• Happy Release of World's 1st Animated Cartoon (1906)! 📽️(➡️🧵)
What leg to push off of. Effect of heeling on forward velocity.
I'm not unfamiliar with carving away from the side of my lean like Marc describes, but it is something I have to make a conscious effort to achieve. I also agree that different hull shapes will react differently to leaning, but as a general rule I think the same hull that carves away from the lean will also carve towards it with a different trim and lean.
My theory is that a modern solo boat can either turn towards or away form a lean depending on trim and lean.
I would also like to attend a freestyle clinic. I'd like to add to what I'm currently doing and not replace it.
  • Like
Reactions: ABT
This discussion has reinforced my thoughts regarding turning a canoe with a heel vs carving and how it relates to carving a ski(s), which is how my brain thinks of carving. My conclusion is that there are two ways that canoes "carve" a turn and they rely on different aspects of canoe design and hull shape. Whether a canoe is carving in the first sense (turning towards the heel) depends on its hull profile when heeled, and carving in the second sense (turning away from the heel)* depends on whether (and how much) the bow and stern stems extend into the water when heeled.
* "Carve. A deflected turn away from a heel, caused by differential entry edges and forces."
(Freestyle Canoeing: Contemporary Paddling Technique; Glossary of Freestyle Terms; 1996; Lou Glaros and Charlie Wilson.)
* "We can heel the hull... outside, away from the turn, starting the stems to carving."
(Freestyle Canoeing: Contemporary Paddling Technique; Part III, Chapter 10. Solo Freestyle Maneuvers, page 78; 1996; Lou Glaros and Charlie Wilson.)
* “[At the bow] the heeled down side intersects the water at a greater angle than the up side, and deflects the leading stem towards the side of less resistance.”
(Freestyle Instruction Manual Ch. 4 Pg. 6 Copyright 1995 CEW)
My alpine and Nordic skiing background has me thinking of carving a canoe (first sense) as heeling the boat towards the turn to narrow up the hull and produce a profile that very crudely mimics the shape of a fat powder ski. The narrower inside “edge” profile of the canoe carves into the water, acting like the compressed camber of a ski. Sharp edges (i.e., hard chines) might make the turn easier but are not required, thus there's a fair amount of skidding that occurs.
The other way that a canoe carves (second sense) works best when the stems, particularly the bow stem, remain in the water when heeled. The more stem that projects into the water the more powerful the carve. Narrow stems act like a tipless ski (with two bases) set sideways in the water. When vertical (sideways) it just keeps the canoe pointed forward, like a skeg, but when tipped to one side or the other it now acts like a high angle ski and carves away from the heel, using the pressure of water against the stem (ski base) to accentuate the carve. I think that’s why it feels natural to push down with my foot to emphasize the heel; it feels like I’m weighting a carving ski. And pulling up on the opposite foot feels like I’m unweighting the inside ski in a turn. In this case, the heeled profile of the hull is less important because the stems, especially the bow stem, is doing most of the carving, not the hull, and the stern stem is both carving and skidding into the turn, much like the tail of a ski.
So non-rockered canoes will have a much different response to heeling than a rockered canoe because of how much stem remains in the water. The stems act like a ski carving a turn and because the stems are oriented roughly 90 degrees to the hull they counter somewhat the yaw effect. That also may explain why a slim, non-rockered canoe tends to have less ability to turn into the heel, the stems continue to influence the forces acting on the canoe hull. Depending on hull profile and length, there is a wide range of effects; it’s all relative.
That’s how I think of carving a canoe. I use carving in the second sense to subtly offset the yaw effect when paddling a fast solo touring canoe. Flame on! 😁
The following diagram shows what I believe is the difference between a typical hit-and-switch forward stroke with no heel vs a hit-and-switch forward stroke using a subtle carve to partially offset yaw.
This discussion has reinforced thoughts I've had regarding turning a canoe with a heel vs carving and how it relates to carving a ski(s), which is how my brain thinks of carving. My conclusion is that there are two ways that canoes "carve" a turn and they rely on different aspects of canoe design and hull shape. Whether a canoe is carving in the first sense (using a heel) depends on its hull profile when heeled, and carving in the second sense (Freestyle Instruction Manual Ch. 4 Pg. 6 Copyright 1995 CEW) depends on whether (and how much) the bow and stern stems extend into the water when heeled.
