Removeable Yoke for CF Gunwales
SW OH - Land of Opaque Water
Im looking for ideas to convert a homemade portage yoke designed for threaded anchor gunwale inserts to one that will grip standard Northstar carbon fiber gunwales without damage.
I gotta say, I really like Savage River's setup for thin gunwales. It wasn't clunky at all, and made for a solid connection that could be moved fore or after to make up for preference or attached gear.
I had a yoke long ago with those plastic two-piece clamps. I found these and some videos of yokes made with them. The downside is the product is canoe specific since the hole must be drilled precisely. I may give them a shot, perhaps with two sets of holes for two different solo boats. Maybe I’ll dip the ends of the yoke in liquid rubber to cushion the carbon fiber a little.IMG_1820.jpeg
Tryin,
Piragis still sells a yoke with those clamps. I had one long ago but it was very clunky, heavy. I’d love to find those clamps, however.
Whew, they are proud of them. McMaster-Carr had some similar, but even more moolah.
Northstar sells some overpriced bent aluminum that works kinda the same.
Yeah, I have a NS solo yoke. It works well for my NW Solo, but I’m careful. I dipped the aluminum clamps to cushion the CF gunnels. It’s short for the canoe I want to build one for, which has a 30” beam. I do however, like the thin wood NS uses. The NS yoke is only about 5/8” thick.
I saw those Swift clamps, but availability is often an issue with their accessories, in addition to the price and the shipping charges to the U.S.
Savage river lists two yokes on their site, one wood (no photo) and carbon fiber (bad thumbnail).
So basically no info… do you have pics? Tell us about how their yoke works compared to traditional solo clamp-on yokes…
Bonus points if you know the weight.
Here is a pic, it uses a protected cam buckle for closure. With the gunwale setups that I saw, it gives you about 4-5" of front/back adjustment, maybe more with straight gunwale lines. I didn't have a scale, but I would guess ~18-22oz.
An aspect I didn't really think about was how much the strap firmed up the sides while shouldered for carry. There was very little "bounce" to the arrangement, certainly much less than I have experienced with other very lightweight layups. I believe this is the result of stress being transmitted into the chines along the arc of the hull via the strap, rather than across the chord. This allows for flex to be constrained by the strap, instead of the gunwale collapsing toward the bottom of the hull.
Thanks - had forgotten that the thumbnail actually expanded.
Not really in love with it. For tripping, there is a zero percent chance I am strapping a yoke around the hull. With my current setup I can exit the canoe, attach the yoke, clip in the paddle, put on the pack and get the boat on my shoulders...walking in under two minutes. At the other end of the portage I can be paddling in under one minute.
I do like that it could be moved forward and back.
Guess I am picky. Needs to be very light, very fast to attach/detach and tough (100% reliable).
FWIW, I had never used the system before and had the yoke on in less than 30 seconds. Floating the hull over the strap in the water was the quickest. Faster than my Swift clamp, and waaaay faster than the two Wenonah options. But, I definitely dont have my system tuned to the level that you have, so the yoke attachment time is comparatively insignificant regardless... 😅😅
Running a strap around the hull is a clever idea. I can see that being quicker than most clamps in many situations.
Nova Craft has a removable portage yoke that uses basic hardware parts. $27 CDN for the hardware kit, $150 US with the thwart added. The kit looks like ordinary hardware store items. I already have a salvaged Old Town center thwart. I picked up hinges, etc. at the local hardware store but haven't assembled anything yet.
I like the clamp on designs better, because they don't have parts permanently attached the gunwale to cause injury. Harbor Freight might have clamps similar to those in #5 above; I can't log onto their site right now. Maybe non-marring clamps could be cast from reinforced epoxy, 3-D printed, or even steam bent from wood.
Slipstream Watercraft recently came out with their own yoke designed for their thin and delicate wood gunnels with injection molded plastic clamps. I have been using one for both my 36 pound Lady Bug with wood gunnels and 30 pound Dagger Tupelo with aluminum gunnels with success. If my Swift Kee had a gunnel with a lip I wouldn't hesitate to use the yoke with it as well.Slipstream.jpg
This is what I’m contemplating. It’s not going to be lightweight, but this is a comfortable yoke for my busted wing, and I’m building it for a 45# canoe. Maybe I’ll put some flex seal on the wood, fill the countersink. Pardon the mess.
