• Happy National Paranormal Day! 🔮👻👽
Very interesting cart design
This is a nice looking cart-- looks sturdy and light.
Linder makes a ton of aluminum boats, including some nice canoes.
Many canoe carts are best-suited to short trips on flat terrain-- like transporting the boat from the car a short distance to the water. Canoe carts tend to be built fairly low, close to the ground. For long-distance humping over hilly and rocky terrain, the bed of the cart should be about 18" above the ground.
I've used several store-bought examples of canoe wheels on trails like the Bowron Circuit, but I found I had to make my own carts that are a little taller than what's available. It's easy to smack the trailing stem on rocks if the boat is too low; also, you have to walk bent over to keep the boat level. I'll post a photo tomorrow.
Here's one I made. It quickly disassembles for storage in the boat. It has 12" BMX plastic wheels, Delrin bearings, pneumatic tires, and a chrome-moly axle. The triangular frame is ash, the overal height of the cart is 18 inches, and it all weighs 7 LBS. The nominal weight limit is 200 LBS.
