• Happy Release of World's 1st Animated Cartoon (1906)! 📽️(➡️🧵)
Alan's Bloodvein II
Blairsville, PA (about 30 mi E of PGH)
I've come to enjoy building canoes during the winter and experimenting with different wood combinations. The decision of what to build is normally tough but was made easy this time as the plans for my 2026 build are courtesy of @Alan Gage. Although this hull has been called other things, I'll steer clear of any possible profanity filter edits and simply dub it the Bloodvein II.
This is the revised version of the hull that Alan built for his trip down (and back up) the Bloodvein River. Upon returning, he decided that more rocker was needed so he revised a few of the fore & aft stations before building his composite version. I'll trust his judgment and skip version #1.
The issue of what wood to use was not as simple. I've still got lots of Aspen, Tamarac & White Pine but didn't want to repeat a wood choice yet. I've recently acquired nice supplies of Catalpa, Yellow (Tulip) Poplar and Sassafras but none of them were dry yet.
While helping my daughter find some Walnut for another project, however, I ran across a good deal on some kiln-dried Yellow Poplar, bought 100 board feet (at $1.50/brd ft) and also bought some Walnut that had far too much sap wood to be worth much. I'll have a little more in this build than when I kill the trees myself but I consider that better than waiting for another year.
I took advantage of nice weather today and decided to cut strips in the yard and, at this point, I'm thinking that I may have over-bought on the Poplar. For whatever reason, I've been thinking that I use 60-70 board feet per hull while I know that can't be right (60 feet of White Cedar would weigh 110lbs so, even if 1/2 of the board winds up as sawdust, that would be 50+ lbs of wood before glassing).
The Poplar that I bought is 4/4 (1 inch thick) rough cut, 10 feet long and 14 inches wide on average. I sliced 1 1/2 of these before dark tonight and it's looking like 2 boards might be enough Poplar for the build even though that's only about 20 feet of lumber.
I may count strips on the Raven (which is a similar hull) and I'll need to see if I can get enough clear(ish) heart from the Walnut out boards when I get back to it later this week.
I'm also hoping my architect friend can get the plans printed but, with Christmas mid-week, I might be cutting forms after the first. Nonetheless, it feels good to have the next hull figured out and started.
Building a wood strip canoe was a goal of mine back in the day but I now accept that if I haven't built one by now, it's never going to happen. So, I'm impressed when I see someone build one, let alone two or more. A stupid naive question, but without a table saw, how do you keep the strips fairly consistent in thickness, some sort of guide?
DOH! I see the guide now. :rolleyes:
Not my idea. At least for me, it came from this forum. It's a piece of aluminum angle that I've bolted under the shoe of the circular saw so that it's 3/16 inch (7.62 cm) from the blade. I leave it there as that's all I'll use that saw for now. (a slight bend on the infeed side allows it to slide easily on the rough edge)
One word of caution: That guide completely disables the blade guard and the saw must be placed on its side, on a 5 gallon bucket or held until the blade stops on its own. If you forget and set it down on the board you're cutting, you'll gouge some future strips. Get careless and allow it to contact something else and you'll gouge something else.
...theoretically you have to build 4 boats now.
Thanks, Brian. I'm (again) using 3/16 inch strips but the extra Poplar won't go to waste. I've got 250 board feet of Catalpa (Toby tree) drying right now and, as it turns dark like Sassafras does in UV light, I'll probably use some of the extra Poplar for gunwales, seats, etc on my next build (most likely a tandem as I have a granddaughter that loves the outdoors)
It would also look great paired with Bald Cypress as soon as I can figure out the logistics of transporting it.
Even at 3/16, the Poplar has me a little concerned. Alan used 3/16 inch Cedar above waterline and 1/4 below and still wound up at 48 lbs. Using your calculation of 24 brd ft (2 cubic feet) and my estimation that roughly 1/2 of that will lay in the yard as sawdust, I'm still working with a 6 lb weight disadvantage. We'll see if minimal outfitting can still bring 'er in close to 50 lbs.
That will certainly be more likely once I get the plans at the correct scale. When my friend printed the first set, I told him that the line where the forms attach to the strongback will be 8 inches if the scale is correct.
Having never built a canoe himself, he printed them out without checking the line length (probably didn't understand which line).
That reference line is 11 1/2 inches long instead of 8 so, if I compensate for the extra width by stretching the forms until proportionate, I'll be renaming this build Noah's Arc.
