What Size Spinning Rod for Paddlecraft?
Eastern Washington
I am not new to fishing in general, but I am new to fishing from a canoe/yak, new to warm water, and I was fly-only for a few years. I have a 9 foot medium wt spinning rod that I originally got for walking the beach and casting in the surf. It's great from the beach but I think it might be a bit much from a tiny boat and/or the typical tight cover of a riverbank. Other than that all I have is my deep sea boat rod and a 6 wt fly rod and 8 wt switch rod.
I plan to fish rivers and ponds, both from both in and out of the boat. Eastern Washington. Typical warm water stuff like, bass, walleye, crappie, bluegill, cats, carp, and so on. I got a 6'6" medium wt spinning rod but still have the tags on so I could still exchange it for something else. As a teen I had a 7ft med wt that went everywhere with me and was an excellent all-rounder, so I naturally gravitated towards something close to that but part of me wonders if I should have gone shorter/lighter for the boat and bank.
What do you all think?
I would say, whatever you are comfortable with.
I fish a few bamboo fly rods that are7’6” four weights to 8’ six weights, I also have a couple graphite 10’ six and seven weights. And a fiberglass S glass five weight fly/spinning pack rod combination, that is an eight footer. Which rod or rods I take depends on target species and waters most likely that we will be fishing.
I have found casting flies from a canoe seat more difficult than wading. I practice lawn casting from a chair or sitting on the ground to help prepare me for that.
A good stern paddler that positions the canoe is more important than most people realize. Knowing where your back cast is, is very important to you and the person at the other end of the canoe. I also take a net with a longer collapsible handle.
Guess I should have read the title of this thread, hope I didn’t hurt anyone’s tender feeling’s with thread drift, If I did, I apologize.
On trips, I carry two 7 foot, medium light, fast action rods spooled with 4-6 lb flourocarbon line. The same two that I use for finesse fishing on my bass boat.
Pike often break off pretty easily and you'll be awhile landing a nice smallie or laker but I tried lightweight braid briefly and, as mem says, it's tough to break off when snagged.
I make sure that they're tied into the inside of the canoe during portages but I still broke a rod tip doing the Marshall Lake loop this past year (which is why I carry 2 rods... stuff happens & I don't want to be out of business when one breaks and, of course, they will... all part of the game that we play)
One of the places I fish puts me among a lot of trees with low hanging limbs. I use an ultralight 4.5' spinning rig for that. Since it's a lake, if I need more reach I can just paddle closer.
Most of the rest of the time, I'm using my 5.5' ultralight with 5 lb Spiderwire. It's surprising how far I can cast with that. Having a very efficient reel design helps a lot.
(Edit: I've switched to 10 lb Power Pro (braided Spectra). Stronger but just as thin/light.)
I do use a fly rod sometimes if there's room to do so. I takes some practice, but I've learned that I can cast effectively from sitting - even moreso from kneeling.
I second the 5 1/2' utralight, mine is a custom made from a cut down daiwa 2wt fly blank- short enough to easily handle in the boat, while still enough backbone and flex to handle the bigger stuff, it also is sensitive enough for the "shy biters", I've never even tried line heavier than 6lb, it was more than enough for a nice 14lb brown trout a few years ago...
I usually bring a 7’ medium weight fast action rod with a 2500 series reel. I use 20 pound braid, but always tie on a 10 pound fluorocarbon leader if fishing for bass or walleye. The leader serves two purposes, it’s less visible than the braid and breaks more easily if snagged. With pike I use a 30 lb wire leader but use floating rapala’s so the chance of a snag is reduced.
Gamma, you probably know this, but they make rod tip repair kits that pack up small and light. Basically it’s just a new eye and stick of glue you melt with a lighter. I’ve replaced rod tips on remote trips several times without issue.
Gamma, you probably know this...
I am aware but, at least to me, they just don't seem to fish the same. I guess everybody has their idiosyncrasies... I can drive a truck with 5 different colors of paint and enough miles that most wouldn't drive it beyond walking distance of home; bash canoes off of rocks and drag them over portages, even forget to pack a tent for a 2 week trip and none of that ever bothers me. I break a rod tip and I'm just packing out the garbage so I can save the reel and not leave (shtuff) in the forest.
I'll replace line guides if the ceramic gets cracked but the tip is a deal breaker. (just weird that way)
I ended up trading it for a same size and weight (6'6 medium) rod but with a faster action. I think the faster action will help me not feel like I'm over-poled for small lures while still having a decent sized pole overall. It feels a little big for use sitting down but it's not bad, and I'll be glad I have it when I'm fishing from the bank when I'm stopped or at camp. It's also a good all-purpose size for a backup/loaner rod.
I got a 3000 size reel and I plan to go with 12lb mono because it's rocky here but I'm not dead set on that.
Double check the line rating on the rod. A 6'6" medium might be rated for 12lb, but I would think it would be less. Possible to break the rod.
I looked and it's rated for 14, and it's an Ugly Stik. I know a lot of people turn their nose up, and they have a lot of marketing but all through my teens and 20s I fished with a hand-me-down 7' Medium Ugly Stik from the late 70s or early 80s (best anyone can remember). I watched it bend almost completely over when I hooked a leopard shark off a pier with the butt in a knot hole and the rod resting against the railing. I fished with it for another 10 years with zero issues.
