• Happy Birthday, Alexander Graham Bell (1847-1922)! 📞
How much have you paddled this year?
Two and a half years ago, I attempted to start my chainsaw. As I pulled the rope, my back went out, pinching my sciatic nerve in my right leg causing my right foot to go partially numb. After seeing an orthepedic surgeon, going through physical therapy and weekly visits to my VA chiropractor, my right foot is still partially numb and will be for the rest of my life. I haven’t been canoeing since. My doctors said that I can go canoeing again. I just bought a new Wenonah Wilderness Solo Canoe and the doctors gave me an exercise program to rebuild my strength over the winter and spring to prepare me to go canoeing next summer. My goal over the next 2 summers is to canoe all of the lakes in the Swan Lake Canoe Trails, the Swanson River Canoe Trails and the Nancy Lakes Canoe Trails.
don't let numbness hold you back, I broke my back about 10 years ago and severed 5 nerves on my left side and severely crushed my sciatic nerve, at the best of times I can feel my big toe and inside of my heel, at the worst of times I can't feel anything below certain parts of my hip and thigh.
I still try to get out and paddle when I can, but now I use a "sherpa" (usually my daughter or son in law) and a canoe cart, the biggest hassles are 1) walking in the dark or low light- I now use 2 headlights (one around the neck) to illuminate the path and the ground because I discovered that without sensations you can't tell where your foot is or if the placement is stable, 2) my balance while standing is next to zero, but sitting in the canoe is no problem and I can rotate my pelvis and hips normally, the biggest problem 3) is getting in and out- for decades I've dispensed with placing my paddle across the gunwales and just stepped in, now I'm back to doing it the conventional way to add that third point for stability. getting out is a whole new ballgame- if there's a high enough dock or rock it's simply a matter of swinging my butt onto it , scooching back and standing up. Beaches sometimes require me to pull up parallel to it and log roll out, which often leaves you wet and sandy. The worst are low floating docks that move under you, essentially meaning you have to roll out, belly flop onto it, then crawl off because standing on a moving object is a no-go...
Everything is still doable, just in a different way, and I learned a very valuable lesson- carry a gallon of water and a change of clothes in the car- driving home covered in cobra chicken droppings is not good for either your sinuses, upholstery, or travel mates...
I broke an ankle which has left me with numbness and funny sensations in that foot and calf. That ankle also tends to roll. And I’ve lost proprioception in that limb, meaning that unless I am looking at it, I don’t know where it is.
I have many of the same problems you do, getting in and out of a canoe. At first I just crawled out, a variation of your log roll, getting completely wet and dirty. Getting in, I would frequently swamp the canoe. I still have to stare at that foot and rehearse the motion needed in my mind before I can step in. Once in the canoe, I’m fine.
I in no way mean to compare a broken ankle to a broken back. Just also letting folks know you can keep going. I have some new health challenges, but don’t yet know where those will lead.
The good news is I've been tripping for almost 35 years with a partially numb left foot. My sciatic pain used to go down the back of my left leg making it painful to sit. Then I had a skiing accident on Tincan Mt. and the symptoms changed to the numb foot. It was an upgrade for me.
I hope you can achieve your goals this summer. If you do you'll be in real good shape by the time you're done. Hopefully I can join you for a trip.
I look forward to going on a trip with you.
I haven't paddled for a few years and decided to give it another try. Couldn't comfortably lift my old solo, so I purchased a lighter one and did a few short paddles on local lakes and then headed for the Bowron Lake chain. With that circuit my total for the year was about 100 hours but that was over about a six week period. Not bad for 89 years old I'd say and I already have plans for next year! This site is my inspiration.
You, dear sir, are my inspiration.
Yes, you are truly an inspiration. Will you be doing Bowron again next year?
This was the most I've paddled in the last 7 years but that's not saying much. I bought a new surfski hoping something different would rekindle my interest in paddling. It didn't. Most of my paddling time was spent paddling back and forth across the same lake testing the speeds of different paddling styles in various boats, which I did enjoy. I'd guess 20 miles.
I haven't been sedentary though. Cycling and running are new hobbies that logged a lot of miles along with plenty of walking.
I would consider doing Bowron again but I kind of have my sights on going to the Wells Gray park and paddling Murtle Lake. I'm looking at Vancouver Isalnd also. British Columbia has so many options for paddlers that it seems almost unfair. Glad I live a 1/2 mile from the border!
Looks like Murtle is a little less of a drive - from north Idaho, at least.
Well, I put in three more trips since I made this post, and hit my goal of 200+ miles (currently sitting at ~215). Probably won’t get another chance before NYE, so that is probably where I’ll end up this year. Here’s to even more next year.
Nov 9, Meramec River, Starfire
Dec 26, Current River, Polaris/Phoenix
Dec 27, Meramec River, Phoenix
Not as much as I wanted. But I am retiring this year after spending way too much time setting up my business to run without me.
I realized that if I didn't have an exit date, family would just keep me working.
This year should be a whole lot more.
