• Happy Sausage Pizza Day!🍕
17' Old Town wood/canvas derelict (well maybe)
Kent/Carmel NY and NYC
I just got back from viewing this beautiful beast near my house. My neighbor found it in the attic 5 years ago when he bought the house and believes the prior house owner also found it there. It has sat outside for the last 5 years and the deterioration is obvious. I believe we know, once restored, it likely will be worth about what it is now. My real question is: Can I do this? She has 4 to 6 broken ribs, The inwales appear 95% good and the gunwales are totally shot. Are they mahogany? Don't forget it needs to be totally re-canvased. You folks have nursed me through two other projects that were successful. I am retired, have a garage to donate but need to add a woodworking shop- is doable. I can't rely on my 90 year old buddy Clark who helped steer me through the last two projects. You may recall I when to boat school in Maine (with nNoah) in the early 80's and then sat at a desk for 35 years.
Attempt it or strip it for parts and toss on the burn pile?
Gamma- please weigh in!! Cheers- Bill
Look Bill, I know nothin' about wood/canvas boats but I agree 100% with Jim. It's the perfect boat to learn on because you can't make it worse than it already is (although I suspect that it'll look better once the canvas & rotted wood are removed).
Honestly, the front deck (with sticker) looks to be in good shape; the rear is good enough to use as a pattern... it looks very salvageable and, as most people would have probably already tossed it on the burn pile, you've got little to lose besides time.
Really, there's only one way to find out. Audentes fortuna iuvat (fortune favors the bold).
Thank you all-well said and if I pass before it’s done-who cares?
Gamma-Watcha doing up at 4? I wake up then but roll over after I hit the head. 😇
One of the good things about wood and canvas canoes is that they can be repaired relatively easily. I suspect that you can do it. The books at https://www.woodencanoe.org/books will help explain the steps. The forums at https://forums.wcha.org/ are another good resource. Most questions have been asked before so the search utility can be your friend. This canoe was probably built after the late 1950s and the outside gunwales appear to be mahogany. The first link below may help you find the serial number if you want more details. Good luck,
I'll echo Benson's reply. There are many experienced restorers who frequent the forums at WCHA.org, many of whom will be willing to offer advice and analysis of your project. I'm currently on my fifth wood/canvas restoration, and while they seem to be getting progressively more difficult, with experience you'll realize that nearly any feature of the canoe can be restored. It's easy to be overwhelmed by the entirety of the project, but step by step removal of damage, and incremental repairs of each step will find you surprisingly close to completion in little time. Patience is likely the most valuable asset- the technical bits are not exceptional if taken one at a time. For example, that deck with the label can be resurrected simply by cutting back to good wood at the tip, and scarfing on a new tip of appropriate species of wood. See the attached picture of Chestnut Canoe Co. decks (Ash) that were rotted at the tips. Scarfed-on bits of Ash made them serviceable again. The same technique will repair the rotted inwale tips too.
Researching the serial number stamped on the stems will give you all the pertinent information on build details.
I just checked in before heading to the new job.
Today was a 5am start driving a 45 ft, 50+ passenger commuter bus into downtown Pittsburgh. It's a little unnerving in downtown traffic but I figure people value the paint on their car more than I hate filling out the incident reports so I seem to have lots of room. :giggle:
Fortune does, indeed, favor the bold... and those who drive fearlessly in other people's vehicles (my trainer says I'm a natural) :ROFLMAO:
Depends on what you enjoy doing as a hobby. If you like restoring canoes, and you seem to, then why not.
At any point in life, you gotta know when to bold 'em, or hold 'em, or fold 'em.
Someone like me, who only enjoys paddling canoes and is winter weak, wouldn't restore it because I couldn't lift it, once restored, to paddle it. Hence, I've folded for any canoe above 30 pounds. Fortunately, “There are more things in Heaven and Earth, Horatio, than are dreamt of in [my] philosophy.” (Hamlet)
You will have to decide the purpose of restoration. Is it to keep to use, or keep as a display piece, or to sell? For personal use, it looks like you could get away with new outwales, partial stem replacement and canvasing. If this are the only cracked ribs, you should be OK, although you will know better when you get the canvas off if any of the planks need replacing. Refurbishing it for resale would be more arduous, as you would want bring it up to almost perfect.
