• Happy Birthday, Nicholas Katzenbach, my old boss (1922-2012)! ⚖️
Need a Bigger Shaft
SW OH - Land of Opaque Water
I’ve been dealing with Trigger Finger, which makes it hard to grip smaller circumference items. Is there a custom shaft diameter, or a diameter option paddle out there?
Surgery might be in the future but not this year, by golly gosh darn.
Thanks
Tony
Somewhere on myccr HOOP_ shows how to wrap a shaft with rope so it makes a firm grip with larger dimension.
From Hoop_ on myccr:
The classic way of wrapping a lower paddle shaft is using the whipping cord technique. The cord is smooth and bump-free since there are no knots. The whip is wrapped and pulled very tight, so it feels good in the hands and does not impede any sliding, and it won’t slip. It completely protects the shaft in the wear area (about 4-6 inches). I used 2mm climbing accessory cord.
Paddle wrap thread
The above might give you more ideas. I can’t find the instructional post he made.
I've been thinking of wrapping my paddle shaft because my main solo boat has aluminum gunnels and I want to reduce noise. I haven't done it yet but found a couple videos. They focus on the rub area but I don't see why you couldn't extend it higher up the shaft to where you grip it.
