I'm separating this from my build thread since it may be of interest to those building non decked canoes. As I said in the Kruger build thread, I'd like to stick close to Verlen Krugers design in building my boat, so that means I'll build seat risers the same as found in a Sea Wind or Mad River Monarch. The main advantage to this design is that the seat riser acts as a buttress for the coaming, which will have to take the weight and tension from straps while transporting the canoe. Another reported advantage is that you can pull the seat out and sleep in there if you can't find a good place to camp. I can visualize making a cockpit cover out of bug netting and just stringing a tarp over the whole thing as an emergency sleep shelter, but realistically I probably wouldn't use it that way.
Here are pictures of the riser and how the seat with attached portage yoke sit inside the canoe. I talked to Scott Smith, one of Verlen Krugers proteges a couple weeks ago, and he said they hand laid these panels with fiberglass topped off with kevlar on each side. They're about 1/8" thick meaning lots of layers of glass, more than I want to deal with.
I am thinking I could use a wood core to build the thickness and use fiberglass and possibly carbon or kevlar on the outside to make something strong enough. I'm not worried as much about making a panel strong enough in the vertical direction. I think any wood, even cedar, with a couple layers of glass on each side would work fine. I'm more concerned about the horizontal stiffness since there would likely be some seat movement from side to side. Too much flex in that direction could be an issue. If I had it available, and it didn't cost so much, I would buy some Okume plywood for the core. Regular plywood, maybe 1/4" would also probably work too. Looking here at home I have some left over cedar planking that is 5/32" thick and 3-3/4" wide. I thought maybe I could make a panel double that thickness by laminating a course of planks going horizontal and a course vertical, then glassing the outside. I don't think it would have much flex at all with a couple layers of glass on both sides. I suppose I could also mill some hardwood and make 1/8" planks from that and do the same thing.
Any thoughts or suggestions out there?
Mark
Mark
