• Happy National Dog Day! 🐶🐩🐕‍🦺
Getting in and Getting out
I always have a pack of some kind in front of my seat. Daypack or fishing gear. I step over the pack, putting downward pressure on the gunwales to keep it level, then put my butt in the seat. My other leg follows. I used to go a moving entry like Steve describes, back when my balance was better. Now I just get my backside down as quickly as possible.
I’ve used all the various methods identified in this thread ay one time or another depending on the situation. Any of them would be good to try and start with.
The best advice I ever got was to keep your head inside the boat until you have your balance outside the boat and the converse.
All instruction breaks down when the access or egress is deep water only, when the waves are crashing into the shore, the bottom is deep mud, etc.
After I broke my ankle, I lost the ability to get in and out of the canoe normally. During rehabilitation period, I had to crawl into and out of the boat, getting thoroughly wet in the process.
I'm somewhat similar- I broke my back a few years back and lost almost all feeling in my left leg, after several hours in a canoe I start losing all feeling below the waist, which absolutely destroys my balance, so my ability to get in or out boils down to basically quickly barrel rolling over the gunwale before I submerge it, yeah I get wet but that's secondary to the amount of gifts the local cobra chickens leave on the shore or floating in the water- I now keep a gallon of water and a change of clothes in the car...:ROFLMAO:
Cobra chickens....
I need to add that to the list with trash bandits, slimerockets, Holstein pheasants, sagerats, and speedgoats. :D
I like to do the paddle across the gunwale method. Iif possible, as the blade shaft is gently held across the gunwales with both hands and the blade gently presses with slight force on a low dock or the land itself as I lean that way and easily step in one foot at a time. My other favored miethod is while standing in shallow water to sit sideways on the seat over the gunwale. Keeping my head and CG over my knees to prevent over rotation backwards, I just sit, then rotate my feet in.
I do the same thing if I'm bracing off land or a dock, paddle in front when I kneel and paddle behind when I sit
The problem with getting older as a canoeist is that big canoe are easier getting in and out of because of their stability and potentially higher seats, but big canoes can be too heavy. So far my composite Seliga at 40 lbs is light enough and is stable. I still mostly paddle my w/c boats but can see the day when they will be too heavy.
Getting in from a shallow bottom is the easy part. Getting in from a dock or similar hard, raised situation is the challenge. On the Hornbeck Boats website they have a video demonstrating the weird process they recommend for that. The first part of the video is the shallow-water situation -- I'm talking about the second video, about docks. I still find it confusing and will go to great lengths to avoid using a dock. :-) I'll attach a link to the video.
Pack canoe entry
Getting in from a shallow bottom is the easy part. Getting in from a dock or similar hard, raised situation is the challenge. On the Hornbeck Boats website they have a video demonstrating the weird process they recommend for that. The first part of the video is the shallow-water situation -- I'm talking about the second video, about docks. I still find it confusing and will go to great lengths to avoid using a dock. :-) I'll attach a link to the video.Pack canoe entry
I’ll take a rocky beach to a dock or boat launch every time.
At 71, I'm still paddling my 32# Sawyer Autumn Mist most of the time, especially earlier and later in the season when there's more in my gear kit. I agree, it is only a matter of time until my Hornbeck Classic will be the main boat. I also fear that the time will come when I will be doing a lot less (if any) camping in the backcountry and will limited to campgrounds or motels and doing day paddles. So I'm trying to get as many of those backcountry canoe camping trips that I want to do again done while I still can.
Hi all - I’ve been following this discussion with interest. My grandfather has paddled his whole life, but in the past couple of years, he’s had a couple of falls getting out of his canoe in shallow water. It’s usually that sideways roll during the first step that catches him. For those who’ve paddled into their 60s/70s, has entry/exit become noticeably harder over time? Do most people rely on refining technique (paddle brace, deeper water entry, etc.), or have you found stabilizers or other aids helpful?
I’m just trying to understand whether this is a common challenge and how people are managing it. I appreciate any perspective.