The other way that a canoe carves (second sense) works best when the stems, particularly the bow stem, remain in the water when heeled. The more stem that projects into the water and the narrower the hull profile, the more powerful the carve. Narrow stems act like a tipless ski (with two bases) set sideways in the water. When vertical (sideways) it just keeps the canoe pointed forward, like a skeg, but when tipped to one side or the other it now acts like a high angle ski and carves away from the heel, using the pressure of water against the stem (ski base) to accentuate the carve. I think that’s why it feels natural to push down with my foot to emphasize the heel; it feels like I’m weighting a carving ski. And pulling up on the opposite foot feels like I’m unweighting the inside ski in a turn. In this case, the heeled profile of the hull is less important because the stems, especially the bow stem, is doing most of the carving not the hull, and the stern stem is both carving and skidding into the turn, much like the tail of a ski.
So non-rockered canoes will have a much different response to heeling than a rockered canoe because of how much stem remains in the water. The stems act like a ski carving a turn and because the stems are oriented 90 degrees to the hull they counter the carving effect of the hull. Depending on hull profile and length, there is a wide range of effects; it’s all relative.
Not enough coffee in me yet to follow your text, but the diagram looks right to me. :)
The following diagram shows the difference between a typical sit-and-switch forward stroke with no heel vs a forward stroke using a subtle carve to partially offset yaw.
I couldn't find the Freestyle Instruction Manual is I'm not exactly sure if I'm following you correctly. I do agree with the premise that carving depends on how far the stems extend into the water when heeled. With a flat trim I've noticed a turning away from the lean, but I've never leaned away from my paddle side to see if it counteracts Yaw. I assume it would.
When I compare how a ski carves to a canoe I see three ways to weight your ski. You can front load it and carve with the tip or load the center and carve with that and you can also turn with your tails. In all three cases the ski will turn in the same direction. What I find in a canoe is that if I'm bow heavy it will carve towards the side of the lean.(bow pinning) If I'm stern heavy it will also carve towards the side of the lean, but with a flat trim it will turn away from the lean.
I think I get way more carving action with my stern to offset yaw, then I could by leaning away with a flat trim. When I'm carving with the stern I have to control my lean or I can turn too much towards the paddle side, requiring me to add a sweep to stay on track. I'm always balancing my carve (trim and lean), my stroke and the wind to minimize correction strokes.
Marc defines a carve in his article as simply a heel to the outside of the turn. It sounds like you are using “carving” to describe something happening even when heeled to the inside of the turn, so there is some discrepancy in how the term is being used.
Yes, this is one of the many examples in canoeing where we have terminology differences that end up confusing communication. Sometimes there are many different words to describe the same canoe stroke or move, and sometimes (as here) we have the same word ("carve") describing two different heeling turns.
When I learned serious whitewater canoeing 45 year ago, heeling into a turn was called a "pivot" turn and heeling away from a turn was a "carved" turn. Virtually all whitewater canoeists used pivot turns for all maneuvers, but we were aware that low rocker flat water canoes (and sea kayaks) responded better to carved turns.
Later on the internet, I began hearing some folks refer to inside heeled turns as carving with no particular word for outside heeled turns, unless they used "carve" for both inside and outside heels. Somewhere in between I learned that freestyle had developed its own lingo, which calls an inside heel turn an "axle" and an outside heel turn a "post" (accompanied by a specified paddle placement).
Finally, we had influencers such as Tom Foster (mainly in whitewater) and then Charlie Wilson (mainly in flat water) advocating and teaching the "inside circle forward stroke." In this quasi-forward stroke, the hull is induced to "carve" toward the paddle side and then this yaw is counterbalanced by an uncorrected forward stroke, making the canoe go quasi-straight without any need for correction. (I keep saying "quasi" because the canoe is actually traveling along the curved circumference of a very large circle, and must be kicked slightly in the other direction periodically.) However, the confusing point is that some hulls in the Foster/Wilson stroke will "carve" better toward the paddle with an inside heel while other hulls will "carve" better with an outside heel. The difference, generally speaking, is most pronounced between high and low/no rocker hulls.