This time around I went with an Ugly Stik Elite and like the faster action WAY better than a normal Ugly Stik. I liked it so much that I bought another one, a 5'8" Light when I saw it on a decent sale just a few days later, paired with a 1000 size reel and 6lb line. I was seriously impressed with the action on that rod, my little 7yo nephew who has never fished before was slingling a bobber (the weighted foam kind) and worm with it about as far as I was fly casting with a 9' 6wt.
I think shorter is better. When I'm in the stern with someone in the bow I can lay my 6'6" rod across the thwarts without it reaching the bow seat. I'm a lot less concerned it will get broke than I am with my longer rods.
In this photo (taken this AM) you can see my spinning rod on the left. The rod tip stops at the bow thwart and stays clear of the seat. The fly rods on the other hand go past the bow seat. If there was a person in the seat I would have put the tips of the longer rods under the bow seat, but I'm always afraid the bow person might break them.
For bass, pike and smaller, which I fish for a LOT, I use 500 and 1000 Okuma spinning reels loaded with 6lb mono on Diawa Spinmatic rods 6'-6" ultralights. They are cheap, work well from poppers to plugs and soft plastics. I've used them on 40-50 bass trips a season with zero problems or complaints. They are listed as fast action, sorry but it's slow, which I like. Occasionally a pike will pop me off, happened this morning, but it's pretty rare. Not much fun winching in a fish, these are a nice compromise that gets you owned a few times a season but otherwise holds it's one on some nice fish. I also use ultralight casting and fly rod setups for the same fish, typically taking them and the 2 spinning rigs when I go out.
I have found that longer rods (over about 7 feet) make it problematic for me to lip a fish when I get it alongside. A new BFS rod I picked up is a 6 footer ultrafast rod and presented a new challenge. The tip of the rod is so quick, that you need to keep the pole aimed towards the fish, 45-60 degrees or so, in order to get the power out of the lower section. Beautiful rod that's a new favorite but comes with a learning curve. When I bring a fish alongside, that angle goes vertical or backwards, and with it the power. Same type of thing that happens with longer rods.
First fish of the morning and first fish with the new BFS rod n reel. Another fish with the tried-and-true Diawa/Oluma set up. Was a rather nice trip.
I like to fish with ultralight tackle, it makes small fish a lot more fun to fight. You catch a lot more small fish than large ones, so...
I'm tough on my stuff so I tend to gravitate to the less expensive side of things now-a-days when it comes to rods and reels. I pull them apart, slick everything up and re-spool them with something that will work for the fish I'm after. I fished with hella expensive open face baitcasters on hella expensive rods for years but I prefer spinning reels or spincast reels now, mainly because of the simplicity, but also if I break something, I can drop a hundred bucks and replace it (Zebs for well under $100). I've found over the years I catch as many fish on a $100 setup as I do on a $1000 setup and feel a whole lot better about it if it gets stepped on or dropped over board.
Right now I have 5 different combos that I use. My main two are a couple of really small set ups with heavy line for their size. First is a 5' light action one piece Ugly Stik spinning combo, Bass Pro special. I have it spooled with PowerPro 15lb braid, I throw it more than anything else. It's my main rod for bass and other sport fish. I also have a Zebco Micro 33 5' spincaster one piece combo, light action, spooled with Trilene XT 12lb mono for when I'm in really clear water or want to swap out between a couple of different baits in the same area. I use those two in my kayak (and last weekend in my new-to-me canoe) more than anything else. I like the compact nature of them and I can get close enough in a micro-craft that throw distance isn't an issue. I only use low-vis line, both braid and mono.
I also have an Ugly Stik 7' two piece medium action spinning combo that I use for larger stuff, i.e. catfish, drum, red fish, tuna, grinnel (bowfins) or gar. I have it spooled with PowerPro 30lb braid. Last but not least, I have an 9' ultralight action Ugly Stik spinning combo for white perch (crappie). It has 6lb Trilene XL on it. These two make it on the boat if I'm going after those specific species otherwise it's the kiddie rods for me.
If you can't tell, I think Shakespeare strikes a good balance between value, performance and durability. I have a few other things, I like to fly fish in the spring for perch so I have a Bass Pro White River 9' fly rod setup and I have (3) Zebco 33 5'6" combos I hand out to friends and family when I have company. I also have all my grandpa's stuff, he taught me to fish, they're all wall hangers now though since he's gone.
Down south here I'm generally targeting largemouth and spotted bass and prefer a 5 1/2 rod with a lightweight spinning reel and 8lb mono. My fav rod is an old custom made one piece fiberglass I inherited from Dad, w/cork handle, a stiff backbone and a sensitive tip. Current reel is a small Shimono. Works for most plastics, jigs, and small crankbaits. My fishing routine is totally casual and non competitive, lots of times I dont even bother, so I dont get too obsessed about it, But thats the gear I normally have with me and it seems to get the job done out of my 12 and 14' solo canoes.
