• 2026-29 Fund Drive needs only 9 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
Removing registration stickers without damaging the finish.
A few weeks ago, I picked up a DH in Ohio. Ohio requires registration and, therefore, stickers posted on the hull. I need to remove the registration stickers, which I will do with a heat gun, but I am not sure how best to get rid os any residual adhesive. My go-to on other surfaces has always been either WD40 or Goop-Off. What can I use on a MR DH that will not damage the paint/finish?
Thanks,
JDG
My first canoe was a lighweight hull Grumman that I bough in Columbus OH when I was in th AF there many years ago. After moving to NY (no stickers required), I carefully scraped the registration numbers off. But the awdul outline still remains visible. I don't use that canoe enough to worry about it, bu have threatened to use harsher means to clean it up. Steel wool comes to mind, but I did not want to leave a discolored patch. I can't imagine much of anything would harm the aluminum, but just haven't gotten around to it.
Thanks,
JDG
I assume your Duck Hunter is Royalex, so I'd go easy on the heat gun, as Royalex can expand with excessive heat. I had a similar situation with PA stickers on a Mohawk canoe once. They were stacked 6 deep and would not respond to heat. Ended up getting a single edge razor blade under one corner and just working it gradually, while very careful not to cut into the vinyl skin of the Royalex. A little gasoline on a rag removed the residual adhesive without damaging the Royalex.
I live in PA. I purchase the boat launch permit every year, I certainly don't mind supporting everything it gives me access to. But I refuse to put the sticker on my canoe for this exact reason. I've gotten stopped once at a boat launch and once I pulled out the permit they didn't give me any trouble about it.
Mineral spirits is pretty benign
And believe it or not, baby oil removes lots of adhesives, very gently, I might add.
Tougher stuff may respond to acetone, tougher yet hexanes.
With any of these, of course, test them out in an obscure spot first.
WD40 has removed lots of sticker residue on hulls for me, though that has only been on Kevlar and Carbon-fiber hulls made with either Vinylester or Epoxy resin. I too am done putting ugly registration stickers on my hulls...I'll pay the fine.
I don't put stickers on my canoes but I've had good luck with Goo Gone when working with surfaces that I was hesitant to wipe with Gasoline
As for the stickers themselves, I actually bought a launch permit last year when I paddled to Allegheny Islands State Park but didn't put it on. I had it in my pocket when Fish & Boat questioned me and the officer seemed to understand completely why I didn't have it stuck to my stripper.
I'm not saying all fish cops would do that but the fine might be optional if the only issue was an "installation error"
royalex is very susceptible to gouging from razor blades- if you go that route I suggest you touch the corners to a grinder or whetstone to knock the corners off so they won't grab and dig in.
I don't know if it would work without leaving marks but there's a wallpapering tool made for vinyl called a "paper tiger' which has tiny teeth on rollers designed to puncture the waterproof coating and allow the adhesive remover to soak through without damaging the drywall behind- I've successfully used it on glass and painted metal as well as some harder plastics and composites, but never on something as soft as royalex
