final coat.
Sanding/rubbing of the bilge area
Once the varnish is applied, the tape is removed immediately to prevent any edge issues with set varnish.
The matte doesn't kill all the shine, it just damps it down to a satin sheen, in this photo you can see how there is a lot of reflected shine on the right outside of the bilge, but not on the matte area. Just a note about what looks like a lot of "blotchy" areas on the finish, that is just the trees across the street reflecting in the finish
Looking the other way gives a different view
This is a pure vanity shot of the deck, I needed to redo the last varnish coat and I am pretty happy with how the finish and design worked
Moving on to the exterior, so close, planning test ride
The boat is going to be flipped over for the first time in months
Step 1 is to just angle it up on the cradles and cleanup up anything that was missed under the exterior gunnel area, there were a few clumps of epoxy, some varnish and a coupe of rough glass areas, all easily cleaned up with the carbide scraper
The gunnels are still pretty green for varnish, so I made up these blocks to fit in where the thwarts attach
and promptly redesigned as the gunnels wouldn't clear the strongback
The boat was previously sanded, so I just rubbed out the hull with the scotchbrite pads to cleanup any marks and smooth it all down
This is waiting to be tac'ed
The application method is to do an ~18" hunk of hull, apply the varnish with a roller vertically, then redo horizontally to level it all out, then a quick tip off with a foam brush (I know this is repeating). I believe the key here is not wasting time, a patch like this takes me under a minute to apply, just to put the "not wasting time" in perspective. The second key is not to try and varnish when it is too hot, again "too hot" for me is over 72 F ... it skins too fast and you get overlap bands where the new varnish patch doesn't flow into the old.
The hull can still look good, here is a shot at 2 coats
Looks shiny and you can't really see that there are bands at most of the overlapping areas, for the first couple coats this isn't too much of an issue because there are more coats coming and you can cleanup issues between coats. The final coat is a little more critical (if you are fussy that way) ... so I take a care to clean it up well, check the temp and forecast.
This is part way through sanding between the 2cd and 3rd coats, you see the maroon scotchbrite pad, and the 320 sandpaper and small foam block. Process is sand an ~18" patch (keel to gunnel) till most shiny bits are gone, rub well with scitchbrite and use brush to get the worst of the dust off.
Once sanding is done, I will take a shopvac with brush attachment and go over the hull, then tac the hull twice. Once with an old tac cloth and again with a new one.
The exterior varnishing went pretty well, I am happy with it, no banding, the mail lady also does wood working, she said it looked like it had been sprayed on ... figure that was a good compliment.
Going to leave the hull a few days to cure well before putting it back upright. At that point, it is really just bolting stuff in and it is complete, the only real build stuff left is to get the seat webbing installed, which seems like it will be pretty fast and easy. Hopefully be ready to hit the water in about 2 weeks ... was hoping for 1 week (getting anxious to try it), but hardwood being installed next week and stuff like that (even when someone else is installing) always seems to require more time and effort than you plan for, so I have just written the week off, but am hoping I get it done sooner.
Garage is a little full with some furniture from the house, hardwood being installed in a couple of rooms ... there was however enough room to get the seat webbed.
I am using 1.5" polyester webbing from Sailrite for this seat, looking for something more comfy than webbing this time.
The seat received a couple of coats of varnish and allowed to cure for a couple of days (it has actually sat for a month).
Figured out the spacing for the fore/aft running webbing, there will be 11 with 1/4" spacing between.
Each piece was tacked to the inside edge, using 2 3/8" stainless staples
then the piece was pulled around, up over the top and to the other side, pulled tight and 4 staples on the opposite underside and 2 more to tuck under the edge bit
The cross running pieces were precut, edges melted and tacked to one of the inside edges and woven through the ones already installed
Each was pulled tight and stapled, 2 on the inside edge and 4 (some times 5) on the underside of the seat
And presto, we have a new seat to try in a week or so.
Well, assorted furniture cleared out of the shop and I finally got to bolt all the pieces together.
A few views to show the completed canoe
Hoping to get it wet within the week, will follow up with a "first impressions" post.
The original design of this boat was 15' and was built with a target weight of 30 pounds, I missed that target and the project ended up at 32.5 pounds, that was still reasonable and I ended up learning a lot on that build.
The design target of this canoe to build a 17' version, maintain the strength and weigh the same or less, the final weight ended up at 30.9 pounds ... so I did in fact make target this time.
There were quite a few build method changes, some for performance, some for comfort and some to keep me from getting bored.
Changes Summary
1. 6 oz. E glass swapped out for 4 oz. S Glass ...
- 4 oz S glass is about the same strength as 6 oz E glass
- this is a good way to rapidly increase the cost of the canoe build
- there are some weight savings to be had, but they are less than might be expected (in the range of ~1 pound/average canoe)
- the lighter glass is easier to handle IMO
2. My regular 5:1 epoxy swapped out to System 3 SilverTip 2:1
- this was after I read an article by Rob Mack (linked in build)
- another way to increase build cost, but I won't ever build with 5:1 again, this is that much better
- main feature is being able to recoat up to 72 hours after application with no sanding, I don't leave it that long, but being able to leave it overnight and just start again in the morning changes the entire glassing paradigm
- this epoxy is also water clear, my 5:1 has a bit of haze
3. Moved from a wet layup (fiberglass on wood, flood coat) to a dry layup (wood precoat, fiberglass on dry epoxy)
- direct result of the recoat capability of the System 3 epoxy (and Rob Mack article)
- the seal coat is applied and you walk away, there is finite amount of epoxy applied. With a wet layup, the wood takes as much epoxy as it can soak up, until the epoxy kicks
- did up a weight balance model and it turns out this area is one of the significant "hidden" weights in the layup
- using the seal coat was one of the largest weight savings for this build, in the range of 2 pounds
4. Changed up seat design to be wider (fore/aft measure) and flatter/wider siderails, incorporated webbing instead of woven cord
- the webbing is definitely heavier
- haven't tried the seat yet, this was definitely a comfort move, I found the woven seats were a tad uncomfortable after a few hours
5. Installed Uniwales, I don't think there are any performance or weight advantages ... I was just bored with regular gunnels, I used these on my first build
6. This project used a stemless construction, this is new for me. Modest weight saving of ~6 oz and a much sharper entry profile, thinking this might make the glide somewhat better ... will have to see. With this method you end up carving the actual mold ... I used baltic birch ply ... this is a very hard ply and made the carving much harder than it needed to be, the lesson was pick the end mold material to make carving easier.
So Like all builds, there was a bunch of stuff I learned and I appreciate being able to share it with this group. I appreciated all the comments and suggestions, I can't always use a good idea on a current build, but I usually remember and try to give credit to those suggestors on the next build.