I predict that the bare hull weight after sanding should be in the ball park of 18.5 pounds, standard 6 oz glass if you are careful, should be around 11.2 pounds, 4 oz glass will save a bit at 10 pounds.
So ready for trim weight should be close to 28.5 pounds, the wood choice weight cost is ~4 pounds .... if you are careful, you can do a lot better than you are thinking, but those trim decisions can be tough.
Brian, remind me to weigh it after glassing the inside & we can check to see how close you are.
Planned lay-up is 4 oz e-glass in & out w/ an additional 4 oz e-glass layer on the inside football to increase impact resistance (gonna happen). I've considered some s-glass on the exterior football to increase abrasion resistance but I remain undecided.
I can't find 4 oz s-glass in 24-30 inch widths but I can always add it after the exterior gets torn up a little. (I'm tempted to try 2.5 oz s-glass on both footballs just to see how it holds up with a minimalist lay-up)
I'll try to get some clear heartwood out of the Walnut outboards before the weekend is over. If I can't salvage nice color, I'm debating using Sassafras (again) for trim or doubling down on the Poplar and doing the whole build with just the one species. (would that be too boring?)
I guess, if it is I can always shpit on it (I've got lots left :LOL: )
Gamma, one thing to note about walnut ... it fades with exposure. Not a deal breaker, but it is something to keep in mind.
I did up my Kipawa with cherry/walnut gunnels and stems ... the cherry darkens a lot on exposure, walnut lightens and all the contrast I had initially gets more muddy with time, walnut is one of those woods that doesn't get better with exposure.
True. Darker woods (IME) get lighter with time while lighter woods get darker. Cherry turns a beautiful dark red and the Catalpa seems to age dark like Sassafras into a warm chocolate brown. I'll get a moisture meter on some of it tomorrow... I think the Poplar will stay much lighter so the contrast might endure better with one of those.
Can't wait to see it come together. It will be nice to have another one of them out there in the world.
It's still my favorite all around hull. I didn't think anything would ever replace my Magic until I built this. If I ever get the itch to build again it would be interesting to build an UL version geared more towards day paddles rather than serious tripping.
Alan had kindly sent me the plans for this canoe many years ago when I was contemplating building a new fat canoe for my pre-cardiac bloated carcass. I couldn't get over my love affair with the Raven though, and went with what I knew. I'll be interested to hear a side by side comparison of your Raven and the Bloodvein.
I've never paddled a raven but I think there will be a pretty big difference between the two.
I believe the plans I had sent were for a larger sized solo that would be more comparable to the raven. I remember at the time I was starting to design a higher volume solo that could carry a big load on bigger waters and I was picking your brain about what features you liked on the raven and similar hulls. The plans I sent you, as I recall, were based off those suggestions and then I used that information and tweaked the design to better suit me. I don't remember what changes I made between it and the design I sent you. I built the hull but still haven't had a chance to really test it other than day paddles.
I'm, honestly, wondering if this hull will be too much volume for the 2-3 weeks trips (w/o a pup) that I'm planning (the Raven is more volume than I need but I do like the way it paddles). When looking at plans, however, I struggle a bit in visualizing how boats will look or handle so I figure I'll just build them all and see. (less thinking, more doing, eh?)
As for a side-by-side comparison, you may get the opportunity to try them yourself. I have a friend who is retired Air Force. He was bummed out when I didn't take him on the BWCA trip and I recently learned that he was a lot more disappointed than I had believed. Although I love going solo, I think I could get along with him well enough and non-solo might be an interesting twist.
I've asked him if he wants to tag along on the Wabakimi trip with the understanding that it might take 3 weeks or it might not be do-able at all. If he decides to take the plunge, I may be bringing both the Raven and the Bloodvein North in August. Wouldn't take much to meet you somewhere around Nipigon & untie the boats and I've been figuring on 2 nights of crown land camping on the way to Armstrong any way (you bring the beer, OK?)
