• Happy Father's Day! 👨‍🦳👨‍👧‍👦😍
Which Canoe For Summer Solo?
Great input, thank you. My back isn't always happy with me, but my knees surprisingly have held up rather well. I'll probably sit most of the time but kneeling generally isn't an issue. Getting into and out of the kneeling position might isn't fun though. Stiff and old.
I'd label preferences as primary stability, ability to turn in smaller streams, overall weight and length. Based on my excursions around here, portages are anticipated to be fairly short and often but with very dense trees and brush. Maybe I'm wrong but it seems that a shorter boat is going to be easier to portage and probably be more manageable on smaller water. That makes me leery of going longer than 14'. It's also why the interest in the 12' trapper, granted it's close at only a 2 hour drive and a good price.
As I mentioned before, for lakes I fish from one of my kayaks. I've got a couple of small lakes that I'd take my Brittany with me but primary use for the canoe will be smaller rivers.
....took way too long to type this....I keep running errands, bank etc.....
The person with the Nova Trapper called me back, I'm going to go pick it up tomorrow morning. It's a green FG canoe still in the plastic wrapper for $1250. I'm sure I'll end up buying another canoe, but for the price I couldn't pass this one up. Time to research addles and a few other essentials.
Thank you all for the insightful and quality input.
I traded my BS p15 last year. Wish I’d known.
Appreciate that. My preference would be the 16'.
I stupidly passed on the one that was offered to me a few years ago. Not long after that, I decided my royalex P16 had gotten too heavy.
Shoulda been listening to Glenn. I'm smarter now. ;)
I'd call the Swift P14 and 15 lake boats for sure. In my limited experience the P14 turns nicely with a gentle lean but that's all it's got; it does not want to lean to the rail or spin on a dime or get horsed around...so not a good choice for someone that needs a true Prospector with generous rocker for swift current or dangerous rivers.
My take is that Swift is using the Prospector name for marketing.
The marketing, or something, is working very well for the Swift P14. I distinctly recall a Swift video (in 2023, I think) in which Bill says the P14 outsells all their other solo canoes combined. I assume that's because it is safe and friendly feeling, is satisfactory on lakes and easy whitewater, and can fit both males and females.
I’m not seeing much room for gear and my mut. I could probably fit 2 packs with the dog, but it would be tight.
My preference for solo tripping with overnight gear is a 15'-15.5' solo canoe. Your picture, Tony, reminds me why.
Most such overnight trips, whether on lakes or easy rivers, are 98% straight ahead paddling, so the enhanced maneuverability of a 14' canoe is irrelevant to me. I'd rather have enhanced forward speed efficiency, gear capacity and freeboard. A 15' solo canoe can maneuver perfectly fine if it has progressive secondary stability to the rail and you are comfortable effectuating turns by heeling the canoe to release the stems.
As the owner of a 14' black-gold Bell Wildfire, which is a fun and maneuverable freestyle and day canoe, I find that it bogs down at around 275 lbs. of total load, resulting in a loss of the rockered maneuverability and too little freeboard for my taste. Hence, I view its suitability as gear tripping canoe to be dependent upon how much the paddler weighs. Fortunately, I've lost a lot of weight from my Covid-couch-potato peak.
Only minor issues getting 50 days of supplies into the XL14 (14'3", 32" width at gunnels, 30 at waterline, 3" rocker).
This pic is from about day 12/51, there has been a little "settling" of the dry bags.
Same boat, different trip, the Put-in at Harris Lake (near Savant Lake), start of a 46 day trip to Fort Albany on James Bay.
I gave up trying to get that barrel lying down! I was only paddling up to the north end of the lake so didn't worry about it. After the portage there I rearranged things so it all fit nicely. Since I took the train the gear was weighed 225lbs plus I carried on about 50lbs, pfd, paddles, ropes, carabiners, water bottles (filled) etc were all attached to the canoe. probably close to 300lbs total plus me at 150lbs
Recped, a nice packing job but I don't see any place to sit. Just curious, what happened to your right bow gunwale where you have the aluminum brace? It looks kinked.
The seat is hidden behind the big green dry bag, you can see the nalgene bottle sitting on the rails. You get a better view of the seat location in the video image below. Note that it's the stern that is up against the shoreline.
I wondered if somebody might notice the kink, the boat got involved in a "hockey fight" with a rock while lining. The insert inside the the vinyl gunnels pretty much broke, I installed that metal "strut" (electrical conduit) to prevent further damage (doubles as a good mounting location for my GoPro) and surprisingly I think the canoe tracks better with that twisted nose!
You can see it all happen here:
Criminy, what a video! Hard not to go off on a lining tangent.
As you were lining that heavily packed canoe, I was actually wondering if you could hold on to all that weight if the canoe capsized . . . . and THEN . . . !
A simple bailer may have made emptying easier at the end. Two questions: Do you think you would have been better off with an under-keel bridle or at least waterline lining holes? Did you lose anything?
First problem was simply being a bit lackadaisical, the nose of the boat caught the rock because I let the bow float out to far and when I went to pull it in there was too much slack at that point it was really too late to do anything, I took a quick look downstream and seeing the huge pool (the Bloodvien is truly pool and drop) just let go.
I lost nothing, the end of the boat has modified flotation cages, they have quick release buckles, any gear in the cages stays put, everything not in the cages is tethered including the throw bag which I grabbed and swam to shore to pull the canoe in rather than try and drag it while swimming. My semi-dry bottoms filled up with water and some water leaked into my soft-side cooler everything else remain dry and secure.
An under-keel bridal would probably help but the real problem was bad rope management. If not for the ledge about halfway down I would have run instead of lining.
