I read on one of the canoeing bulletin boards about how to handle northern. Someone replied back “ I lip them” well that got my attention. He described waterproofing leather gloves and then using them to handle fish. I still would not lip a northern even with leather gloves on but I do ware leather gloves to handle fish and rarely get my hand wet and never cut or poked. For more than 10 years I have used waterproof leather gloves for fishing and camp chores.
How to water proof leather gloves method one.
What you will need:
leather gloves
Sno Seal
ziplock bag
car dash on a sunny day.
Put the gloves on and grab a handful of Sno Seal and rub it in covering the entire glove. When you can’t get any more to rub in put the gloves in the ziplock bag and put them on the dash of a car in the sum. After an hour of two put the gloves on again and rub more Sno Seal into them then return them to the dash in the bag. After 2 or 3 iterations of this they will be water proof for long enough to do a two week trip.
If you get them wet in the inside prop them open with a stick and set them in the sun for an hour or two to dry.
How to water proof leather gloves method two
I have only done this method one time and only tested under the faucet but I think this is going to be my preferred way of treating my gloves. There have been several threads on how to seal a tarp and I had some leftover sealer.
What you will need:
Leather gloves:
Clear Silicone Calk: I use “kitchen and bath Silicone ultra. White lighting W21101010” available at Menards OR Mainstays brand sold at Walmart.
Camp fuel: You can also use low odor mineral spirits but the smell goes away with camp fuel but not with mineral spirits.
Old tin can to mix it in and stick.
The mixture I use is 4 parts camp fuel to one part silicone calk. For a pair of gloves I would estimate ½ ounce calk and 2 ounces of fuel. I use scales and weigh it but you could guess at the portions by volume. Mix and mix some more. It will take several minutes of mixing to dissolve all of the silicone. When it is all mixed put the gloves on and pore a table spoon full in the palm of one hand and rub it in. Repeat until you can’t get any more to rub in. It took me 4 or 5 times. Then cover the can to slow evaporation and set the gloves in the sun to speed evaporation. When the gloves are no longer sticky (about one hour) apply a second and third coat.
After handling fish wash the glove or it will stink the next day.
What you will need:
leather gloves
Sno Seal
ziplock bag
What you will need:
Leather gloves:
