• Happy Read a Book Day! 📚📖🔖
First Canoe
I hope you have your strongback, secured to your saw horses.
I use Fish line, (203 ) to align forms. I leave it on, until I'm stripped close to center. Nice to be able to check alignment while stripping !
Just be very minimal with your glue !
It's not fun to scrape excess glue, especially from the inside.
You only need enough glue to hold the strips together, until the epoxy takes over.
It took me a few canoes, before I realized that !
Oh, My first canoe ! Took me days, to get the Yellow glue, scraped and sanded.
Then the Yellow glue, still showed through the resin !, ( Polyester resin at the time)
PS ! I use C-clamps to hold my forms to the cleats. I can easily adjust on the fly, and I won't need the clamps, until I take the hull off the forms anyway.
Looks great !
@Jim Dodd
The 5/8" connecting plates have 4 screws up into the strongback and 4 screws down into the sawhorse. The sawhorses are ones I copied from a post by @Robin and are pretty heavy. It's all on cardboard as I saw in one of your posts.
The Titebond nozzle is way too big and I'm looking for a different glue bottle. Even small Titebond bottles have the 3'8" wide nozzle. Every source is clear that it doesn't take much glue. I know that TB isn't required but I know it performs well. I'll review more posts on this forum to see what others recommend. Small, plastic-bristle, discount store "artist" brushes are great for spreading small amounts of glue but obviously tedious for stripping. The wait time for the stem forms means I'm more than a week from the first strip.
There is a line down the strongback, but only a chalkline. The forms bottoms are the same width as the strongback top which should help if I stay centered. When I first used a laser level, I was converted. So very convenient and not deflected by contact with the work.
Thanks
Dave
Oh. Forgot the pic.
I used a syringe (without the needle) from Tractor Supply for my 1st couple of builds (pretty easy to suck up some glue by tipping the bottle) but I've started using a small, rinsed-out Elmer's school glue bottle on the last couple. Seems to lay down a small bead & it's easily sealed when done for the night by twisting the cap.
Don't get overly stingy with the glue. I had one hull (my Raven IIRC) where some of the glue joints pulled apart during sanding because I was overly zealous about minimum glue. Not much fun and I'd rather scrape some extra glue from the interior... a fine line to be sure.
I found glue bottles at a Hobby Lobby. Don't know if you have one near by ?
A good hobby store should have glue bottles, with long small tips.
I strive to get a pencil lead diameter, glue bead, or less,.
If you see squeeze out ? That's too much.
Evan if you starve a glue joint ? you can add a little glue, and strap the glue joint.
My strongback legs. With these ? I'm able to tilt my strong back.
This helps, when stripping the football, as well as sanding, the entire hull.
The hobby shop 30 miles from here closed maybe 15 years ago. Rural living is great . . . usually. The idea of a twist-open glue nozzle sounds good. I'm sure I can find Elmers glue here.
No yellow pencils in the house, only mechanical pencils with 0.07mm and 0.05mm leads. Those might be too small as glue guides. My school drafting pencil from the '60s has a 1/16" lead. The books here say 1/16" to 1/8". One pic shows the cove full which I suspect caused them some scraping although the caption is only about the right amount of glue.
So I suppose a yellow pencil lead is 1/16" ? I suspect a glue bead of 1/8" would be too much.
Thanks for the warning about being too stingy since most warnings are about too much glue.
I built a sacrificial lamination of the same strips as the stems. I'll cut this in a few days to see if the center glue has set up. I can probably cut 2 or 3 times if a few days is not long enough.
In the mean time, it's raining outside and I can set up the center 14 forms although I'll have to move the level around to add the end forms later. Might look for other projects instead so I can set up from one end to the other as suggested to me earlier.
Thanks all
Dave
Dave
Amazon has a very wide variety of glue bottle application tips.
As for glue, anything, but Yellow. Beings you are using Bead and Coved strips ? Your glue joints will be near invisible.
So the glue won't show much anyway.
Yep, I think that would be too much. Aim for 1/16 & if you get too much squeeze-out, cut it back a little (move faster with the glue bottle). I like to see a little here & there but not have it all over the place.
Honestly, it's probably something you need to do (and, maybe, screw up a little) to get a feel for it. Like so many parts of this project, just dig in, don't think TOO much and it will come together just fine. (The second or third are easier, I promise)
Thanks. I'm glad that the second or third strips are easier. (That's what you said, right?) I'm starting to get used to the idea that other canoes will follow but I'm gonna need another building or a shed off the side of one that's here already.
At the end of this post are some thoughts on glue usage as well.
Thanks for those thoughts on glue, color match, and early cleanup with a putty knife to prevent spreading. You make an excellent case for me giving up my old familiar Titebond.
I have never heard of "Express glue". A web search shows that some are PU glues.
(EDIT)
I see that other threads on this site mention LePage Express PU glue which is a PVA glue. I'll try it.
Thanks all,
Dave
Anyone with experience with other "express" glues is welcome to mention which ones.
Good news about the laminations I made with Titebond III. I just cut the test piece after about 40 hours. The cut was 3" from the end so I could take other samples later. It is dry inside. I split it with a chisel and it resists splitting on a glue line but shows grain on both sides of the split. I took another sample from the center of the test lamination and it is also dry and also splits wood instead of glue.
The "real" lamination has been curing for 65 hours. I am confident that I can proceed.
When I laid these up, I first clamped the bit below the waterline and progressed up the the gunwale. The bit below the waterline was all square but the layers had splayed out left and right by the other end. I did try to control them but in the end they were less than square.
So I flattened one side a bit. I worked on only the side that will go against the fence of the table saw and only the end that had splayed significantly.
Then to the table saw. First cut was down the middle then 2 cuts to make them 3/4" wide.
I can now go on to attach these to the forms and bevel them so I can staple strips to them.
Dave
(EDIT)
Thanks all,
Dave
The post was more about using a glues properties to your own advantage and that for softwood like cedar almost any glue is going to be overkill from a strength perspective. I have TB, TB II, TB III, LePages Pro, LePages Express and two different epoxies ,,, they get used to make building easier for me.
In hot weather (like we have here currently) I suspect that my Express (that is just the name, not a class) glue would setup too fast for stripping and I would need to go to one of the other glues to get sufficient open time to apply and get a strip on.
In your application (stem lamination), TB III is a good glue, but you likely would have been better off using TB or TB II IMO. Under constant stress or heat, TB III is flexible and tends to "creep" , it doesn't setup as hard/rigid as the other 2 TBs. I doubt you will see any appreciable creep in your glueup in the build timeline, it is however something to be aware of when selecting your project glue(s).
The surface sheer strength of WRC, NWC and Spruce are all , on the average less than 1000 psi (likely way less) .... TB has a sheer strength of ~3000 and TB III ~ 4000 .... whatever glue used is going to be overkill on softwood. If you look at the sheer strength of most glues, it is the same story ... almost all glues are strength overkill for softwood, so pick the properties that make your life easier and suit the job at hand.
Thanks, Brian.
I know very little about wood glue. My measures are "Does it stick together?", working time, and sometimes weather-resistance.
What I took away from reading "not a treatise on glue" is that glues that would serve best would a) have a color that matches better and b) be cohesive enough to knock off the cedar without smearing or tearing wood. It seemed that LePage Express did that for you at one time.
TB III dries to a dark brown but I use it for the longer open assembly time compared to other TBs. (I don't want hide glue.) I don't use enough wood glue that I keep others on hand. Even a table, bookcase, or kitchen cabinet doesn't really take much.
It's 71F in the basement. That's about as warm as the basement gets unless I set up portable heaters. I don't expect to use heaters until time for glassing.
CLC says "yellow carpenters glue". Gilpatrick says "yellow carpenter's glue". Schade says "yellow wood glue . . . such as Elmer's ProBond or Titebond" (PVA, not waterproof). I can't find work time data for any of the several ProBond glues.
I'm not sure where I went wrong thinking LePage Express would work. LePage claims open time is 8 minutes at 20C. That's equal to TB III and longer than any other Titebond except Hide glue. Perhaps LePage Express claims longer working time than it actually has or your shop is warmer than 20C. Mine's currently 21C.
The longest working time for TB (not III) is the original. About half as long as what I've used these past years.
I know TB III is not a good match. Nothing else here will work well.
Dave
I haven’t used it on cedar strips, but my last flooring project specified either a Bruce or Wilsonart white wood glue for manufactured wood flooring and a wood composite that is water resistant. It dries either clear or translucent and was water resistant also. Available at Home Depot, Lowes, etc.
Typical with any wood glue, I keep a wet rag handy to clean up the glue line as dried glue can interfere for appearance sake. Also easier sanding.
I made a flat spot.
Working from one end to the other, I aligned the forms pretty well (I thought). The laser level was mounted to the bench weighted down with all the nails and screws. It was not moving.
The cleats were already mounted to the strongback and I screwed the forms to the cleats in under 2 hours without touching the laser level.
A batten shows a flat spot on the north side at form 5. I ended up moving the laser here and there to isolate the problem.
