• Happy Birthday, Doc Holliday (1851-1887)! 🤠🦷 🇴 🇰
Results of the more stringent 2024 bear-proofing food storage rules in the BWCA
As a frequent visitor to the BWCA I think it's too bad this was needed but it was, too many sloppy careless campers resulted in many habituated bears which is as bad for the bears as for the humans. There was a lot of complaining but compliance was pretty simple - either get or rent certified bear proof storage or hang. I'm glad to see that it seems like it worked.
During my one and only trip to BWCA, we hung, and sometimes it was tough to find a way to hang 12’ up and 6’ from a trunk. You need a large limb in an area where there are no lower limbs and no other trees nearby. There were sites where we couldn’t find such a limb and resorted to rigging lines between trees and did not achieve 12’/6’. Luckily, we were not visited by any bears and got away with it.
I’ve been in parks where the sites were equipped with either wire pulley systems (Olympic and Shenandoah NPs), an elevated log chained between trees (Yellowstone) or steel storage boxes (Grand Teton and Yosemite NPs). It’s a lot easier hanging if the site is equipped for it. But, BWCA is so huge with so many sites it doesn’t seem feasible to equip sites there with storage systems.
Which I guess leaves carrying a bear-proof container as the best solution. In the BWCA, where we averaged 8 carries a day, that’s a lot of carrying. I think I’d invest in one of the bear-proof sacks if I went there again. Hopefully, they are approved for use in the BWCA.
If you go the Ursack route, the "Allmitey" line protects against all animals. The non-Allmitey bags are susceptible to the chewing of rodents and other small mammals.
In some areas, specifically the Eastern High Peaks Wilderness of the Adirondacks, to be legal you must use a commercially made certified bear resistant hard side canister. Ursack bags and other flexible soft bags of the like are not legally acceptable, although those are useful protection in adjacent less restrictive areas against mini-bear type scurrying critters.
Why hasn’t someone made a bear canister the size of a small blue barrel? That way you can repurpose a barrel harness you probably already have.
Would also be nice if someone bothered to make these with a seal to contain odors and keep water out.
They also should have a way to attached a line to them. I know this would give a way a bear could carry it off…would have to design it so this connection is the weakest link.
A weather proof bear canister that could be hung (secured) would be the most secure.
Not a fan of the bags. The bear might not get an easy meal but it’ll destroy your food and thus end your trip.
In 1985 there were some habituated bears around. I remember running into one on a portage trail, but I had a canoe on my head so he took off at a run. A few days later we had one in camp after dark that was pesky and not afraid of humans. My 35 pound cow dog ran her off easily. She was used to working with large cattle.
Just like taking selfies in Ystone, the public seems to be losing some of their common sense.
If ever bear hunting in the BWCA I guess you could just set up a tree stand over a blue barrel.
The problem bears will get thinned out, plus meat from a bear fattened up on granola bars, GORP and Mountain House meals is probably delicious.
I would guess cost and lack of demand.
The bigger it is the thicker and heavier duty it will have to be. It would probably be cheaper to buy another bag to carry bear canisters than to buy a big bear canister that would fit your blue barrel harness.
I imagine the vast majority of bear canisters are for people doing hiking trips. They don't need the capacity and don't want to carry the weight.
There aren't a lot of canoe trippers in the grand scheme of things.
Yeah, you’re likely correct. Blue barrels started as repurposed olive barrels if I recall.
Company I work for does some contract molding and we molded some of the BearVault brand canisters….just the polycarb blowmolded bodies. Pretty tight margins I imagine after tying up $60k just in one mold.
"Last spring, Boundary Waters Canoe Area Wilderness (BWCAW) managers toughened the rules for how visitors store food, hoping to reduce the odds of encounters with bears.
"So far, they say, the moves appear to have worked."
Revisiting this thread, and I note that the link in the story to the new regulation goes to a dead page. Has there been an update?
I'm not seeing a dead link anywhere, Steve. An official summary of the new April 2024 bear-proofing order along with links to the actual order itself, a map of the affected geography, and a FAQ are HERE.
I just noticed that the order is only in force for two years and expires on April 19, 2026. Of course, the Forest Service can probably extend the order with another one if they want to.
The link I'm talking about is what they claim leads to the list of accepted containers.
Many of the common polyethylene blue barrels aren't on the list. (Find the list at bit.ly/bearprooflists.)
Okay, I found a link to the list in pdf by going to the source here...
My bear resistant container is in the group of "previously accepted but no longer available". I guess that means it's still good, but maybe no? Wording in the pdf is a bit ambiguous.
I'd think you're ok. Just go for it (maybe don't tell the Ranger where to find the list)
@Steve in Idaho, I agree with @Gamma1214. I've got the Counter Assault Bear Keg and the Bare Boxer (for 1-2 night solo trips hiking & paddling) and I plan to continue to use them. IIRC, the Garcia Backpacker's Cache—once the most popular and commonly used in rental programs—is only available through Amazon. I don't know if it's still be made or it's just NOS being sold off.
The IGBC-approved, bear-safe alternative to blue barrels could be open-head steel drums.
The 10-gallon version is a little larger than a 30L blue barrel (~8 gallons). The 16-gallon has the same capacity as a 60L blue barrel. The volume of five Bear Kegs is 58.5 liters compared to 61 liters for a 16-gallon steel drum.
Here are two sources for 16-gallon drums:
The weight of five Counter Assualt Bear Kegs is 18 lbs. The weight of a 16-gal., open-head, steel drum is 19 lbs. (Source 1, Source 2.)
I bit the bullet, and purchased two BV500 Bear Vaults.
A tricky lock feature, easy, once you learn the trick.
I really like, as It keeps me better organized, and even the small camp raiders out.
Now If I can only reduce what I take for food. To only need one ! Ha !
