• Happy 1st U.S. Census (1790)! 3,939,214 👪
little helper for loading the canoe.
Germany, Nohn
I saw the video here on YouTube and thought to myself: I need something like that!
So I took some screenshots from the video and then I rebuilt the cart.
P1000344.jpg after welding the frame it look like this - but how to fix the Wheel axle?! mhmmm .... screw-clamps!
still a little paint on it and the little scales is ready.
This will help me a lot to put my canoe from backwards to the roof of my car.
regard
Michael
Do you think it could be used for more then that little bit for loading the canoe? I guess it would need to be bolted on somehow for more rugged use.
Nice job though.
maybe yes.
it will be bolted from the other side with srcews an some plastik washers ... please have a closer look to the pictures an you will see how it works.
regards
Michael
I did see those bolts but it is on the tapered gunnel and pulling forces want to slide to off. I’m thinking something that engages the deck (even a bungee cord) would help keep it in place.
I took another look at your setup and you have a cross bar right by the hand grip. A Velcro strap would do nicely.
Canoe Cart 4 Wheel Dolly to Transport Canoe with Four Wheels which allows flipping the canoe for easy loading on vehicle upside down is what I just posted a photo of
I understand that Joe. Maybe someone will be interested, but Michael lives in Germany and my suggestion was to maybe help him make what he is building more useful. Not taking away from your 4 wheel version.
@jim
here on the pictures you can see how I have solved the clamping.
There are two PE rails that clamp tunder he gunnel.
and here are some pictures of using the trolley ... "easy going" by one person. (y)
put on the trolley
preparing the car (temporarily attach wooden slats for better sliding, and a blanket for the protection of the car)
Roll the boat to the car and put it on the roof.
ready to go.
And here’s the total setup for loading a 60 # Raven alone - a solid steel bar with one end inside the Thule bar and the other inside a hollow aluminum extension, all gorilla taped together and supported by a 1” hardwood dowel. Not pretty but it works and is much cheaper than similar manufactured setups.
Very clever and much cheaper than the $60 I paid for the used Yakima equivalent for my round bar rack.
