• Happy Sausage Pizza Day!🍕
Skid Resistant Shoes
SW OH - Land of Opaque Water
Having a cable and cadaver parts in my shoulder, I’m a little worried about a fall in the backcountry. My surgeon said, “Don’t fall, and if you do, don’t extend your arm to catch yourself.” It is an involuntary reaction to extend your hand to catch yourself, so that’s just minutiae. My camp shoes are the worrisome part of my gear. Anyone have some shoe suggestions that resist wet or mossy rocks? Please don’t say Crocs.
NRS and Astral have some highly regarded offerings. Fly fishing shoes will perform well. Most people will tell you to not get the felt soles, which are VERY non-slip, because of invasive spread.
You might want to look into the footwear worn by many river guides. Don't know if you're willing to check out sandals but there are many choices in that category. Over the years I've worn Tevas, Alps and now Chacos. There is a new company called Bedrock that is getting good reviews so there are many to look at. And, if you're not into sandals, Bedrock also sells clogs with heel straps so that's another option.
Hope that helps. Take care and until next time....be well.
As others have suggested wading shoes (fly fishermen) and climbing approach shoes often tout sticky bottoms. Vibram makes a lot of different sole materials and many shoe manufacturers specify which ones are on which shoes. You might look for something with the Vibram Megagrip sole.
I wear Astral “Brewers” or “Rasslers”. Soles are siped and a very good compound for wet rocks. I also sometimes wear my chacos and they have a new model out called the “rapid pro” designed for wet slippery rocks.
I’m a notorious cheapskate so it’s unlikely I’ll ever buy these, but the exchangeable sole concept seems interesting. Maybe there’s a shoe and sole combination you might like.
Rafting and fly fishing are two endeavors that require good foot wear.
Sandals are mostly unsatisfactory. Too slippery, and only the ones with buckles like Alps stay on in the current.
Some people like dry suit booties. We used high top basketball shoes a lot with fleece socks in cold water.
Another idea are wading shoes with felt bottoms. They are good on slippery rocks.
Maybe the best are the new water shoes. They look like hiking shoes but are made with neoprene and drain water fast.
I bought a pair for side hikes in the Grand Canyon. I wear them around the water for nearly all activities. they have a rough tread like hiking shoes.
If your wet/wading shoes are good, why not take two pair. I started doing that so that if I blow out a pair of wet shoes I have a spare. They work fine as dry camp shoes.
Also. on canoe trips I carry one hiking pole. I use it portaging the canoe to brace myself stepping over logs or thru tricky rocks. I have one so I can keep one hand on the canoe. Portaging packs I use my two paddles for support when needed.
If I had a fragile shoulder I would have a hiking pole in hand any time I am on tricky footing even around camp.
Me too on the Astral Rasslers but don't think any shoe can counteract a slip when the moss lets lose from the slick rock its perched atop. Happens to us a lot. Soft soles are nice to feel the terrain but a bane when you bruise the bottom of your foot on a root the first day in. Can't imagine being on a back country trip with a shoulder healing from surgery. Hats off to that!
I used Astral Loyaks for my camp shoes and they were lightweight, easy on/off, and no problem on wet rocks. No toe protection, so care must be taken, and feet could get chilled. I wore a sock mostly, but they are very comfortable sock less too.
