The Adirondack Canoe Company. Boreas is the model and comes in at 27 pounds. It's a 14' Carbon fiber canoe. But, it has 3 other hull material options with Kevlar being one of them. It's narrower than I'm used to so I will test paddle it and any other canoe I'd consider purchasing before I commit. I'm a flat water paddler and stick close to the shore. I don't take any unnecessary chances on large open water crossings.Hey Tim,
I have a bad back too, throw in two junky shoulders. I didn’t catch your size, but part of your criteria should include the durability necessary for your paddling. UL Kevlar is fine if lakes are all you paddle, just get a boat that will hold you and your gear, and is sea worthy. If rocky rivers are on your list, you might consider the expedition Kevlar from Swift. I love my Prospector 14. At 41 lbs, it’s my heaviest canoe, but I can handle it. Kevlar’s also easy to repair.
My tripper is a Northstar Magic in UL Kevlar, but it may be a tad tippy for your taste. It handles me, my gear and dog for the trips you describe. Last winter while rehabbing my shoulder and back, I got a really light (29lb) Blacklite Phoenix. It was a mistake. I love the hull design, but it’s impractical or not ideal for all but a local reservoir backwater; too delicate for local streams, too responsive, low capacity for bigger water and tripping - but man is it easy to load and carry. I’ll either sell it or bash it up anyway.
So, I’d recommend a Kevlar boat, ultra light if you’re just doing lakes or larger streams, thicker Kevlar for other waters.
Hmm. If you meant my physical size. I'm 5'9" 210 pounds.