The pic shows form 5 in the middle. Note the small errors at 4 and 6, about 1/32". A straight edge shows the bottoms are out by about the same 1/32". EDIT: There are also very slight variations in how vertical the forms are. Attaching them to a keel strip should also help with the flat spot.
The design has areas of very slight curvature. I need to be more careful to get the forms aligned precisely.
After I move forms 4 and 6 I'll spend more time with battens since the bottom of this design also has areas with very slight curvature.
I'm glad I didn't trace and cut the forms or I would have had more difficulty finding where I went wrong.
Dave
Good progress getting the flat spot out, but I have a different do-over today.
I cut witness kerfs for the rolling bevel. The kerfs were OK but I was overzealous when cutting the thinner part. That's the bottom of the form or top of the canoe. I got the stem too thin by 1/8" total or 1/16" per side. When I lay some scrap 1/4" strips on each side, that makes the top of the canoe short by 3/8" to 7/16" at each end. It may be a nice-enough curve and it may not be a nice curve at all. Do over.
This morning I ripped new strips to laminate new stem forms. I have 3 new-to-me wood glues but they all have shorter working times. Everything I find has shorter working times. I could use epoxy and could probably use the practice. It can be messier. I thought the TB III turned out good enough for making part of the forms.
I'll take the forms off the strongback and clamp them together then figure out what glue for the next try.
Dave
I epoxied the new stem form laminations early this morning. Then at noon today, Chesapeake Light Craft exchanged some wood for me.
Yesterday I bent the new stem strips cold and dry. They don't take as much "set" that way but it worked OK. These were slightly thinner than the last ones I ripped so a few more strips. West System with fast 205 hardener has plenty of working time and I was able to align the strips better than I did last time. It was necessary epoxy practice. Pics after I split them.
Weeks ago, when I first opened the boxes from CLC, I noticed the runout on the 3/4" square gunwales. All the 8' pieces had what I thought was severe runout. I emailed CLC with pics of the grain. A week later, they asked how many pieces I would need. It was all eight 8' piece. The worst was at both ends with some better grain in the center of each piece. The four 4' pieces had slight wavy grain, but not the kind of runout problem of the 8' pieces. They replied that they would bring replacements to the Wooden Boat School and we could exchange.
Today I went to the WB School at the end of lunch hour and met John Harris of CLC. He looked at the pieces of wood from the kit and he agreed that we should exchange. The pieces he brought are much better. There is some runout but it's not bad.
IDK how well this would work with shipping, but my experience with John Harris and Chesapeake Light Craft is very good. It would be easy to say "It's wood. It has grain. It won't always be straight." They didn't say any of those things.
For the record, the cedar is very good. Some knots and runout but overall very straight. I'm impressed with the quality of the cedar strips.
Dave
The replacement stem forms are better. A new brace keeps all the forms in parallel planes. The books say to nail a strip near the keel-line but that would be in the way of finding the alignment problems I've introduced. That's why the strip is inside the forms instead.
The hull does have hollow at the waterline and above and below that. No hollow at the gunwale. I had been checking form alignment with a straight-edge and that does show problems. Now I'm using spruce battens to get a different look.
I expect to move slowly for a while.
Dave
Staples!
I ended up moving only two forms. The battens and the straight-edge were valuable in different ways for finding and measuring the problems.
I was going to make each strip long on one end and short on the other but figured it makes every strip fussy. Seems easier to make one strip short at both ends then add the long strip on the other side. Alternating sides, of course. I stapled one strip but haven't cut the ends yet.
USPS delivered two glues yesterday: Titebond Extend Wood Glue and Titebond II Extend Wood Glue. TB E says do not use below 40F while TB II E says do not use below 60F. After mid-November, the basement won't have heat which usually means 50F (10C) into April. I can start heating some in March but not a lot and don't expect fast results.
I don't have any wood glues that make any claims for gap filling. Seems like the stemless ends of the first two strips are where I'd need that most. Or maybe I just need to spend more time cutting the angle right.
Dave
Coulda been worse.
Both ends have the same problem with the long strip pushing the cut strip away from the form. I'll work on them with a coarse single-cut file.
I used a flush-cut saw because it has the finest teeth of anything here. Turns out the lack of tooth set on one side made it good for making the cut.
Good idea. I have often considered the same kit. I built a sea kayak from Pygmy with excellent results. The boat was beautiful, strong and light. But I do not really like kayaks. I sold it for several hundred dollars more than the cost of the kit.
I like to add strips of fiberglass cloth on the stems under the final fiberglass cloth. I would not go too light. 6 oz is light enough.
Good luck. It is a rewarding process.