@lowangle al suggests that weight distribution can affect whether the hull naturally prefers to pivot turn or carve turn, to use the terminology I originally learned. I suppose that's possible because altering trim can alter the waterline profile of the hull.
I added some excerpts from Freestyle Instruction Manual and Freestyle Canoeing: Contemporary Paddling Technique in my previous post which may help to explain what I'm referring to.
I think that's where the combination of hull and stem profile makes the difference; a narrow hull with deep stems will have a greater tendency to carve (turn) to the offside.
I have often heard Charlie say that heeling presents a "banana" shape of the hull to the water, opposing the paddle yaw with an offside heel. I find most of my solo canoes respond to a turn better with an outside heel in the turn with proper trim. In some I can hear the stern "break lock" as it slides on the surface while the bow tracks around the turn. With the exception of my zero rocker SR Blackwater, it doesn't seem to care which way I heel it either to counter yaw or to perform a fairly tight turn.
the offside.
So you're saying that the most efficient way to paddle a narrow hull with deep stems is by leaning away from the turn to offset yaw, even though you loose the benefits of a same side lean. These benefits would be paddling closer to the keel, a more vertical stroke and being closer to the water. I was out in my Seliga yesterday and got a strong offside carve from kneeling on the stern thwart. It did reduce yaw but it wasn't efficient, as the boat is too wide for comfortable paddling that way.
I feel that at a certain point when the stern stem gets deep enough and the bow stem gets high enough any hull will carve towards the side of the lean. There is a lot of talk about the release of the stern stem. What I'm talking about is the release of the bow stem. If your bow stem isn't in the water it can't affect the turn. I would think that in a lot of solos you can get to that point just by moving your weight back as far as you can on the centralized seat.
Finally, we had influencers such as Tom Foster (mainly in whitewater) and then Charlie Wilson (mainly in flat water) advocating and teaching the "inside circle forward stroke." In this quasi-forward stroke, the hull is induced to "carve" toward the paddle side and then this yaw is counterbalanced by an uncorrected forward stroke, making the canoe go quasi-straight without any need for correction. (I keep saying "quasi" because the canoe is actually traveling along the curved circumference of a very large circle, and must be kicked slightly in the other direction periodically.) However, the confusing point is that some hulls in the Foster/Wilson stroke will "carve" better toward the paddle with an inside heel while other hulls will "carve" better with an outside heel. The difference, generally speaking, is most pronounced between high and low/no rocker hulls I suppose that's possible because altering trim can alter the waterline profile of the hull.
When I was in the Seliga yesterday turning by engaging my bow stem away from the side of my lean it sure felt like a carve. In Tom Fosters videos he turns towards the side of the lean. This is something I have also felt, but usually with a more heavily weighted bow.
This is because of how it affects the stems for one thing. The way I typically paddle my bow stem is completely released from the water. By doing this I'm carving with the stern only and always turn towards the side of my lean.
Yes, that six inches or more in the difference of hull width is a big deal. Back when my only canoe was the 16' Prospector, when I paddled it from the kneeling thwart, all of my turns were heeled on the paddle side. Offside heel was not an option. In fact, the onside heel facilitated going straight as well. With both stems out of the water and the rocker in play, paddling "straight" was easy. And for that matter, the Prospector would turn - or even spin - either direction with ease. Poling is another matter though. With feet in the chines, an offside heel is always an option. But in the Prospector the advantage of the offside heel was never as pronounced as it is in the Coho, the Penobscot, or especially the Malecite.
I think maybe what you are describing here as carving with the stern pinned is what I would call a pivot. I can do that in the Coho, but it comes at all the cost associated with the shortened waterline.
Sliding my seat in the Solitude all the way back with my day tripping gear load behind me gets the bow out of the water.... barely. That does make it easier to turn with a heel on either side, but it still turns much quicker with the offside heel. It's been a while since the last time I stood much aft of center in the Solo 14, but I'm sure that at some point I could get that shorter hull's bow out of the water enough that it would pivot with no heel at all. The lack of stability then would be a problem though.
Anyway, we're talking about very different canoes. My experience is that the long, narrow, zero rockered solo does not respond at all to trim and heel changes anything like the moderately rockered tandem.