At age 74 I use a couple of methods. from a low dock or low shore bank, I brace my single blade across the gunwales with blade on the dock or shore. Both hands holding teh paddle shaft on gunwales. It takes practice with a Hornbeck or a skinny blackwater or a PB Shadow. One foot in, slightly outboard of center, then the other goes quickly in to balance as my butt lands on the seat. The other method is when in shallow but floatable water. approach with back to the boat, sit sideways with butt across the gunwale. Then ease to just sit in the seat. When steady, swing both legs in. The trick is to not lean back too far during the sit. If you do, you will roll over backwards. You will do that only once. (don't ask me how I know).
Ryan, welcome to site membership! Feel free to ask any questions and to post messages, photos and videos, and to start threads, in our many forums. Please read Welcome to CanoeTripping and Site Rules! Also, because canoeing is a geographic sport, please add your location to the Account Details page in your profile, which will cause it to show under your avatar as a clickable map link. Many of the site's technical features are explained in Features: Help and How-To Running Thread. We look forward to your participation in our canoe community.
Of course. Balance issues and muscle weakness (sarcopenia) are very common issues with aging. It affects some older people worse than others.
Most folks here who are experienced canoeists and who mostly paddle alone would not rely on stabilizers unless absolutely necessary because they would not enjoy paddling a canoe with stabilizers, nor would they enjoy carrying such additional weight. I suspect most would try to refine or take greater care with the methods so far discussed.
For 20 years I had a composite, very light Hawaiian outrigger canoe. That watercraft is very easy to get in and out of. You just put it in eight inches of water, straddle over it, and sit down. To exit, just paddle into shallow water, stand up, and step over the hull.
Put your butt in first, then swing your legs around. Works in solo and tandem.
Mason, you are the first person to mirror what I have always thought was the best way of getting in the canoe. So many folks seems to think putting feet in first is the only way to get into a canoe, I always figured that once your butt is in, then the rest is easy.
I did a video when i launched my last canoe, the first few minutes show the entry I use, get that butt in first and the rest seems easy
2024 Canoe First Water
I like to launch wet, parallel to the shore ...
That was smooooth. Careful attention/extensive experience with the correct launch depth at work right there. I always seem to miss it by a couple of inches and either have a bit of a flop (canoe too low) or a bit of a roll (canoe too high).
Good demonstration video, Brian.
I suppose that could work if one is a kneeler. Get into a sitting position and then, as a second step, wrangle your calves under the seat while you are sitting.
But putting one foot in first, holding the gunwales, then sliding the initial foot under the seat while bringing the second foot in, and finally sitting after sliding the second calf under the seat . . . all of that can be accomplished by one sort of big continuous movement. So, perhaps the preferred method may depend upon whether one wants to end up sitting or kneeling.
Nice video. I often use a similar technique with a couple small differences. Stand facing away from the canoe with left hand on the near gunwale just behind the seat; right hand on the far gunwale near the front edge of the seat. This allows you gradually transition your weight to the canoe as you slowly set your butt into the seat nice and easy like you're lowering yourself into a very hot bath. The key is a controlled transition of weight from your legs, to your hands, and ultimately to your butt in the seat; no plopping necessary. It can be done in water ankle deep all the way up to a depth that brings the gunwales nearly as high as your butt. I find the ability to launch in deeper water helpful on rocky shores that are getting beat up by waves.
I avoid docks at all cost.
Low to the water docks are my first choice for getting in or out. I'm a wimp when it comes to wet-footing. If I can keep my feet dry and still not scratch my canoe that is what I go for.
A couple of years ago though in my eagerness to avoid wet feet for a local paddle I decided to try entering my canoe from a dock that was well above the water level. I could not just dangle my feet off the edge and slide down into my canoe the way I do from lower docks. As I slid/jumped myself off the dock towards the canoe it rolled out from under me and I ended up standing in waist deep water. So much for trying to keep my feet dry! It was an embarrassing display of how not to enter a canoe.