I thought you might like to see your beloved Raven built from Tamarac (fair warning: it's even prettier in person and you might have to build one yourself) so I've been figuring on bringing it. Might bring both even if Rob (yet another Rob lol) decides to tap out but, if that happens, I'd prefer to toss one of them in your yard while I'm taking the long black train from Armstrong. (OK, so VIA isn't black but my destination is the middle of nowhere and I'm rarely able to resist tempation... though that might be a lack of effort)
I think the answer could be yes or no depending on how you like to paddle. A lot of people trip out of 13 or 14' boats and I don't know how they do it. I personally like paddling a longer hull whether I need the room or not. It fits my paddling style better. The "Barrens" hull that I linked above, which I believe has somewhat similar dimensions to the Raven, seems much larger in comparison.
I don't think of the Bloodvein as a terribly high volume hull. It has similar dimensions to many other 16'x30" hulls and the paddling station is fairly narrow to make it more comfortable to paddle. Most of the extra volume comes above the water line because I wanted plenty of room for the dog and also to allow it to shed water when plunging into waves and to hopefully keep it from plunging as far. I think it looks bigger than it paddles.
I know I told mem that I'd get crackin' on this build this weekend but I've hit another snag with the plans. I misunderstood the scale and had them printed about 80% of the actual size. This might leave me with an Olympic Sprint boat (if I leave station spacing at 12 inches) but I doubt that it will be suitable for wilderness tripping.
I'll have to contact my architect friend again on Monday to try once more (for whatever reason, he seems fascinated with these projects and has yet to tire of me)
In the meantime, I may have solved a bit of a mystery.
Especially after the Raven build and mem's comments that 50# was an excellent weight for that hull, I've been wondering how I've been getting lucky enough to land on the light side of every weight estimate and I think I finally have it.
Because the fence on the circular saw follows the edge of a rough-cut board, any minor deviation from straight gets exponentially greater with every pass. This has never been an issue when working with 6 or 8 inch wide boards but, cutting up 14+ inch wide Poplar, the edge I was cutting from started to look like it should have whitecaps so I took the last 6-7 inches to my buddy Dewey's wood shop and used his joiner to true them up.
Being a helpful guy, he threw the trued board on his table saw and ripped a couple of strips 3/16 of an inch. His strips looked substantially thicker than I remembered mine being so we stopped & I returned to the boat shop with the trued Poplar and the 2 strips he'd cut.
Sure enough, I was correct and the fence that I thought was 3/16 inch from the blade is not. On the (VERY) plus side, I am extremely pleased with the consistency of strip thickness with this method. Being careful to hold steady pressure against the board while cutting results in outstanding machine tolerances.
Sorry to post so many pics but I simply cannot believe that there was so little deviation... There are spots where I got lax with pressure and the strips thinned (I cut those out as I bead & cove) but I am sold on this strip cutting method.
Also, I understand that I am producing considerably less than 3/16 inch strip thickness which (in my mind) explains why I've been hitting the light side of weight estimates. I had thought of trying a build at 1/8 inch to save weight but I'm pretty sure that I won't even bother now.
I've Preached the benefits of a Skilsaw, with a fence clamped to the base, to cut strips.
I still believe, its the best way to cut strips from wide planks.
Glad to see you too have made it work !
You will learn from every hull you build.
Gaining from your experience, as I did.
Extra thin strips present a challenge, and I'm sure that you can over come.
As for the plans ? It's simple to go to a good Print shop, and they can adjust printing of the plans, to suit you.
Good Luck !
For future reference, you should get your buddy to use the jointer on all your boards. The first step of getting good strips is having a perfect edge to begin with. I have just started ripping 1/4 inch strips for the new 20 footer, the first step after thickness plaining for consistency is to run every board through the jointer.
Now that I've started some strips with that perfect edge, I'll agree that using a joiner is a great idea. I think it would allow me to slice up the entire 14 inch board without the edge becoming too wavy, and it makes it unnecessary to discard the first strip.
As for thickness planing; I don't do that. I'll cut the bead first and then force the strips between the shaper bit and a solid fence when I cut the coves. That uniforms strip width for me and saves a step.
I'm not saying that planing boards or starting with finished lumber isn't OK, I'm just trying to assure anyone interested that you don't need a lot of tools to build these boats. A shaper or router table (IMO) eliminates the need for a planer and, in a pinch, you can eliminate the need for a joiner by discarding the 1st strip (but you'll have to be more careful holding consistent pressure on the saw to follow the edge).
Some boards will move as you remove material as internal stresses are relieved. When I was using cottonwood those planks really tended to crook while cutting strips, despite being jointed before hand. I stopped 2-3 times during each plank for a quick run over the jointer to keep it true during the process.
