• Happy Father's Day! 👨‍🦳👨‍👧‍👦😍
Solo Canoe for Dogs
My wife and I have been canoe camping in the ADK and Algonquin regions for about a decade typically with 2 (once 4) dogs and 2x 120L dry packs using a 1980 BlueWater Jensen 18’ cruiser. This canoe has been fast, easy enough to turn despite the length, ok in head and side winds when loaded, but not always the most stable with dogs who don’t know to keep seated in the center; our older pups are pros now.
While we plan to keep using it for some trips, she wants to get a solo canoes to replace our aging plastic kayaks for our more local river outings. Wanting to only buy these once, I need them to be right for portage trips as well. Our portage trips have been mostly in open water, some times with chop. Used in rivers with just class 1 water, maybe class 2 once.
Looking to hold 1- 2 dogs or 1 dog and one dry pack. Just because, I would get a different brands and model canoe for each of us. Probably will want to be in a sitting position, with foot pegs and use a double blade paddle.
I know the best way to see for my self is to demo them, but that can be hard with dogs. Anyone have any opinions about any of the following options, when it comes to balance and room for dogs?
Northstar Northwind - probably Starlight buildup
Hornbeck 14’ or 15’6” Classic - probably low or mid profile and Matrix Skin
Adirondack Canoe Company Boreas - trimmed sides and carbon kevlar skin
There is a Swift dealer in Canada that I could make a side trip to. And a Wenonah dealer I live close to.
Some solo canoes have a pretty narrow beam. Not the best for hauling dogs. I like at least 34 inches of beam for a boat with dogs, especially multiple dogs.
I have found tandems set up for solo best for long days paddling and dogs. My veteran tripping dog is 10.5 years old. He moves around often to ease his painful joints. He is often accompanied by my 8 month old pup who is doing well, but clearly still in the train phase. Hemlock Eaglet, set up as solo has room for me ( 6’2” ) 215 pounds, 65 five pound Vizsla and 40 plus pound pup. This canoe is robustly built - in light weight skin coat, 40 pounds or so, and is symmetrical … nimble but easy to track straight ( especially with double blade ).
Also, Polaris NorthStar, set up as solo, very stable and large for two dogs … nimble enough and faster than the Eaglet.
Below are pics of my Eaglet with seat back and foot braces. Good luck with your search.
Bob.
I had a Northstar Northwind Solo and it easily handled my 60 pound coonhound, but I'm a kneeler and want my dog right in front of me. It's a stable, high capacity solo. In the Swift line the Keewaydin 15 is very similar to NW Solo and their Prospector 14 is their most stable solo.
In your case we need to know the weight of the dogs and paddlers. If you're counting on the dog being comfy while you sit with your legs straight out you might want to try it first. That works for our latest dog since she's small and tolerant but my bigger dogs didn't like being so confined.
if the dog is OK sitting behind you that could work since you plan to trim with a pack at the other end. I like dog in front.
The dog's temperament matters more in a solo.
I agree with Bob that a light tandem may be worth considering. I have a Northstar Polaris with 3 seats and when paddling solo it could handle 2 dogs easily. Polarus is slightly narrower than most tandems and solos nicely. Eaglet is another fine choice.
Thanks all. My dogs are Siberian huskies, with weights ranging from 55lbs - 40lbs.
Generally I would look for the dog to be in the front and the pack behind me.
I’m about 5’10”, 195# myself.
Here’s how dense we packed for some of our limited or non portage canoe camping trips
I had no problems carrying a 60 pound springer spaniel in a Bell Magic. We would paddle the local rivers and lakes and fish from it. There was room behind the seat for a pack.
But unless you're comfortable in relatively narrow solo canoes I wouldn't make a blanket recommendation of it.
Since you're talking about possibly carrying multiple dogs of that size then I would echo the advice of the others to look for a small tandem setup as a solo. I personally do not like paddling such large canoes solo but plenty of others do.
It wasn't on your list but I have a Hemlock "Peregrine" and it fits me and my dog with room for gear. My dog, a bona-fide mutt, is about 55 pounds but is willing to lay down on a piece of old yoga mat and stay still most of the time. With her in front of me, there is still room for a good sized pack behind me. If you're really set on a solo, I would suggest you check one out if you can. It might be just what you're looking for.
I frequently have my dogs in my esquif adirondack and swift shearwater one at at time and now that I have the pocket canyon I can take out two at a time solo. My dogs weigh between 50 - 70 lbs.
I've shared pics before but I can share some again so you can see space available with different size dogs in the same boats if that would help
They are located close to me and I didn’t know it. I’ll check them out!
In my experience the Peregrine and Shearwater are both superb dog boats. Hemlock offers a seat with some fore/aft adjustment that may be quite helpful when carrying a dog (for making dog space and for proper trim).
Overall I'd say it's good to stay within the efficient load range for whatever boat you choose. I think NW Solo can take up to 340 pounds and Peregrine and Shearwater 320.
I think the Magic is worth considering too; it's made for paddlers that sit vs kneel.
I ended up going with a north wind as someone put one of for sale, starlight with e6 gunwales, close to me at too good a price to pass up. It’s very fast, but slightly tippy. However it has a traditional kneeling seat with foot brace instead of a pack seat, so I think getting their foam pack seat and back band to sit lower will help. Also if it’s loaded down that will help.
I used it with Walmart sleeping pads which are closed cell, and my older dogs loved it.
Nice canoe. Glad you found one. How high is the seat from the floor? A seated setup will probably be around 6" and kneeling will be higher.
If it's setup for sitting I recommend giving it a little more time before going to something like a pack seat. You might feel pretty comfortable after a few outings.
I also recommend intentionally capsizing in shallow water. See how far you can heel it over before capsizing. You'll probably find that while it initially feels tippy that it will firm up after it's leaned over a bit. Once you get used to it you just ignore that little twitchyness and know you can rely on that secondary stability.
I’m fine with it on my own, but with my dogs is when it gets tippy. So far I’ve used it with my older dogs which know to keep their butts centered in the middle and it wasn’t terrible. But with the younger dogs are too hyper for that and keep me counter balancing it.
The seat is currently about 6.5” from the floor, low but, lower around 4” would be nicer. I think they still have a set of lower gunwale drops, but I also go it to replace my kayak, so I don’t mind it having the same kind of foam low seat and back band.
Not sure there's a right answer on this one, but there's probably a few wrong ones.
55 pound Cerberus has a tight fit up front in my narrow boat (Savage River Blackwater), but she can turn around, she can lay down, etc...all while staying pretty centered L-R. Which I think helps stability a lot.
