Size Matters
SW OH - Land of Opaque Water
Took the Phoenix up a swollen creek and back down. It was a pleasurable paddle - lots of lining through rocky swifts. One thing clear is I need a new wood paddle for shallow streams. My BB Explorer is too long in the blade and a few inches too long in the shaft for this boat. Any suggestions for a durable, shallow stream paddle? Thanks.
How about a canoe pole? I've only played around a few times with one, but I find it much more comfortable to stand up and pole in shallow water than to sit and try to use a paddle..
I'm still tying to wear out the Rock Guard, on my first BB paddle. It's been nearly 30yrs. Yes I've reglassed the blade a couple of times ! But I can't seem to leave the bank without it !
When the going gets rough ? Out she comes !
I also have a few ZRE rec models, i've used racing and long lake paddling.
I can recommend BB !
I like the BB Expedition Plus for river use. Mine has held up to moderate abuse for quite a few years with the usual annual touch up and maintenance. I re-shape the grip a bit and oil finish it. The BB rock guard edging does seem to hold up unexpectedly well.
Annual touch up ? I actually have an unopened can of marine polyurethane varnish meant for that purpose about 10 years ago.
I like to tune up the shafts and grips on my wood paddles each fall. Steam/heat any dings if necessary. Smooth things up with some fine grip paper and give them a couple coats of oil. Flat water paddles get tung oil on the shaft, river paddles get an oil, varnish mix.
Nice project for a few evenings when the first snow is getting ready to fall.
