• 2026-29 Fund Drive needs only 5 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
the physics behind a canoe's pivot point
I could probably test this by myself too. I could probably find the CLR by locating the spot where a draw stroke perpendicular to the boat with the paddle blade parallel to the keel will create a perfect sideslip. According to the article on the peripatetic pivot point, this should move forward with speed.
It's not actually speed that matters; it's (neglecting the effects of bow rise with speed) the angle between the boat's centerline and the direction of motion. In aerodynamics we call this the "relative wind".
Picture a canoe moving straight forward, and you're looking straight down at the boat from above. We'll consider 2D flow, ignoring the water flowing under the boat*. In this 2D view, half of the water flows around one side of the boat and half flows around the other side. Right on the bow is what's termed the "stagnation point", where the flow divides.
Now say you're sitting amidships and sculling. The canoe is moving straight sideways, and the stagnation point is at the middle of the hull.
In between, when the boat is sideslipping while moving forward, the stagnation point is somewhere in between, and it moves forward as the sideslip angle decreases.
When things are symmetrical (straight forward or straight sideways), the center of pressure (the pivot point, more or less) is in line with the stagnation point. In between, when things aren't symmetrical, the stagnation point and center of pressure don't directly coincide, but they move in a similar manner.
The point is that the actual speed doesn't matter; it's the angle: if you're sideslipping twice as fast while also moving forward twice as fast, the angle is the same and stagnation point and pivot point don't move.
*Yes, 3D flow complicates things, but the general principle still holds. And, of course, the now lifting with speed changes the waterline length, which also moves the center of pressure aft even while the decreasing slip angle moves it forward... there's a lot going on. Hydrodynamics is messy.
That's a good explanation, never heard of stagnation point before. I'm not one to delve too deeply into scientific explanations when it comes to paddling or canoe movement. I base my understanding on what I feel when I'm paddling. Sitting in the stern seat my pivot point is way different than someone sitting in a centralized position but the physics are probably the same. In the end, what matters is that you can make adjustments with paddle placement and angle to compensate for the variables (ie, trim, speed, wind and current), to get the boat to do what you want it to do.
