• Happy Discovery of DNA Double Helix (1953)! 🧬
Source for Canadian Maps
I would use CalTopo where you can easily print out map sections at any scale and size that you want. You can add waypoints and other info before you print.
If you want full size copies of the old Canada Topo's the government no longer prints them but there are third-party services that can.
You can find a few of them on this page, pretty sure there are others.
You might try this. They do have nts topo maps.
Thanks. I prefer the old topo maps and will be looking into these.
Im looking for the Armstrong 1:50,000 NTS map. Seems to be unavailable from World of Maps, Maptown, etc. Sad if paper topo map products are going away.
Not gone away just switched to Print On Demand, nobody wants to stock all 22,000 1:50 topos in pre-printed form. Even just the popular ones would be several thousand.
"Armstrong" is the name of the 1:250,000 topo map sheet 52J.
All 16 of the 1:50,000 topo map sheets in the 52J area - none of which is named "Armstrong" - are listed on the map world website here:
They are also available free online using the sites referenced by Mason above.
Yeah, it’s numbers 52, 53 in the Armstrong area
Yes, but here is the index for area 53. I can’t read a thing. Cross referencing to a legible map. IMG_6898.jpeg
Here’s what clicking a desired sheet (any sheet) returns.
GoTrekkers has an Ontario base map that looks like this when zoomed in on the Armstrong area.
If the Canadian topographic index map provided below is not detailed enough for you to find the map you wish to purchase, please Click here to view our extremely detailed Canadian topographic index map. This will open up a new webpage where you can identify the map you wish and will be able to return to this page and add the particular map(s) to your shopping cart.
Hope this helps.
Hope this helps.
I just used this provider. It was relatively easy and I could see the river and lakes , etc clearly.
Hope this helps.
I’ll try with my laptop. Neither of my phone’s browsers will work on this link.