So you're saying that the most efficient way to paddle a narrow hull with deep stems is by leaning away from the turn to offset yaw, even though you loose the benefits of a same side lean. These benefits would be paddling closer to the keel, a more vertical stroke and being closer to the water. I was out in my Seliga yesterday and got a strong offside carve from kneeling on the stern thwart. It did reduce yaw but it wasn't efficient, as the boat is too wide for comfortable paddling that way. [My emphasis.]
I'm not saying it's the most efficient technique, but it's the one I've found works best for me paddling a fast solo touring canoe. The key is how narrow the paddler's station is in order to comfortably reach the water with a subtle offside heel along with a fairly narrow elliptical hull that is still efficiently moving forward when heeled slightly. I'm not trying to get the fastest speed, as in racing, but rather be able to carry good speed without having to switch sides as often. I like to paddle hit-and-switch but I don't like the switching part as much. :)
I feel that at a certain point when the stern stem gets deep enough and the bow stem gets high enough any hull will carve towards the side of the lean. There is a lot of talk about the release of the stern stem. What I'm talking about is the release of the bow stem. If your bow stem isn't in the water it can't affect the turn. I would think that in a lot of solos you can get to that point just by moving your weight back as far as you can on the centralized seat. [My emphasis.]
To me, the idea of having your bow stem out of the water while paddling forward almost necessitates having some lean in order to tell the canoe where you want it to go, otherwise it seems like the bow wanders around. But I haven't spent much time paddling with the bow raised because it didn't work well for me in the canoes I had. I paddled my 18.5' Wenonah Odyssey solo a few times and when I sat on the bow seat paddling "backwards" it didn't work, mainly because it was a tractor seat and the thwart is close to the bow seat. So I tried paddling sitting on a cooler up against the stern thwart and that helped but the canoe rode bow high and I had to use a lot of correction. It wasn't until I heeled to one side or the other (Canadian style) that the canoe settled down and moved forward with purpose. Same with our 16' Curtis Northstar. They paddled even better (when solo) with weight up front to get the "bow" stem further into the water, especially in the wind.
Even if I wanted to, it isn't possible (at least for me in the touring solos I've paddled) to release the bow by sliding the seat back or sitting back on a bench seat, not without adding considerable weight behind me. I can adjust pitch to compensate for wind effect but the bow stem (or stern if I move forward) remains in the water. Even in my Northstar Firebird, with 2.5" of rocker, if I sit back on the seat the bow stem is still submerged a bit. I have to heel the canoe to get the stems out of the water. But that's for turning, not going fast with minimal correction.
Interesting observation and something I use to keep the canoe tracking efficiently. A solo canoe paddled hit-and-switch travels in sweeping arcs due to yaw so it's a matter of deciding how much yaw is reasonable for efficient travel. Visual cues are the main prompts I use to switch sides but the sound of stern turbulence lets me know right away if the yaw effect is beginning to accelerate. If I start to hear that sound I know I've pushed the canoe beyond an efficient forward stroke and the canoe is no longer tracking well. The stern hasn’t broken free but the turbulence indicates inefficient forward travel. I try to minimize how often I hear that sound while maximizing hits per side/minimizing switches.
We are on the same page as far as using our hull to lessen yaw and having to switch less often when hit and switch paddling. we're just using different ends of the hull to do it. Out of curiosity, would a racer lean onside or offside in your boat during a race?
I do get a better carve with the stern when leaned over. This is probably because when leaned the hull profile changes and the stern sinks a little deeper making it carve better. It may also have something to do with increasing resistance on on side of the hull and decreasing it on the other. It's also possible that these two things are the same.
With no lean the bow is more easily deflected by wind and takes more attention to correction strokes or more frequent switching.
This makes me wonder if a boat with differential rocker (more in the bow) would help turn with the stern more easily. If not, then what is the purpose of it?
I've been researching that question online this morning and have yet to come up with a definitive answer. I can find anecdotal posts at paddling.com and here at canoetripping.net but nothing specific from racing focused websites, mainly videos of racers, mostly tandem. The book references I posted earlier in this thread are about all I've found. Again, I'm not racing and trying to maximize speed, I'm going fast in my canoe trying to maximize the number of "hits" before switching while maintaining efficiency in moving forward. I remember reading years ago that a bit of offside lean helps to counter yaw in a marathon C1 canoe but I cannot find the reference.