And here is a heretical view, which will land me in the lower levels of hell in the Church of the wood canvas canoe apostles, indeed, it would render me the French Canadian title of sale apôtre, or Dirty Apostle. Take the canvas off the canoe, sand the hull fair, don't worry about cracked ribs or slightly sketchy planks. Cover the entire hull with painters tape, or even Saran Wrap. Lay on a six or ten ounce sheet of regular canoe building fibreglass and wet it out with epoxy resin, with the required number of fill coats. Sand it fair and paint it red. Don't tell anyone you fibreglassed it, they will never know, and it will paddle like a dream and look like a queen.
The sound when tapping the hull of a canoe with your fingernail can quickly distinguish fiberglass from canvas. Fiberglass usually makes a sharp ping while canvas produces a softer thud. Canvas canoes will also sound and flex differently in the water although this is more difficult to describe.
I did one around 15 years ago, used painters tape, so the hull is not stuck to the fibreglass. It's still going strong, it's in my backyard right now, lonely for a paddler.
Fiberglass and epoxy are two words that shouldn’t be used around wood canvas canoes. Well, maybe the term “a little epoxy” is ok.
I’m done taking on new projects, but if that was my canoe I would;
1.Remove the canvas and strip the varnish, there’s a chance you might find more cracked ribs.
2. Find a shop that will supply you with a new deck, ribs and planking.
3. Scarf in new inwale tips, repair stem, install new deck.
4. Remove one rib at a time, never two ribs next to each other at the same time.
5. Steam and install new ribs.
6. Sand and varnish hull interior.
7.Make sure the hull exterior is smooth, some people apply an exterior finish like varnish or oil, either have a shop install the canvas or DIY.
8.Fill canvas, wait 6-8 weeks till filler is dry.
9. Sand canvas, paint. (Don’t cheap out on paint)
I removed and installed new inwales on my last two canoes, and used the “food storage bag” system to steam my ribs.
Totally appreciate all the comments particularly Manaque’s soliloquy. I believe perchance he has brought out my real issue with attempting this restoration. While I believe I can master the project, I have no practical use for a wood canoe that I can barely lift. Unless it is perfect likely there would be no market for it. Still interested just not ready to pull the trigger. Ordered the This old canoe book and will get it once back in NYC in a week or so. Please stay tuned I love the heartbeat of these threads. Cheers, Bill
Well I'm back folks. Finally after two weeks got the This Old Canoe book through Amazon. First they said it was lost, then damaged by UPS, then sent via USPS and undeliverable. That all took two weeks. Visited the canoe today and lifted the serial number: 175240. 7or 17. Remember it's a 17 Old Town. Please tell me how I get the build sheet. I know that info is on the site but I seem to miss it when I hunt. I measured the ribs today, 12 are broker and they appear to be 2 to 2 1/4 inches wide on average and beveled. Three ribs look like replacement made of white cedar. I can't tell what the darker ribs are made of. I'm pretty sure the outwalls are mahogany.
Ask and you shall receive. The Old Town canoe with serial number 175240 is a 17 foot long Otca model with narrow two and 3/4 inch planking, a keel, and the stern seat was moved two inches forward of the usual location. It was built between September and November, 1965. The original exterior paint color was pale blue. It was shipped on April 7th, 1966 to Cranford, New Jersey. A scan of this build record can be found below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-wcha to learn more about the WCHA and https://www.woodencanoe.org/pricing-plans/join to donate or join.
It is also possible that you could have another number or manufacturer this description doesn't match the canoe. The page at https://www.wcha.org/catalogs/old-town/specifications.jpg lists the specifications for your canoe from a period catalog. The original ribs are Eastern white cedar. The inside gunwales are spruce and the outside gunwales are mahogany. Let me know if you have any other questions.
