• Happy Birthday, Judge Joseph Wapner (1919-2017)! 📺🤼⚖️
Canoe seat replacement parts - Drilling dowel holes
Appleton, Maine
I need to make a replacement part for a canoe seat. Cutting it down to size is no problem but I’m wondering if anyone knows a simple procedure to line up the holes for the dowels. I don’t have a drill press, just hand tools.
Thanks
It looks like dowel locator inserts will provide very exact results. But haven't we all replaced seats without such precision?
Crude but effective method: clamp the seat to the gunwales in the position you want it. If the gunwales are new, drill the gunwale and seat frame at the same time. If you are fitting into a canoe with existing gunwales, just take a pencil, put it through the the existing seat-mount hole, and mark the seat frame. And, it appears you have the old seat, so you could just put the old seat on top of the new seat and drill through the old seats existing holes.
I've installed a dozen or so seats in this manner. I'm thinking Robin and Boatman53 have installed way more seats than I have. It's so simple I'm thinking I must not understand the problem.
I believe Chip has the right answer, simply clamp the two members together and dill them at the same time. Dowel points like the ones in the pictures are designed to be used with a brad point drill bit.. Trying to drill by hand, machine bits has a tendency to "walk" or wonder just a little bit
Haha, I probably didn’t explain my problem correctly. I need to make a new section for the canoe seat in the picture. The new piece will be held in place at each end with dowels and glue. I will need to drill somewhat precise holes in the new piece to match the existing holes in the old frame so I get a flush fit on the top when I insert the dowel into the new piece.
Boatman53 nailed it with his idea.
Thanks for the interest.
Boatman53, The guide you show is much more reliable for a true cut than the dowel centers. I would certainly recommend the guide over the dowel centers with the guide giving better results. The guide helps prevent the unsteady hand from moving where the dowel centers only mark the center and does nothing to help steady the drill bit. I've used a commercial one similar to that a few thousand times with good results.
You still need the center points to locate where the hole should be.
If I were to do this on a regular basis I would have both. I only need four I” holes, once those center points give me the spot to drill I’ll be good. Getting a 1” deep hole close enough shouldn’t be a problem. That’s why someone invented sandpaper and a file.
Getting the holes straight freehand is always a challenge. I've used the guide on the right with great success, but I believe it's probably no longer in production. I recently found this Harbor Freight guide on the left that comes with threaded inserts for several increments, plus the two holes on the right for 7/16 and 1/2. Both are very adjustable. The HF one is easier to use for multiple centered holes, but the one on the right can be adjusted for thicker stock and off center holes.
