Oh, BTW - did the Genesis make it on your list yet?
The Mad River Twister was a somewhat radical solo hull design
successor to their "Rattler" design which was constructed for the 1984 Nationals and was one of the earliest hard-chine racing designs. It is radically rockered, has a flattish bottom, a pretty sharp chine, and a pretty narrow gunwale width.
MRC also used quite thin and lightweight wood gunwales on this boat. The Twister I bought had developed multiple cracks along the stress riser created by the side edge of the bottom core and required significant rehabilitation.
not be the most forgiving downriver canoe for someone who had not been in anything much sportier than a Reflection or OCA. The sharp chine would likely result in many swims early on.
due to its extreme rocker and very proud stems, the waterline length is pretty short for its length overall, so it certainly won't be the most efficient on the flats.
What about a Millbrook Kyote?
For 100 bucks in paddling shape, I'd get it and play with it - expecting to get something else for river tripping.
Is okay, just the same. "Playing with it", for me anyway, would amount to viewing 360° of every 20' of the river. Who has time for that?![]()
And a third used candidate currently in the works, one of the better do-everything solo canoes designs, especially for his size, weight and multi-use desires.
This is a radically asymmetrically rockered whitewater slalom racing canoe. Zero is about what it would be worth to me, and probably not much less than the total number of Kyote's sold.
My friends who own them use them primarily for river day trips, but some have used them for overnights. Some of these day trips have involved Class I and easy, short Class II rapids and they have functioned well
My guess is that if your friend's goal is to do whitewater day trips and run rapids up to straightforward Class II, without playing much in them, it will probably serve him well so long as he can handle the width. If he becomes interested in whitewater, I suspect he will look for another boat.
please if you know of any Millbrook boats that are free or really cheap, let me know!!!
have poled a Freedom Solo...briefly. A little squirrelly, but do-able. Kind of surprising, really. Not as easy as the Mohawk Solo14, but not entirely intimidating.
I got to see that same boat go down long stretches of class 2 and some class 3 on an overnight trip this last spring. The owner, Eric, had rigged splash decking of sorts on the bow. Basically a small tarp secured and draped over camping gear so it was raised in the middle.
One of my good friend have a Freedom solo that he uses a lot on big trips, He goes for 20 days in usually rivers that are classII-III+ and he goes solo! He likes the boat a lot. He is a great paddler, and can make that boat do what ever he wants!!
