• Happy Birthday, Bill Mason (1929-1988)! 🎨📽️🛶
Kite +6%
I applied the third coat of varnish today inside and out after roughing with maroon Scotchbrite on my RO with interface pad. I then gave it a vacuum, a wash and a wipe before tack clothing. I managed to get the whole inside and out with one 2" foam brush. Normally I use two but I'm running low. It's finally warming up here so hopefully this coat will cure a little faster than the previous ones.
I have a few spots in the varnish where I don't have it completely level. Do you guys think I should use 180grit on the interface pad to level it before the final coat or do you have a different suggestion?
I'd figure the scratches of using it will cover them but I'm the reason that I can't have nice things & usually stop at level-ish. YMMV
