• Happy National Beans 'n' Franks Day! 🐖🫘🌭
the physics behind a canoe's pivot point
In the thread about moving and turning a canoe with side slips, it was mentioned that the canoe's pivot point will shift a little bit fore or aft when the velocity of the canoe changes. The term used to describe this phenomenon is the "peripatetic pivot point". A google search explains this term by stating that when a boat is dead in the water, it pivots near its center, and as it gains forward speed the pivot point dynamically shifts toward the bow.
My own experience doing side slips seems to back this up. When I am doing a side slip using a static draw, as the canoe slows down and loses its momentum, I need to move the paddle back, or toward the stern, in order to keep the canoe slipping sideways without rotating about the pivot point. This theoretically keeps the vector from the power face of the paddle pointed at the pivot point. So far, so good.
But are we able to delve deeper into the physics of why this occurs? My search of old posts seems to suggest two schools of thought on why a tandem canoe won't go strait when both the bow and stern paddlers execute perfect forward strokes. To briefly summarize, the first school suggests that since the pivot point shifts toward the bow, the lever arm between the stern paddler and the pivot point is greater, thus magnifying the effects of the stern strokes. That makes sense. The second school suggests that the water pressure forces on the hull are stronger at the bow than they are at the stern, due to the eddys that form behind the pivot point, which would tend to hold the bow in place and make the stern easier to pivot. That also makes sense. So I don't know. Maybe all of this can be explained by Bernoulli's equation, or maybe it's just beyond the scope of this forum.
What are your paddling experiences with the shifting pivot point?
Sideways motion also shifts the pivot point. In aerodynamics we'd say the center of pressure shifts aft with increasing "angle of attack" (defined as the angle between the airflow and the chord line of the wing).
Can't it be both?
Bwca s centre of gravity also changes .
Love the pics where your dog is on the yoke.
I think i have seem a better explinatouo with vectors and physics and people try to do.maths in there.
I had a conversation once in the uk. Where a third idea was trown in;
I try to explain but language is a thing here.
The paddle stroke of the bow paddler creates a gap/hole in the water where there less resistance and gravietey puls the canoe in to fill the gap .
On second tought the has not much to with the pivot point but it has made me wondering for along time about the unkown phycis around paddlijg
Maybe know comptuer capacity is getting so cheap that maybe maths can do stuff. I see a project with a buddy of me and that guys that wrote a book about physcis and paddle strokes
Hiya,
While I can't explain the physics behind the sideslips or changing pivot points I was afforded an excellent demonstration of this very principle by Charles Burchill about 10 years ago. A number of us spent an afternoon "messing about in boats" and experimenting with varying pivot points...
I learned an awful lot that day and still have the tape on the gunwales from the identified pivot points!
Charles may be able to explain the phenomenon...
Cheers!
Bruce
When a boat is at rest with relation to the water around it, the center of lateral resistance (CLR)—more colloquially known as the pivot point—will be located at the center of gravity of the boat+gear+paddler. In a central seated canoe with no gear, that will put the pivot point at the COG, which will be approximately at the longitudinal center of the canoe. When the canoe begins to move forward with respect to its local water, the pivot point will move toward the bow; and, conversely, if the canoe begins to move backward.
This Charles Burchill video demonstrates the phenomenon.
When the boat is at rest, the rope tied abaft of the CLR=COG=pivot point will pull the boat laterally to the dock with no bow or stern yaw. However, when the boat is moving, the same rope attachment pulls the stern closer to the dock than the bow because the pivot point has moved forward to the bow. Hence, the rope pull is applying more vector (lever arm) force to the stern than to the bow towards the dock.
That effect certainly makes a lot of sense to me. I note strongly that when I power ahead and increase the speed in my solo canoes from a slower casual pace, it becomes much easier to maintain straight track with purely single side single blade paddling for any distance. As the pivot point moves forward ahead of my posiiton, even a gentle pitch stroke is all that is required as a minor correction to maintain straight ahead tracking from my solo central seat. A slight offside heel helps as well. Certainly, no need to add any obvious "J" beyond that.
I think the most pertinent sentence from the Clyde Winter article linked above is:
"The precise location of the pivot point, why it works, and how the boat moves in response to a force, depends on a lot of things with which we don’t have to concern ourselves right now."
I guess that will have to do. Interesting topic though.
I've never noticed the difference speed has on where the pivot point is when it comes to sideslipping but I think it is something you adjust to with paddle placement and angle. If you are solo in a boat, the pivot point will be close to your body. When dead in the water, a draw perpendicular to your body or slightly forward of it, if that's where your (center of gravity)COG is, will move the boat sideways. I can see when you have some speed you will need to reach forward with your paddle to get the same sideslip. If this is because your COG or pivot point moves forward I'll just have to take their word on it. It is possible that we learn how to compensate for such things without needing to know the scientific reasons why we need to do them.
One of the things I like about paddling from the stern seat is where the pivot point is. I find it much easier to turn a boat that pivots closer to the ends then the center.
Also very likely that a planted paddle is stationary in the water while the boat is not. I'm not so sure the pivot point is actually changing as much as it is now dynamic and will change throughout the paddle stroke.
As always, being aware of how your inputs correspond to outcomes is the goal.
You can empirically test this with the help of another person.
The more technical name for the pivot point is the center of lateral resistance (CLR). If you are in your stern seat with your usual gear load, the boat will move perfectly lateral, with no left or right bow yaw, if someone pushes or pulls the boat sideways abaft of the CLR (= pivot point).
So, if someone stands in the water and pushes your canoe sideways at different points of the hull, or attaches a rope at different points of the hull and pulls sideways at these different points, the fore-aft (longitudinal) location of your canoe's CLR/pivot point at rest can be determined when the push or pull location generates no bow/stern yaw.
I could probably test this by myself too. I could probably find the CLR by locating the spot where a draw stroke perpendicular to the boat with the paddle blade parallel to the keel will create a perfect sideslip. According to the article on the peripatetic pivot point, this should move forward with speed.
Approximately. When the boat is at rest relative to the local water, the pivot point will be under the combined boat+gear+paddler center of gravity (COG). You will probably be shifting the COG a bit, and hence the resting pivot point, as you shift to place your draw stroke in different places.
Since the resting pivot point starts out underneath the COG, you could also test its location by balancing your laden canoe on a sharp cliff edge or on the sharp top edge of a highway divider on a major highway. There are probably other "balancing act" tests that are less exciting.
