• Happy National Scotch [Whisky] Day! 🏴󠁧󠁢󠁳󠁣󠁴󠁿🥃🚱
Trouble Closing a Seal Line Map Case
Maryland
I recently got a 12"x16" clear, plastic map case by Seal Line. I can't get the zip-lock-like closure to close. Seal Line suggests applying Vaseline, which I don't want to do because I think the Vaseline will trap dirt and make matters worse. If any of you are familiar with this map case and provide hints on getting it closed, I will appreciate it.
Maybe a silicone lubricant would help.
Is the trouble indoor or outside? Those heavy duty zip-locks can be annoying when it's cold.
Vaseline does help and I don't think it'll cause too much problem with debris (just use the thinnest application possible, no globs). But I avoid those ziploc-style map cases now.
The newer Recreational Barrelworks one with a waterproof zipper (like on a dry suit) is so much better. Only used it for one season so far but it's no worse for wear so far.
I found silicone helped. In the field, so does spit - just lick your finger and run it along the seal.
Thanks. I’m going to return the Seal Line and order from RB. Zipper rather than zip lock seems sure to work better.
Have a look at Aquapac. I bought one in 2008 and have never wanted to go back to any of other options.
Oh boy... Once more, CTN excels at separating me from loose change... Maybe I can offset the $50 cost by not printing maps on waterproof paper but that seems like it puts an unwise amount of faith in the case remaining waterproof.
The Aquapac bags look quite good...but they've lost me by not providing the volume or even dimensions for them (not even on their size guide tab). 😑
Recped's map case is quite voluminous. I'm certain I recall things being lost in it. You can't need anything bigger. Myself, I like the Watershed deck bag made for k***kers - it has a window for a map. I print out maps at home and have them laminated at the local office supply store - 2 pages back to back to a sleeve. A little sturdier and definitely waterproof that way. And preserved - I have sets of maps from 15 years ago that are ready to go downriver again.
I received the map case I ordered from Recreational Barrel Works. The zipper closure looks great! However, I don't understand why they built in so much useless black trim. I just emailed RBW this comment:
I’m sending this email to suggest you enlarge the clear windows on the map case. For orientation regards this comment, I’ll call the side of the case with the logo the “front” and “top” is where the logo appears. The map case is 34mm tall and of that 34mm, only 22mm is clear window, i.e. 35% of the case’s height is black plastic. Maybe the black plastic is necessary to mount the zipper, but that’s only on the back. Why can’t the clear window be taller on the front? What is the benefit of carrying around a map case that has 35% of the content blocked from view? I am very disappointed the clear window isn’t larger. If I had purchased this on Amazon, I’d return it. However, I am going to keep it due to the effort and expense of returning the product to RBW. I will not be recommending this map case to other paddlers.
I only provide this feedback in hopes you can improve the product to the benefit of paddlers who may purchase a map case in the future. I wish you good luck and success in your business.
That's a really good question. I have the large version of the RBW map case and it doesn't have the wide black strip at the top.
That's a good point. I'm planning on buying another map case but I print my maps on 12" x 16" (30 x 41cm) waterproof paper. My overlap is kept at the edge so a wide border will cover the overlap (or even more).
I guess I may be back to the drawing board looking for a map case. I don't care if someone covers the entire back with their advertising but I'd like the part I need to be clear.
@Chip , I'm curious what RBW's response will be. After you posted, I emailed the folks I was going to buy from and she measured the window area. They appear to have 2 versions of the case but I'm not sure which of you have to one currently being produced.
As you can see, this one should be perfect for my 12 x 16 inch maps. Now I just have to figure out an economical way to get it across the border (or a drop point along the route where I can pick it up).
Here is response emailed from RBW:
Chip,
Thank you for writing to us with your thoughts on the Medium Map Case and sorry for the delay responding. You are correct that the black portion of the map case on the top and bottom is larger than it needs to be. The design for the black nylon material on the back should only be wide enough to form a stronger surface for the inside of the zipper to rub against rather than against the clear window. If we look at the Large Map Case the proportion of the black nylon material is more appropriate.
We will take your good suggestions to our manufacturing team to make adjustments to either expand the clear view area or reduce the width of the black nylon portion on the top and bottom by the zipper.
We hope that your use of the map case will be otherwise positive and align with the many other customers who feel the Paddler's map case is the best they have ever used. (Given the feedback has been regarding the Large map case).
Happy paddling,
Andy & Marion Baxter
Recreational Barrel Works Inc.
310 Margaret Ave.
Peterborough, ON K9J 5H2 Canada
Tel: 1-866-222-6311
Fax: 1-705-743-9834
www.recreationalbarrelworks.com
I am pleased the RBW responded in a positive manner. They seem like good people trying to make a good product.
