• Happy National Tooth Fairy Day! 🦷🛌🧚‍♀️💵
First Stapleless
I built two canoes with staples years ago and now am doing a Rob Roy, stapleless. After looking at different methods, I am doing it a little different.
After cutting out the forms, I cut 3/4" strips from the same wood and glued them on.
I set them up with these rings facing the pointy ends.
After that is was a quick fairing using a straight edge to get the angle I needed and a light touch with a belt sander. After the first strip was attached with screws it was just a matter of clamping them on.
If the strip needed a little help a dowel (section of kebab skewer) and some masking tape did the trick.
When I got to the bottom of the canoe and the strips needed serious pulling, I changed to Gorilla tape. It is stronger, sticks better and has a little natural stretch to it, like a bungee.
This took a little more work at the start, but once I got going it was almost effortless.
As you can see, this is not taking place in a dedicated, pristine, workshop but the garage. The strong back is on a table with wheels so it can be pushed to the side when I am not working on it.
Always fun to see a new build. I'm feeling rather silly - why haven't I - or other strip builders, for that matter - thought of that? We were so close!
It looks like it's working well. The hull seems to be turning out very fair, and you've got good consistency in the strip layup. (Easier time sanding when prepping for the glass.) Two concerns/questions:
  1. How well is the hull keeping to the forms when you remove clamps to add the next strip?
  2. How long do you need to let the glue set before clamps can be pulled and the next strip added?
Hey, no shame building in the garage! My first was built in an old barn, not at all wind-tight.
Nice !
Stapleless always presents the challenge, of keeping the strips true to the forms.
When you release the clamp ? The strips around the bilge area want to lift.
That's why canoe designers use staples, when they build "Plugs" for fiberglass canoe molds.
I have learned a few tricks to make the staple holes less visible, over the years.
Looks like you have it under control !
Thanks for the feedback. Some observations:
Timing
The Titebond II tacks pretty quickly so going up the sides I did a strip on one side, then the other, then took the clamps off the first side for another strip. No issues, even on the stem. When I got up to the bilge where I was doing one side at a time and pulling a curve I waited an hour or so before taking the clamps off. I might not have needed that long, but I didn't want to find out the hard way.
Floating
Mostly perfectly tight. I had one spot going up the sides where it floated a bit, I probably forgot to clamp from the center out to avoid pressure building up. A small screw between strips tucked it back in, after a couple more strips it was gone. On the bilge I have 1/8 of float over one form only, probably a fairing issue. I can live with it.
Stems
My cheap clamps held fine until I got near the bottom where the strips start to twist. A small screw straight down into the form took care of that, the holes will be invisible when done.
Gorilla tape and a dowel is the bomb.
Being a Rob Roy, I decided to go classic and make it decked. I couldn't find any good leads on framing the deck, so I am doing this:
Instead of lifting the hull from the form, I rolled it, with stations, off of the strongback.
That became the cradle for the hull.
Once I figured the curves I wanted they were cut from 3/4" particle board, fitted to the stations and attached. The cuts were really rough but nothing that some spackle and sand paper couldn't fix.
Then a strip of basswood was attached and faired for starting the first strip and later mounting the deck.
A decorative center strip.
And it is off to the races. After seeing the post Most Useful/Best Clamps for building a stripper? I made up a bunch of Jimmy Clamps.
Tennis balls work when it is too tight for them, they work better with a hole to let the air out.
Today is glassing, then on to the cockpit and coaming to give some strength and stability before I pry the deck off to work the inside of the hull.
Time for the coaming.
With the glass on and the cockpit cut out it was time to knock out the center forms.
1/2 x 1/2 basswood was used a a holder strip on the bottom of the deck. The curve had too much pressure for spring clamps so screws had to be used.
Fitting the side pieces of the coaming was tricky, a bend with a lot of pressure, shooting for a good fit on both ends. The more I tried to bet the bow fit right, the shorter they got.
Eventually I just stuck some trim wood in the gap and called it good. Not planned but it works.
Side pieces are about 5/16 x 5/16.
Lots of sanding and a epoxy seal and this step was done.
Hanging the deck from the ceiling and I can get on with the inner hull.
Looks like I am about done.
The deck did flatten out some, being off the hull with only one side glassed. Tension in a few spots while the inside glass set took care of that.
I am glad these clamps are cheep.
It is hard to get a good picture inside the garage, I will add a few when I get it launched. Now to carve my first paddle.
Looks nice! Now you just need to find some paddle-friendly weather. Not sure where you're at, but around here the water is kind of solid-ish ATM. I can tell I'm going to get a bit twitchy waiting for all the new paddling reports.
Paddles can be fun. So many different tastes and opinions between paddlers.
A couple of finishing touches.
The carrying yoke. Simple but effective. The wood strips and rubber on the bottom are guide brackets for the seat. I am using an Ed's Canoe classic folding chair, removable.
First paddle today, the seat needs to be moved back a couple of inches, but other than that, pretty good.
What a beautiful little boat, very nice work I imagine a rod holder would clamp nicely on the front of that cockpit. (y)
