• Happy National Audubon Day! 🐣🐦🦅🕊️
Seat Pad
SW OH - Land of Opaque Water
After ann extensive search I found a pad to fit my Swift bench seat, Im hoping to upgrade my NW Solo seat pad. Currently using an inflatable that is ok for short periods, a pain to inflate. Anyone found a durable, non-inflatable standard size pad that cushions decently?
It’s tough to gauge comfort without testimonial. Im hoping to find one that not only supports my booty, but also straps on between the attachments of my backrest. Cushgear might want to expand the width of its Backsaver because it attaches right where seat cushions with straps attach. Some can be routed around the clamps but many cannot.
That said, I don’t turn my nose up at DIY options. I’ve tried closed cell foam and web straps - just not comfortable with the foam I used.
I have quite a collection of seat pads and the one I use all the time is the Oak Orchard pad. Pics show it on my Merlin II with Northstar seat and on Swift Osprey. It also makes the boats very comfy to carry just resting the seat on your shoulders; I've never considered using a yoke.
My first voyageur canoe had hard plywood seats with a thin (very thin) insulating pad on top. (original classic voyageur canoes had only a narrow flat wood bar thwart to rest your butt on). Difficult to take for an 8+ hour race. We looked forward to the ADK-90 portages as a welcome break from the seats. The voyageur I next paddled and on the marathon Yukon River races was captained by a hospital worker. It had hard carbon fiber seats. He was able to obtain a large bed size gel pad that he cut into individual seat sizes. Beautifully comfortable on the butt all day and night. Our ground crew sewed cases and handle straps for them. The problem was they were heavy. So heavy they would sink if dropped into the water. But since there are not any portages on the Yukon races, they worked perfectly for our maximum paddling day of greater than 24 hours without taking a shore break. Since then I have discovered blue honey comb gel pads on Amazon that work great. Much lighter, but still somewhat heavy and add a lot to the total weight percentage to a 14 pound bushwhack canoe. The other main problem of how to secure the pad in place on the seat or elsewhere during an overhead carry. The Skwoosh canoe pad is fairly light, comfortable and small, an works well for a solo canoe.
I have a Skwoosh pad, it's ok but I fortify it with various layers of other types of padding.
My arse doesn't come with much padding and what little I had 40 years ago is pretty much gone so I have real problems on extended trips (a month+) especially if there is little in the way of major rapids, portages, lining etc to give my arse a rest.
A few years ago on a 30 day trip I developed fairly severe "bed sore" that took a couple of months to fully heal and was truly "a pain in the arse" while on the trip.
I have some experience dealing with bedsores in the elderly, it never occurred to me that I had entered "elderly status" (almost 70 at the time). I know this is a major health issue for the bedridden, it never occurred to me that they could develop from paddling.
Many on my marathon Yukon team have discovered something even more ofensive than a sore bum from hard sitting. We call it "monkey butt". it is a painful chafing between the butt cheeks that sets in after many days-long paddling hours. A lubricating and antibiotic cream applied each morning is the simple preventative.
2 words- Arno straps...
these are the quintessential hold everything straps from the 70's that were used for everything from attaching sleeping bags and pads to your pack to bundling up soaking wet tent fly's. they come in various lengths from 2-8' (most common are 3-4'), are about 3/4" wide and have a small cambuckle with a wire keeper, I often use them to attach my gardener's kneeling pad to my seat as well as attaching reflectix to my winter camp chair, simple and easy to use, weigh under an ounce, have plenty of friction to hold them in place, and can just be stuffed in your pocket when not needed.
They're still cheap and easy to find at most outdoor stores in the backpacking section and generally run around $10 for a set of two, although the vast majority of mine were bought 50 years ago :)
there's actually a line of creams and powders designed just for this- they work by eliminating the chafing in the first place...
check out https://www.antimonkeybutt.com/
The current model of the swift deluxe seat pad with straps is the most comfortable of the four types I own.
The problem of fasstening a pad to a seat with straps or even using duct tape, is not so much of a problem with a rectangular bench seat or the like. But when it comes to a molded curved bottom tractor style seat on a movable rail or for a floor mounted solo seat, it is not so obviously easy.
my old "li'l red" of indeterminate manufacturer had a tractor seat, it took a little more work and finagling but what I did was cut the pad to the appropriate shape then used the drain holes to mark where to cut slits for the straps. Then I fed the straps through and used marine contact cement to glue coarse polyester over the straps to make contoured tubes to run the straps through, after assembly I wrapped the whole thing in the polyester just to make it look good and help prevent abrasion- that pad lasted at least 15 years until the boat was stolen from my yard...
my present lady has sliders and it just meant feeding the straps under the seat and over the rails...
My Clipper Packer has a tractor seat and I bought the Clipper gel pad for the seat. It works well and has an added feature of a bottle storage under the seat that makes it handy for quick drinks.
