• The 2026-29 Fund Drive needs 11 MORE DONATIONS to reach target. Read the Featured Thread for details. Please donate!!!
Driving with your canoe on the car all summer long
My latest canoe carrying vehicle is a 2025 CRV hybrid. With mixed driving i consistently get 45 mpg, mostly highway at 73 mph drops me to 37 mpg. Gonna have MDB’s and my canoe on top this weekend, I’ll check mileage and report back.
As far as storing a canoe for a summer on the roof top? Well, I have ample storage but even if I didn’t, I think I would find somewhere to keep it stashed away from the weather.
I used to get the best mileage with my 2002 Ford Ranger with a boat on the roof. Then again the only all highway driving I did with that vehicle was with a boat on the roof.
I'd say that if it gets you on the water more it's worth the downsides of it.
As a former aerodynamic loads engineer, one canoe on a roof can be quite aerodynamic (it does depend on the shape of the vehicle), but 2 canoes on a roof is as aerodynamically clean as having a refrigerator with the door flapping in the wind up there, no matter what you are driving.
Thanks for the explanation. Brought to mind a trip I made to Canada from IL with a boxy 1966 Dodge with one Grumman canoe on top. As I remember it the mileage was better and car only had the slant six in it.
I’m not as versed in aerodynamics as some of the others here but I do know the aero losses increase dramatically (to the sq?) with increases in length wrt to flow.
Witness every airplane wing profile, much wider than long wrt flow.
It stands to reason then, that the most aero efficient way to cartop a canoe would be to minimize the length wrt flow path by mounting your canoe with the keel vertical and facing forward.
While this may cause minor problems at the first underpass, you could relax knowing that you’re as efficient as possible.
Disclaimer: you may have some difficulty with buoyancy after that first underpass!
No offense but my 20+ years as a lead engineer calculating aerodynamic loads for Boeing suggests that you don't have a clue. So, here's a quick tutorial...
1 - force increases by the square of the speed. And, it works for everything.... double your speed and the force quadruples, triple your speed and the force goes up 9x. It works for car accidents and hockey pucks and it works for basic aero stuff, and it figures into your fuel mileage. You will always wear your seatbelt if you understand this fact, and you might adjust your following distance when driving.
2 - length is a secondary or tertiary effect if the flow is smooth. 15 ft canoe or 20 ft canoe, you won't notice the effect unless you're some kind of mad scientist. If the air ain't smooth, it doesn't matter...nothing matters at that point.
3 - wings aren't long and skinny to decrease drag. They are long and skinny to maximize lift. They are swept back (on fast stuff) because that does reduce drag at higher speeds, but now we're getting into transonic (mach .4 to mach .99) stuff that doesn't have anything to do with canoes on cars, unless you're going for a land speed record with a canoe on your rocket car, of course..
4 - Frontal area of the canoe counts, as does smooth airflow around the canoe. AND the car. That frontal area of the canoe ain't such a big deal if the airflow is smooth - as you would expect for a canoe shape.
For some reason, my Subaru Outback and 16-17 ft canoes "get along" really well and I notice no difference in mileage (because I do have a canoe on my car 13-14 days/month).
Why you ask?
I don't know, but I would guess that the extra drag created by the air getting goofed up at the front end of the canoe and car is equaled out by the canoe hanging out over the back of the car... could be that the stern of the canoe is acting like the winglets that you see on airliner wingtips, which create nice vortices that dissipate the drag that an un-winglet wing creates. Whatever is going on, it works.
5 - Carrying 2 canoes side by side will be like carrying a big box on the roof because the air is just going to ram itself into the space between the canoes....junk airflow as we used to say.
Summary -
All cars. vans. pickup trucks will have different results, and it's just kind of a crapshoot. However, drive within the speed limit to get better mileage (your newish car was designed to do that to meet government mileage standards), wear your seatbelt in the car, and when you are flying, read the emergency exit card, note the nearest exit and count the number of seatbacks between you and it, and listen to the flight attendant and keep your seat belt fastened unless you have to go potty. And I quit at the beginning of the absolutely moronic 787 program, so the later 737-MAX is not my fault. But if you like flying on 777's, I'm glad to take some credit.
I saw a car with the canoe cross wise on the car, but that was only because they forgot to tie it down.
I've actually seen that FAR more times than I've wanted. Canoes at anywhere from a 45° angle to fully perpendicular at highway speeds on the Ontario 400 Hwy heading north away from the city, but rarely on the way south- makes you wonder where that boat is now....
...reduce drag at higher speeds, but now we're getting into transonic (mach .4 to mach .99) stuff that doesn't have anything to do with canoes on cars, unless you're going for a land speed record
or you've waited years to escape civilization for a bit and are using all available horsepower.
(Actually, I could go with that excuse but it's mostly just the way I drive because I like to get my money's worth from every ticket)
Just got back from a short paddling trip with the grandkids and son with DIL...
Relatively short drive, 70 miles total up and back, mostly highway at 67 mph...mpg dropped from 37 with no boats (at 73mph) to 33 mpg with two canoes and my old square Thule racks.
10% drop in mpg, would have been worse if I was going 73 mph, ouch!!
Here is another one Benson. I went on a group paddle today, it was fun but we were the only ones in canoes, there was one strip built Bidarka and the other twenty boats were paddle boards or sit upon kayak abominations. We all had pizza after the paddle and I saw this when we were leaving.
Good golly the rope handle is touching the ground.
Reminds me of a guy I worked with, he used to drive around with a kayak stuck down into the passenger seat of his Triumph TR-8.
But to the OP, it's good for your mental health... years ago I concluded that it's impossible to be in a bad mood with a canoe strapped to the roof of your car. :)
Regarding the OP, I spent several seasons with my Royalex Wenonah on my roof for months at a time. It didn't suffer any ill effects that I can tell, though I recognize the OP has kevlar not Royalex.
My mileage suffered but it was worth it to get on the water faster and more often. Whatever UV degradation was worth it for the same reason. No point having cars and canoes if you don't use em.
Just returned from 2000 mile round trip to Atikaki PP in Manitoba. Driving 2020 Dodge Durango 3.7lL engine. I wanted to minimize the junk air flow Scotts mentioned. I spread the canoes apart as much as I could. 75 mph and I only dropped to 20mpg from usual 23.
