• Happy Birthday, Mary Outerbridge (1852-86)! 🎾🇸 🇮 🇳 🇾 🌉
Drilling Lining Holes in My Hull
Nice job, Tony. For those who might come upon this thread first, it might be informative to describe what tools you used to make the clean hole, what diameter hole, what component parts you used, and where you got them.
Best way to do it. PVC works too.
Many people line off the thwarts. I have done it before. Too top heavy.
Materials, Tools List:
Everything is available at Lowe’s except for the epoxy.
• A couple feet of 5/8” OD reinforced vinyl tubing
• (4) 1/2” plastic box adapters (5/8” ID) - make sure your vinyl tubing will fit - I have run across some variances, depending on suppliers
• G-flex 655 epoxy
• Sanding sponges (80, 150 grits)
• Two #2 pencils
• Tongue depressors (for spreading, mixing epoxy)
• Hole saw (I use a 21.5mm which is perfect for the bushing)
• Small drill bit for guide holes
• Tape measure
• Dremel with cutoff saw and grinding cone
• Sharp knife
• 2 quick clamps
• Alcohol
• Paper towels
• Black sharpie
Lovely canoe, I guess after the first big trip thr bottom will look different. Drilling holes in new boats is something to get used to. Enjoy the paddling
Here is a little video I made of installing lining loops in my Swift Dragonfly 15.
Thanks for that video. I've never drilled or used a canoe with lining holes, but my understanding is that they should be low enough so that they are just above the cutwater when the loaded canoe is being lined or tracked.
Robert, your DF 15 is so customized that I don't recall whether it has factory float tanks. If it does, I'm curious as to whether Swift filled them with foam or left them empty. I assume empty with a relief valve.
Glenn, the float tanks were optional from Swift and they are air chambers.