As I understand it, differential rocker keeps the stern planted in the water to assist in forward tracking while providing some bow rocker for ease in turning without having to heel the canoe as much. I think you'd benefit from differential rocker for your stern-weighted paddling technique.
And these two threads are applicable to the discussion, which has been going on for 20 years and more. The topic isn't new, but it's interesting to revisit.
Weight shifting & solo sit & switch – Yanoer (JUL 2005)
Heeling to maximize strokes. (forums.paddling.com/t/weight-shifting-solo-sit-switch/22316/21)
“The Slipper tracks better if I lean it up on the side that I’m paddling and it’s much less work to keep it straight. I prefer not to use corrective strokes when I want to maintain speed. When I would switch paddling sides, I would shift weight so that the paddling side was up and I could get more strokes on each side with less effort to keep it on track. Is this a common behavior in solo canoes?”
Solo Hit & Switch question – Tommyc1 (JUN 2005)
How much yaw is acceptable? (forums.paddling.com/t/solo-hit-switch-question/21533)
“Paddling solo hit & switch there’s always going to be some tendency for the boat to turn away from the paddle right?"
"Is there a rule of thumb for how much is acceptable before switching?"
"If I’m paddling on the face of a clock with 12 straight ahead, is holding it between 11 and 1 a good target?”
I've been researching that question online this morning and have yet to come up with an answer. I can find anecdotal posts at paddling.com and here at canoetripping.net but nothing definitive from a racing focused website other than my own inferences that there's no lean at all. Again, I'm not racing, trying to maximize speed, I'm going fast in my canoe trying to maximize the number of "hits" before switching while maintaining efficiency in moving forward. I remember reading years ago that a bit of offside lean helps to counter yaw in a marathon C1 canoe but I cannot find th
You are probably right about racers having no lean at all as this is what I find to be the fastest. You will have to switch more though. With the "proper trim" and lean I can eliminate the need for any correction at all and only switch sides when I want to. I adjust my lean to strike a balance between minimizing the friction it creates and controlling yaw to where I only have to switch when I want to. In a no wind situation is usually about 12 to 15 strokes instead of 3 or 4 on each side.
That is what I thought it was for. With the way I trim my boats I don't need it, but in a solo boat I think it would achieve my objective of carving with the stern with an effective onside lean to minimize yaw.
In addition to the skeg effect I think differential rocker also helps straight ahead cruising efficiency since the water is able to follow the contour of the stern better than if the boat had more stern rocker...which should reduce wake turbulence. Having less stern rocker than bow also adds a touch to the waterline length vs a boat with higher stern rocker. Many paddlers prefer fully symmetrical boats and I understand why but I've long preferred asymmetric boats for upstream cruising. I think there's huge variation in how asymmetric boats respond to a lean so in my simple mind I generally look for assymetric boats that also handle well.
I'm not sure I do. The only reason I have zero rocker solos is that is all I have found in the longer canoes in my limited used market, and the used market is all I have here. I seem to recall CW commenting that a little bow rocker doesn't necessarily cause an efficiency penalty. So I'd love to test that if I ever get a chance.
I think you would find that you would enjoy more of the advantage of being in a solo hull if paddling from the designed station with neutral trim most of the time. Why give up the efficiency built into the design? But in your honor, the next time I take out the Solitude I will make a point of seeing how that goes. I don't think I want to try it in the Moccasin.
I think you misunderstood me Steve. If I had a solo boat I would be in the dedicated seat. The boat already should be naturally stern heavy so it shouldn't be too hard to find one that'll do what I want it to. From a centralized seat you should be able to change trim from bow heavy to stern heavy. I don't know why you wouldn't be able to carve with the stern as well as the bow.
I guess I'm still stuck on the idea of lifting the bow out of the water. With the bow of the Solitude just clearing the surface, almost the whole offside waterline is still in play when carving. That means all of the chine ahead of the widest part of the hull is still a major influence. To change that to any significant degree, I'd have to either put a lot of ballast behind me or get behind the seat.
